Question about Soleus MW-59
My Soleus AIr Hot/Cold Water dispenser model MW593663404 will not turn on
  • 263 Answers
SOURCE: Cold water freeze
you have to lower the termostat because is freezing the the cold water duct that happens when is cold or winter
Posted on Jan 01, 2008
SOURCE: Kenmore Side by Side Refrigerator - ice/water dispenser
The water will not dispense, its worked since we moved in but last night it just stopped working.
Posted on Apr 16, 2008
SOURCE: Sunbeam water dispenser Model YLR2-5-90HZ3 Ser# 2003
water leak from inside the refrigerator
Posted on Jul 16, 2008
SOURCE: Sunbeam Model YLR2-5-90HZ3 hot/cold water dispenser w fridge
HOW CAN I REPLACE THE PART MINE IS DRIPPING WATER CONSTANTLY.
Posted on Nov 15, 2008
SOURCE: sunbeam cold and hot water dispenser
I called a bunch of different numbers and finally found the people who can help with this. It's called Elite Group (877-383-6399) - I guess they're the ones licensing the Sunbeam name and making these water coolers. If you call that number with the model number, they'll replace the "top" part of the cooler, which should also have new taps, the lady said. The cost is $13.35
Posted on May 05, 2009
Hot water not dispensing
I ve glacier bay hot/ cold water dispenser - new product. Cold water is coming but no hot water. Water is not coming. What have I to do it is a week old machine.
Nov 20, 2013 | Vitapur Water Dispenser. Hot, Room and...
Sunbeam hot/cold water dispenser is leaking from looks like copper tubing that goes to tank. Model # ylr-5-87h3 what could my problem be
Broken solder connection.
Continual expansion and contraction of metal due to hot and cold extremes will cause metal fatigue. The most vulnerable place is at the join. Other places can fail, but usually the solder join will fail first.
Buy another one and support economy.
Make sure next unit is connected to cold water line, and not hot water line. If hot water dispenser is connected to Hot line, then it will cause water heater to run each time water is drawn through dispenser because cold water immediately enters tank.
http://waterheatertimer.org/Water-heater-dip-tube.html
http://waterheatertimer.org/How-to-install-under-counter-water-heater.html#h-c
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html#pot
You might also consider installing small tank under counter. Tanks are less glamorous than hot water dispensers but tanks are more reliable long term than instantaneous water heaters.
May 28, 2013 | Water Heaters
SOLEUS KFHHP-22 - Heater doesn't blow air at all, warm or cold. Cooling works great but no heat.
Doesn't matter how hot it was when installed, there still should have been proper start up performed. That means running unit thru all cycles and checking charge. If it was installed this summer then installer should warranty service to return and complete install properly.
Nov 15, 2012 | Soleus Air KFHHP-22 22000 BTU Mini Split...
I have a PUR 200 water filter/hot and cold dispenser and the cold
I have the same problem as both stated earlier. The cold water is not working and the night light does not work.
Jan 21, 2009 | PUR Air Purifiers
Model YLR2-5-90HZ3 cold/hot/water dispnser with fridge won't heat
I have the YLR2-5-96H2 and hot water stopped heating up. I unscrewed the casing and unplugged the connections to the circular heating element and 2 circular probes. Brushed off the white dust build up on the probes and it started to heat water again. I ruled out faulty heating element, because it got really hot just seconds after turning on the hot water switch.
Dec 18, 2008 | Whynter FX-6SB Free Standing Hot & Cold...
Oct 05, 2008 | Whynter FX-6SB Free Standing Hot & Cold...
Cold water knob
http://www.soleusair.com/Consumer/menus/Water%20cooler/MW-59-manual-101105.pdf
call 1-888-876-5387
Or Write To:
Soleus International Inc.
9451 Telstar Ave.
El Monte, CA 91731 USA
hope that helps.
Jun 30, 2008 | Soleus MW-55
Cold water freeze
Jan 01, 2008 | Soleus MW-55
Soleus MW-59 Logo
51 people viewed this question
Top Soleus Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Soleus Refrigerator Expert? Answer questions, earn points and help others
