Question about O2 Xda II mini
O2 ICE Hangs Very often
I have a O2 Ice phone that hangs frequently. Can anyone help me out on this. This phone is not even 20 days old
Just u have to do soft reset of u r handset or if u instole any third partysoftware remove that software
Posted on Oct 18, 2007
How to make cubes fuller
You have to adjust ice thickness sensor it hangs in front of the evaporator at the top it will be white with a 5/16 screw going through it to increase the thickness of ice turn clockwise no more than a 1/8" at a time then let it make a batch of ice. carefuller you don"t want to make the ice to thick this would cause ice to hang up on evaporator plate and could damage it.
Jul 10, 2014 | Scotsman Ice Maker CM3 30inW Cubed Ice...
Dispenses Ice..but not Water
I have found that when ice hangs up in the door causing the water line to freeze right at the very end of the water line. Remove the ice jam and apply cloth that has been wet with hot water to line for @ 20 sec. with a cup in place engage the water dispenser and please note that the ice plug may dislodge with force due to water pressure in the line.
Oct 28, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
BRANDNEW laptop hangs whilst - writing The Disc Recovery Back-Up
it should still be under warranty. if you bought if from dell.com they will send a service tech there 3 times to fix the issue if still not fixed after that they will at there discretion replace it. replacement takes 20-30 days to arrive (after the 3 service calls fail) Welcome to dell
Aug 06, 2009 | Computers & Internet
Ice won't fall through the shoot even though it is dispensed from the ice bucket. What can I do?
normaly there is an electromagnetic flap at the ice dispenser, where the ice falls thru. this is to keep the cold inside and the warm outside. i would guess that this flap either hangs (does not open), or the electromagnetic mechanism is not working as designed (maybe due to a lack of electric contact?).
Jun 04, 2009 | Kenmore 21.9 cu. ft. Side-By-Side...
My N72 mobile hangs frequently
hie dear,
its the software problem of ur cell. jst go to care centre or the cell repairing center and ask for change the software version of ur cell
bunty
May 03, 2009 | Nokia N72 Cellular Phone
Cracked screen o2 ice
HI,
the only way that you can fix it is to send your mobile to a service center and lt them change your screen with a new one.
thanks,
Apr 25, 2009 | O2 ICE Cellular Phone
Loud Buzzing Noise from Behind Freezer
Sounds like the freezer fan blade is hitting on a build up of ice or frost. You may have a defrost issue, or it may be a one time thing, like the door was open for a long time (object holding door partially open) or also check the ice dispenser duct door to make sure it is closing. Sometimes a chunk of ice hangs up in the ice shoot, allowing moist air to enter freezer, resulting in the extra frost / ice near the freezer fan. You might also check the door gaskets, especially the bottom side where sugary liquid spills might cause a gasket to tear. #2: Long run times: If cooling is good, don't worry. Older refrig's often ran less time, but used much more electricity than the newer refrig's, even though new one run longer. (Like having a 40 watt light bulb on for 20 hours a day uses less electricity than having a 100 watt bulb on for 10 hours a day)
Aug 27, 2008 | GE PFS22SBSSS Stainless Steel French Door...
O2 Ice
o2 ice restart problem
Sep 23, 2007 | O2 Xda II mini
Ice maker problem
I also have this problem.  The ice that was hanging, when looking in the freezer was the right side ice.  I just releveled the frig or increased the height of the side that was hanging causing the water to level.  It has cut down on the amount of ice or times the ice hangs.
Sep 17, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Computers & Internet Logo
65 people viewed this question
Top O2 Computers & Internet Experts
zurysk8
Level 1 Expert
xxxxxx xxx
Jax Planet
Jax Planet
Are you an O2 Computer and Internet Expert? Answer questions, earn points and help others
