SOURCE: need a club car golf cart service manual
generic suggestion
http://www.blockbustergolfcarts.com/index.asp?Category=260&PageAction=VIEWCATS
http://www.lvssales.com/store/product.php?productid=13300
SOURCE: need battery wiring diagram for 1987 ezgo golf cart
Tell me what cart you have and i can help. Not all carts get wired up the same way as this link demonstrates. In the pix pay close attention to how battery one gets hooked up as this sets the pattern
http://www.updateyourdriver.com/driver/?t202id=211793&t202kw=webcam&gclid=COTM4t-ZsJwCFQxM5QodWjoflQ
SOURCE: Electric Golf cart only shutters and inches forward
so many possibilities...
does it roll fairly freely? (checking to see if the brakes or rearend seized up)
Are there any "bad" sounds like things grinding? (Connection between Motor and rearend, axle splines...)
If all that is solid, it is likely in the controller.... (it takes a solid charge right... No bad batteries in there or loose connection? might want to check all the battery connections to make sure none are burnt...)
1997.. does it have the electonic speed control by that year? the other possibilty is that the accelerator is not working corectly. they used a resistor system on old ones that has contactors that would get worn out.... Newer ones control a potentiometer(sp) that controlled the speed.
Only a few real components to check, but if you are not mechanically and electically inclined, could be tough to isolate.
peace,
SOURCE: I heard a scrubbing sound comming from the left
Check your rear wheel unit for bearings or break problems.
SOURCE: I need a wiring diagram for a 1986 ezgo golf cart,
use this link http://www.vintagegolfcartparts.com/cgi-bin/gallery/gallery.cgi?func=show&file=200332&Category=100013&Page=1
INTERMITANT WORK, THEN NO WORK, WON'T CHARGE
