Question about Garden
Belts slipping and breaking
MTD Yardman tractor drive belts keep slipping off and burning up. I replaced the variable speed pulley and belts, but the new belts only last about a month. All parts have been purchased from the manufacturer.
  • 86 Answers
If you are putting on the mtd belts and installing them right then you need to check bearings in variable speed pulley Also check idler and that no other pulley has been bent from installation.
Posted on May 16, 2009
I just replaced the drive belt on my Troy built auto transmission Bronco 42" riding mower, and now it goes a lot slower. The belt seems to be routed correctly
The bronco is a variable speed mower from what I remember. There is a belt that goes from the crankshaft to a variable speed pulley and another belt from the variable to the transmission. If your 1st belt is too long it will never get up to speed. Do you have to push the pedal down further now than before to get it to move. ? If so your main belt is too long.
Jun 05, 2011 | Mtd Drive Belt 42"
Riding Mower Variable Speed Pulley Locked Up. How to remove belts
ya it can be freed up with some W-D40 if you pah the cluch down then try to get the belt off i can get you a new pulley let me know
Oct 15, 2009 | Mtd Garden
The drive belt on my 42 inch yardman tractor is
Once a belt has slipped to the point of "smoking" it is time to replace it. It will have a worn spot on it that will cause a vibration throughout your entire tractor when you are driving in addition to being weak at the burned point
Sep 16, 2009 | Garden
Transmission belt came off the pulley how do i get it back on?
Remove the shifter knob, 2 screws and wire for safety switch from the center plate on the tractor. This will give you access to the variable speed pulley and limited access to the transmission pulley. Reach in under the seat area toward the transmission and "feel" for the pulley, slip the new belt on there first but check to make sure you are inside any belt guards. Next you want to get the belt on the top groove of the variable speed pulley (you may need to remove the belt guide or POSSIBLY bend it just far enough to get the belt on then bend it back in place. Lastly, you need to get the back side of the belt against the flat surface on the tensioner pulley in between the transmission and variable speed pulleys. This is a very stout spring and takes some effort to do but I lift up on the edge of the belt with one hand just enough to clear it and pull the tensioner pulley over with the other hand.
You can Google " MTD 13al675g062 " without the quote marks and it will give you a pretty clear picture of it
Sep 13, 2009 | Garden
HOW MUCH TENSION SHOULD I PUT ON THE BOLT AND NUT THAT HOLDS THE VARIABLE SPEED PULLEY ON A MTD YARDMAN.? KEEPS THROWING BELT AND WON'T SPEED UP. HARD TO PUSH PEDAL THEN BELT FLIES OFF. MODEL 604G THANK...
The bolt should be tightened to a hundred lbs. make sure the center pulley is free to move up and down, and you ahve the right belts. Avoud belts from Lowes or Home Depot od Wally world, They NEVER fit right
Sep 07, 2009 | Mtd Products Yard Machines 158CC Tiller
MTD 12-38 Shifting problem
mtd 12/38 blads not stoping ? theres a ajustment rod on right side under the mower turn clockwise to losen belt .
Jul 09, 2009 | Mtd Garden
MTD Lawn Tractor problem
The front belt should be a 954-0280A, rear 954-0370. When you go to higher gears, the front belt should be getting tighter as the vari-speed pulley is moving further back. Remove the shift plate, put the transmission in neutral. Start the engine, put speed selector in highest gear and slowly let out on the clutch. You should be able to see what the problem is. It will do everything the same as if were in gear, except move. Make sure you have the correct belts.
Jun 28, 2009 | Mtd LAWN MOWER PART # 753-0698 KIT-DECK...
My transmission belt slipped on my yardman mtd 42'' garden tractor. How do I relieve the tension on pulleys to slip it back on?
the tension on rear end you can jack it up in the rear & spin the right tire to get it back on & make sure the brake isn't on
Jun 13, 2009 | Garden
Ground speed slows under pull at high variable speed settings.
Take off the plate around the shift lever between your legs and take a look at the belts. Most likely they will be in poor condition. You can even leave the trans in neutral, start the engine and move the speed selector through the gears and observe the belts in action. They do the same in neutral as in gear when you let out the clutch with the engine running. You should be able to see what the problem is, It will either be one or both of the belts or possibly the needle bearings in the vari-speed pulley itself,
Jun 01, 2009 | Mtd Garden
Variable speed belt issue
Get your model and serial numbers from under the seat. Then go to the MTD website where you can download the owners manual which should show the belt diagram.
May 24, 2009 | Mtd Garden
Garden Logo
937 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
