Question about Flat Panel Televisions
Plasma TV 1/2 Black Screen after Storm
After a power surge during a storm yesterday, and although connected to a high end surge protector, the right side of my Plasma TV screen is completely blacked out.  Good Audio and beautiful picture on the left side, but 50% of screen is completely black!  TV is 9 months old, never a problem before yesterday.
  • 1635 Answers
SOURCE: water and a plasma tv
I am sure that there is damage to any of the boards that got wet, or had residue from being wet. The voltages in these sets are fairly high, and thus there is damage. Sometimes a damaged board can cause damage on other boards that are connected to it.
Before writing off the set, give it to the factory service rep just in case it may only be a failed board that is not terribly expensive.
If you had a flood and you have house insurance, find out if you are covered. In this case, let the insurance company deal with the set.
Jerry G.
Posted on May 29, 2008
SOURCE: Sanyo LCD HDTV Model #DP26746
I am missing the stand to my Sanyo LCD TV. (DP 32647). I dont know where to buy a replacement one.
Posted on Oct 24, 2008
  • 13 Answers
SOURCE: My LG 50' plasma tv popped like a firecracker no longer works
You have experienced a plasma eruption. The fix for this may easily surpass the value of the unit - sorry to hear that.
Posted on Apr 04, 2009
  • 187 Answers
SOURCE: lg plasma after storm doesnt want to turn on
Mainboard damaged and need to be replaced, try EBAY for a general picture of prices but you will need your product code wich is located in the back of the TV next to serial number.
Posted on May 27, 2009
SOURCE: no picture or sound, electrical storm
did you ever get it fixed? Are you looking at selling it or need parts. Mine fell and i broke the display panel, but everything else works
Posted on Jun 14, 2009
  • 975 Answers
SOURCE: my sony won't turn on after an electrical storm.
NEED TO CHECK POWER SUPPLY of your TV , Look for blown fuse , or replace power supply , AJ
Posted on Jul 08, 2009
0 characters
1 Points
My HDTV went out in a lightening storm. What could it be?
Is your TV plugged into a surge protector? If not it very well may have gotten a power surge during the lightening storm that fried components in the TV.
Or is the TV connected to a cable box? It could be that the cable box took the hit if it's not plugged into a surge protector.
Or a possibility of both.
Aug 03, 2015 | Proscan Flat Panel Televisions
Power surge westinghouse 48' tv how do i fix it?
Unfortunately, there is no way to know from here. It's likely that all of the boards in your TV will need replacement, and the screen itself may also need replacement.
I recommend a surge protector for the next one. . . Get a good surge protector, the cheap ones only work one time, and don't tell you when that one time is....
May 19, 2015 | Westinghouse Flat Panel Televisions
4red and 8 yellow code flash
I cannot post URLs here. Please try go googling this: "WD-73738 error codes"
The first result looks promising
Aug 18, 2014 | Mitsubishi WD-73738 73 inch DLP 1080p...
Insignia 37 sound after lightning storm and HDMI's are not working
Dude! You fried it! Sound board can be replaced, but what else was stressed? Replace it, use a good surge protector, and turn the thing off during storms, light a candle and cuddle with your sweetie.
Jul 15, 2014 | Insignia Flat Panel Televisions
How do i stop lightning from getting in my hdmi lines and shocking my tv? 5 tvs went down in one storm
I would recommend getting a surge protector and using that to protect your televisions. This usually will stop something the lightning from killing your tv's.. I have a surge protector and can still use my tv, computer, anything I have plugged in during a storm.
Oct 22, 2012 | Vizio 42 in. LCD TV
Hdmi ports not working after thunder storm
Hi, During a lighting storm unplug or get a surge protector. Your too late to do anthing now. Go to a repairman. good luck.
Jun 29, 2011 | Panasonic TH-42PX75U 42 in. Plasma...
We had lighnting storm pass by and our TV was plugged into a surge protector along with many other devices. When the storm passed the TV will not turn on anymore.
Likely, the surge protector failed.
Depending on the manufacturer, you may have some sort of warranty available. That is, the manufacturer of the surge protector may reimburse you for the cost of TV repairs.
But foremost, try plugging the TV directly into the wall. It could be that the socket or surge protector were fried, but your TV is ok.
May 06, 2011 | Insignia Flat Panel Televisions
No power on Samsung TV after storm
Hello Zkarim,
I'm very sorry to hear about your unfortunate new's. I had the same problem in my own home maybe a week ago.
Basically if your power flickered on and off at anytime during this storm then there was a power surge that probably fried your TV.
* First check the power where the tv was plugged in. Is it a power strip or a surge protector ? Surge protectors typically have an on/off switch and a separate reset push button.
If it is a power strip then the tv fried because there was nothing to stop it from happening (not even the fuse). If it was plugged into a surge protector then it could be quiet a few years old and not as reliable or the surge was to powerful for the limit on the surge protector.
The only thing you can do personally is send it in for repair if it's under warranty, if it is not then you can have it looked at by an authorized repair technician in your area. Troubleshooting should be fairly low, and you will at least be able to find out your options once they find the defected part.
Thank you for choosing Fixya!
Jul 15, 2009 | Samsung LE32A457 32 in. LCD TV
Screen froze during lightning storm. no picture now. When powering on screen lights and then dims - no picture, no sound
You might have had a power surge.Try unplugging your TV for 5 minutes and plugging it back in. If you cannot get a picture from any device such as a DVD player and cable then your TV needs serviced call a repair man. Good Luck!
Jul 14, 2009 | Panasonic Viera TH-50PZ80U Plasma TV
Flat Panel Televisions Logo
Top Flat Panel Televisions Experts
Are you a Flat Panel Television Expert? Answer questions, earn points and help others
