Question about Westinghouse L2046NV Monitor
Nothing Happening I was given this monitor by our IT guy. Itook it home, plugged it up, and nothing happened. I have power, the correct connection cord, but the screen is completely dark. It was suggested that I download the driver. What's the problem here...?
    Problem Solver:
  • 16 Answers
If its like my 20v5 then it might be a power supply problem
http://www.fixya.com/support/t2576306-two_westinghouse_20v5_monitors_also_just
Posted on Nov 08, 2009
  • 1,684 Answers
It sounds like you have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of the monitor. If you are good at electronics repair/soldering you can usually fix the problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts,replace any that look like the pictures and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the new one the same way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
Posted on Jul 19, 2009
LG 42LC7D turns on ok but no display or sound,tried using monitor out with another tv but no picture either
Check to make sure you have the right input selected for the input that ou have plugged into.
Jan 20, 2013 | LG 42LC7D-UB Television
MY computer turns on but nothing registers on my monitor.
1. First thing to do,is to checked the connections of your monitor to your cpu,checked if it is plug correctly.And also checked the switcth of your monitor if it is ON.
2. If the first step is ok and did not function again,possible that there is a problem to your monitor,try to used another monitor to checked if there is a output or it functioning,if it is functioning then there is a problem to your monitor,better to look for a computer technician/or TV technician to troubleshoot it.
Hope this simple information could help you to solve your problem. Mam/Sir don't forget to rate me up I really appreciate what ratings will you given to me. Thanks a lot and God Bless.
Jul 15, 2011 | Computers & Internet
I just bought it off of craigslist hoping to fix
with nothing happening it is very possible the hard drive that needs replacing or is missing
Mar 24, 2017 | Gateway CX2610 Notebook
My monitor was working fine but now it won't turn on. Nothing was happening when it suddenly went off.The light is also not on and I have tried a few different power cables and plugs. It is an acer monitor...
Nost failures are due to bad caps.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Apr 24, 2010 | Acer AL2017 20" LCD Monitor
My laptop NC6120 hp screen is black I can see nothing help plz
Try pressing Fn + F4 and see if it comes up.
If so, you need to update to the most recent service pack to correct this error.
another possibility: click here
see also here
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
May 04, 2009 | HP NC6120 Pro Notebook
Korg Triton Le keyboard not working
Hello! My Triton LE did that yesterday at rehearsal room. It came on twice (by turning it off and on every time the error message appeared), I could play the auditions and demos but when i hit the keys i heard nothing.
Soon after I went home (still with sweat on my forehead and my heart pumping like a pneumatic drill) I connected it and everything was working like nothing ever happened!
So guys, everybody who has the same problem: Don´t panic! I think for me, the power plug at the rehearsal room had a problem. Who thinks of that? Nobody... So check your keyboard on another power plug...If you can, try it in a friends house. Or check your house plugs.
I assume if the Keyboard doesn´t get enough power, the error message appears. Hope that Helps!
Apr 23, 2009 | Korg TR76 76 Key Synthesizer Workstation
Computer turns on but nothing happens
your monitor should have nothing to do with the internet
Are your internet lights on
Have you moved the system maybe causing something to become loose.
Is the monitor plugged into the wall correctly and into pc correctly
can ypou hear windows starting up or does everything just go black
Dec 15, 2008 | Dell Vostro 1500 Notebook
Dell e193fp monitor
Have you made sure the laptop is outputting the the monitor? Does the monitor have dual inputs? if so check it is switched to the correct one. With the laptop turned on and connected, switch the monitor on and off.
good luck
fridge
May 17, 2008 | Dell E193FP 19" LCD Monitor
NO POWER AT ALL!
Does the power supply have its own power switch?
It is located next to where the power wire plugs into the back of the PC.
Jan 10, 2008 | E-Machines eMachines Desktop PC
No power
Did you find out what was wrong with your monitor?
Dec 09, 2007 | Dell E171FPb 17" Flat Panel LCD Monitor
Westinghouse L2046NV Monitor Logo
272 people viewed this question
Top Westinghouse Computers & Internet Experts
Jim Goldsmith
Jim Goldsmith
Dudeman321
Are you a Westinghouse Computer and Internet Expert? Answer questions, earn points and help others
