Question about Fisher Dishwashers
How to fix dishwasher door spring
Have a Fisher & Paykel ''Nautilus'' DW920 dishwasher.The door spring has either come off or broken.I know where to get the part but how do I take it apart to fix it?
5 Suggested Answers
  • 212 Answers
SOURCE: the panel cover on my fisher & paykel nautilus is broken
Fisher and paykel is based out of australia. call the # in the manual to order part. they have a division in california. parts usually take me two to three weeks to recieve.
Posted on Jun 21, 2009
SOURCE: Fisher Paykel Nautilus DW920- the latch on the
521782 HANDLE BRANDED 920 BK SATIN
Posted on Jul 02, 2009
ginko
  • 19396 Answers
SOURCE: I need to know how
Hi.
Click on the document below and open the schematics.
Disassembly start removing the screws that retain the front panel.
DW920 Parts Manual.pdf (285Kb)
Scroll down to the bottom of this forum to find a detailed description on how to take apart the machine (read Philips comment).
If this solution was helpful, then please do not forget to accept.
Good luck.
Ginko.
Posted on Sep 10, 2010
  • 251 Answers
SOURCE: fisher and paykel nautilus dw920 Need
Hi - here are the instructions to help with your project
1. Isolate from power.
2. To remove the outer door panel, remove the eight screws securing it to the inner door panel. Be careful of sharp edges.
3. To remove the handle, remove the six torx drive screws securing it through the inner door panel.
4. Refit in reverse manner.
Note: 230 volts is still present at the detergent dispenser and electronic P.C.B. unless power is isolated at the plug outlet or mains.
Location: The door handle latch is located within the centre of the handle moulding
and is retained by a pivot latch. The microswitch is situated on the side of
the latch and is clipped in.
After isolating the machine from the power supply:
1. Remove outer door and handle (refer Section 6.2).
2. Remove the latch by sliding it away from the P.C.B. console.
3. Unclip the microswitch from the latch.
4. Ensure the springs and microswitch lever are fitted to the latch when re-assembling.
Refitting: Refit in reverse manner.
Sorry I cannot provide a sketch for public view, I may get into trouble.
Cheers
Posted on Jul 07, 2011
Testimonial: "Not at all helpful"
Fisher and Paykel DW920 dishwasher pump wont stop
This means the flood circuit is triggered. There is a leak in the dishwasher causing water to collect in the motor chamber. The leak is usually through the door seals or broken hose. Disconnect mains electric and water connections and pull dishwasher out from under kitchen bench. Tilt it from side to side to get the water out from under the base. Wait a little for water to dry up. Reconnect mains power and turn on to see if pump stops running. As mentioned source of leak needs to be fixed.
Mar 15, 2013 | Fisher and Paykel Dishwashers
Fisher and paykel nautilus dw920 Need instructions to replace door latch (with images if possible) part # 521809
Cheers
Jul 07, 2011 | Dishwashers
Door drops down no tension
what do you mean buy the door has no tension. looking at the model number it is the two drawer glide systm
Jun 03, 2010 | Fisher and Paykel DS602 Dishwasher
The panel cover on my fisher & paykel nautilus is broken
Jun 21, 2009 | Dishwashers
My dishwasher keeps flashing F1 error message
The f1 code is caused moisture in the electronics part most likely in the door.see if there is any way that you can see where moisture might get in and plug that spot up. In the case of the f1 code when not using the dishwasher leave the door propped open to help dry out the electronics.
Nov 18, 2008 | Fisher Dishwashers
What is F4 error on fisher paykel dishwasher?
It means your filter is dirty. Remove metal plate at bottom & scrub with a toothbrush. Clean arms as well.
Clean all around the door & pull out the lift out filter, scrub clean with a toothbrush.
Oct 29, 2008 | Fisher and Paykel 24 in. DD-602 Built-in...
Dishwashers Logo
359 people viewed this question
Top Fisher Dishwashers Experts
Tony Houde
Tony Houde
Ronny Bennett Sr.
Ronny Bennett Sr.
Alan Matzke
Alan Matzke
Are you a Fisher Dishwasher Expert? Answer questions, earn points and help others
