Samsung TXK2754 27" TV
Problem for Samsung TXK2754 27" TV
Power/timer light keeps flashes - green
By sctemp123 on May 15, 2009
power/timer light keeps flashes - green
Solution #1
posted on May 15, 2009
Not Rated)
ginko
Rank: Guru  Samsung Televisions & Videos  Expert
Rating: 89%, 5064 votes
The TV is on protect mode, this happens when a fault had been detected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here, a common fault is PSU, but part must be tested before replacement.
Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
Was this helpful?
Yes
No
Popular Solutions for Samsung TXK2754 27" TV
Questions and Unsolved Problems for Samsung TXK2754 27" TV
Do you recommend Samsung TXK2754 27" TV?
Answer
Answer
My Samsung txk2754 has alot of horizontal lines (white lines) what could be the problem
Answer
On one of the channels it blacks out and say's "Current Rating/Received RatingTV14/Excessive... (More)
Answer
I tried 0711 and that didn't work......does anyone else know how to do this?
Answer
Someone gave me the TV since my old one died.  Can't hook it up, just has "AV1"... (More)
Answer
hlo tv lcd acer basic schematic acer 3201
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Samsung TXK2754 27" TV:
Top Standard Television Experts
Rank: Guru Guru
Solutions: 745
Experience: 30 Years of professional repair and design.
Ask Me
Find more Standard Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
