INSTRUCTIONS for plantonics sbu 100 bluetooth/usb hard to read... need something i an enlarge on pc monitor
  • 15,935 Answers
Please verify the model # for PLANTRONICS.
You entered SBU 100 and they do not have that model #.
Thank you
Please use the "continue with this expert" option so we are connected in the future.
Posted on May 16, 2009
I have a plantonics headset that does not pair with my I phone 4s, I have pressed the button on it until the light comes up but no results, I have a plantonics 975
Turn on Bluetooth option within your phone - Consult phone instruction booklet
Put phone into pairing mode - Consult phone instruction booklet
Put the 975 headset into pairing mode - With the 975 headset on, press and hold Call Control Button until the headset begins to flash red and white.
Select "Add new device" on your phone.
Select the Plantronics 975 headset when prompted. Enter "0000" as passcode.
Your 975 headset will now have a continuous white light blinking.
Choose "Yes" if your phones asks if you want to bond to the 975 bluetooth headset.
Your phone is now paired with the Plantronics 975 headset and ready for use.
Dec 22, 2012 | Cell Phones
I have a broken earloop on my Plantonic 2XX blue tooth.... also the ear piece has a hard time staying on the prong. What can I do to fix these?
The ear loop for the Plantronics Explorer 232 Bluetooth headset can be replaced, the replacement ear loop model number is 80334-01.
http://www.headsetsdirect.com/
80334-01-explorer-earloop.html
If the plastic housing is coming apart, just remember that Plantronics has a one year warranty on the Explorer 232 Bluetooth headset.
Good luck from Headsets Direct - 800-914-7996.
Aug 22, 2011 | Plantronics Explorer 232 Bluetooth Headset
I have brought a tesco onebody heart rate monitor and watch are there any online instructions as the instructions with it are to small for me to read
What may be easier, is to take the instructions you have to a local copy center have them make a copy in an enlarged format. Or have someone take it to work with them and have them make an enlarged copy for you. Most office copiers will enlarge the print.
Feb 25, 2011 | Exercise & Fitness
I have a plantonics voyager pro. It won't pair with Nokia 7230. How could I solve? this problem? Serra
Check First If it Compable with Your Nokia 7230... From the net type Bluetooth programmation with Nokia 7230... Then Read Instruction., Good Luck
Oct 09, 2010 | Plantronics Voyager PRO Bluetooth Headset
Monintor does not read sd card or usb with inserted on monitor.
you need to connect a usb cable on it and attache the otehr end on the usb port of the comp
Mar 03, 2010 | Dell UltraSharp 2407WFP 24" LCD Monitor
I cant use my USB conector in PC
you just need to find a free driver to download for the computer to be able to read the device. After the driver is downloaded and installed, it should read automatically. At least that's how it works with windows vista. IF you have XP, you might need to run the wizard after the driver is installed
Feb 04, 2009 | Sony Ericsson HBV-100 Bluetooth VoIP Kit...
Umax Astra 6700 download driver error code 129
here is your code mines
101: EXPOSURE LAMP PROBLEM
120:SCANNER HOME PROBLEM
121:SCANNER HOME
124:SCANNER MOTOR PROBLEM
125:SCANNER MOTOR PROBLEM
126:SCANNER MOTOR PROBLEM
127:SCANNER MOTOR PROBLEM
129:SCANNER MOTOR PROBLEM
130:SICU / SBU PROBLEMS
300:CHARGE CORONA PROBLEMS
301:CHARGE CORONA PROBLEM
303:CHARGE GRID PROBLEM
304:CHARGE GRID PROBLEM
305:CHARGER UNIT WIRE CLEANER PROBLEM
306:CHARGER UNIT WIRE CLEANER PROBLEM
310-316:DRUM POTENTIAL SENSOR ERROR ISSUES
321:LASER UNIT WRITE PROBLEM
322:LASER UNIT 1 SYNCH. PROBLEM
323:LASER UNIT DRIVE PROBLEM
335-338:POLYGON MOTOR PROBLEMS
340-342:TONER DENSITY SENSOR ERROR ISSUES
345:DEVELOPER BIAS PROBLEM
350-355:IMAGE DENSITY SENSOR PROBLEMS
360:HARD DISK 1 PROBLEM
361:HARD DISK 2 PROBLEM
362:HARD DISK 1 PROBLEM
363:HARD DISK 2 PROBLEM
364:HARD DISK 1 PROBLEM
365:HARD DISK 2 PROBLEM
366:HARD DISK 1 PROBLEM
367:HARD DISK 2 PROBLEM
370-375:IMAGE COMPRESSION ERROR
376-377: SICU,IMAGE COMPRESSION ERROR
380-383:IMAGE DATA TRANSFER PROBLEM(SICU, SBU,PRINT CONTROLLER
Jul 01, 2008 | Umax Astra 6700 Flatbed Scanner
Passcode
The passcode should be four zeros: 0000
May 22, 2008 | Plantronics Polycom SoundPoint Pro SE-220...
To download drivers
I LOST CD FOR MY BILLIONTON USB ADAPTER CLASS 1 UPTO 100 METER RANGE ,ITS A BLUETOOTH V 2.0 COMPLIANT PLEASE HELP ME TO GET SOFTWARE FOR SAME
Apr 12, 2008 | Billionton Long Range Bluetooth USB...
Computers & Internet Logo
16 people viewed this question
David Payne
David Payne
