Question about Plumb Pak Continuous Waste Center Outlet, 1 1/2" x 16"
Installing a new waste outlet hose
We are trying to replace our old waste outlet hose as old one had a hole due to rubbing during rinse and spin cycles. Can anyone talk us through this process? We have bought a universal hose that can be fitted to all washing machines. Our machine is a FP smart drive excellence 6.5.
  • Leslie Looman
    Leslie Looman May 11, 2010
    will need model # please...thank you
  • 15,935 Answers
You will have to remove the outer shell to access the pump.
Remove the clamp from the outlet side.
Install is the reverse.
Thanks
Posted on Jul 13, 2009
  • blueextc3221
    blueextc3221 Jul 13, 2009
    Thanks
KitchenAid KBFS22EWMS4 less than a year old. Have repaired water hose twice ourselves and when another leak occurred we called repairman who replaced the entire hose saying the delivery people may have run...
Check the entire length of the hose to see if it has been rubbing on something. When the machines spin parts inside if not secured move around a lot and there are many sharp pieces inside the machines.
Dec 31, 2012 | Washing Machines
Washer is leaking during rinse/spin cycle
What is the model number of your unit?
Nov 23, 2012 | Washing Machines
Fisher & Paykel GW712 Leaking large amounts of water during rinse and spin cycles. Have looked underneath and noticed the pump is slightly corroded, outlet hose is OK with no cracks, hose clamp OK, but...
hi - I have often come across defective hoses further up along the sides of the machines - a result usually from constant rubbing onto the frame work amongst others.
The design would indicate other defects if present - if the air vaccum breather for level control or the hose defective it will have overfill amongst others - constant leak on to the floor through out the cycle - same would apply to a crack in the outer bowl - pump errors would show up if that's faulty.
Have found duct tape effective for these minor issues - the cost of replacements could be horrendous if a serviceman was to replace the harness..
Cheers
Jul 12, 2011 | Washing Machines
Puddling on floor during high speed spin cycle
you have a leak in your outlet hose normally caused by rubbing on the drum barrel / repair with tape or replace whole hose but this brand of wASHER ITS VERY HARD TO REPLACE IF DONT KNOW HOW TO
Apr 27, 2010 | Fisher and Paykel GWL11 Top Load Washer
Washer smokes during rinse cycle. With clothes out of it, only the rinse cycle works. Breaker pops when trying to run a cycle with clothes in it. Water also does not drain
1. This could be due to a belt that is loose or if this is a "direct drive" motor then the bearings are gone and the motor need replacement.
2. There could be leakage ( water) from the pump hose spaying the motor and causing vapor.
3. There may be a exposed wire from vibration rub during the "spin" cycle and is grounding against the enclosure.
These are just a few scenarios that could be.
The unit will have to be open by a trained technician to give full disclosure of this issue.
I hope this helps. Have great day!
Mar 19, 2010 | Maytag Dependable Clean Top Load Washer,...
Agitator won't spin during wash/rinse cycle. It's
There could be several reasons for washer not to fill .Fill washer with water and wait for the timer to get to the drain mode.Unplug the washer from the electric outlet.Open the case, and disconnect the water hose from the outlet of the water pump.If you get water pouring out from the pump, then plug that up and check the hose to the sewer. If that is clogged, then you have found the problem.Some washers have a self cleaning filter in that hose somewhere. Check that to be sure it is working properly.Reassemble hose from step 3.Plug washer back in. If it pumps out now, then you are done. If it doesn't, then the water pump is probably defective, so replace it.
Thanks for contacting Fixya.com
Nov 03, 2009 | Washing Machines
When rinsing/spinning the water comes out of the dispenser drawer
I see this is under the dryer section, i am assuming its a washing machine or washer dryer.
If its leaking from the dispenser during the filling stage, this could be a blockage in the dispenser or as simple as the water pressure is too high,
If it leaks during the spin on the rinse cycle, this is generally a blockage on the outlet area (normally the sump hose/filter) remove the filter if fitted and check for blockages, if ther is no filter on this appliance, you will need to check the sump hose, this is located under the machine, mormally a black hose from the tank to the drain pump, remove from the tank end and look in there, Finally it could be a blockage at the end of the waste hose (grey one) it quite often gets blocked at the sink end.
Hope this helps.
Regards
Sussex engineer
Please rate my help. Thanks
Oct 22, 2009 | Hotpoint Dryers
GE toploader Washing Machine pumping problems
Sounds like the water is syphoning away due to the drain outlet hose being too low..Raise the hose higher, and this should solve the poroblem.
Oct 31, 2008 | Hotpoint Aquarius WMA42 Front Load Washer
WD640 Aquarious supersilent washer/dryer leaking from powder draw
during the rinse the machine uses a higher level of water, therefore check the door seal for holes,if the water is leaking from the soap drawer in the spin then this suggests that you may have a blockage in the outlet hose or in the sump filter, to check the filter remove the sump hose, the filter is hidden in the hose. Regards Engineer
Jul 29, 2007 | Hotpoint Aquarius WD63 Front Load...
MACHINE DOESN'T CYCLE OUT OF RINSE
Does it spin if you move the timer manually? ist it being used on a delicate cycle@? if so it will stop in the last rinse water
Jul 10, 2007 | Ariston Technologies AWD 121
Plumb Pak Continuous Waste Center Outlet, 1 1/2" x 16" Logo
91 people viewed this question
Top Plumb Pak Plumbing Experts
Tom Chichester
Paul Carew
Are you a Plumb Pak Plumbing Expert? Answer questions, earn points and help others
