Question about Maytag MMV4205 Microwave Oven
Maytag MMV4205BA microwave buzz/grind when operating then no power
I have a Maytag MMV4205BA microwave. Today when I was trying to cook some oatmeal, I pressed start on the control panel and stepped away for a second. Next thing I hear is a buzzing/grinding noise and then the microwave just died. This had happened a couple of days before and we readjusted the turntable glass and that seemed to solve it. The outlet works and the breaker wasn't blown. My husband has the microwave open now and we do have a blown fuse -- but no idea what caused it. Help!
  • mdavis93950 May 20, 2009
    I had the same sound and a friend whi is an installer replaced the fuse and heard the sound also and the oven stopped. He said it was the magnI atron, which is covered under a 5 year warranty. I contacted Maytag and the repair shop that they use said over the phine it may be something elsa and when he came out said it was the transformer. He did not replace the fuse and try to operate it. They charged a fee and gave an estimate that was more than the oven is worth. I'm feeling taken advantage of, Could the problem be the transformer?
  • klr3803 May 20, 2009
    I have had the same problem is the past, however, the most recent incident resulted in a total failure complete with an electrical burn smell. My applicance has only been in use for 1 year 8 months. I had it installed professionally on a dedicated electrical circuit and needless to say, I am disheartened to see other complaints of a similar nature! Will I buy a Maytag product again? Double It!
    Sergeant:
    Champion:
  • 214 Answers
You may have some arching inside where your magnatron is located.If you open the door on the right middle part there is a silverplate on the wall .If it is burned you may need to replace magnatron.if you do not seee burn marks it may still be the magnatron hope.that would be the only possible thing that would make the noise other then the mtor plate out of place.
Posted on May 15, 2009
Hi. Our 1 1/2 year old Sharp KB6524PS Microwave Drawer: While cooking oatmeal, at start of cycle, the microwave started arcing, then smoking. Shut off at 15 seconds. Microwave-safe china used.
I expect the arcing came from the waveguide cover or aerial cover having either a crack or carbonised food particles on it.
A new cover may affect a cure if the magnetron is not damaged.
Aug 18, 2017 | Sharp Microwave Ovens
How do I cook oatmeal in my goldstar microwave?
Heat water to boiling, instead of heating the oatmeal for instant oatmeal. Add heated water to panel and cover bowl to maximize steam effect.
Feb 05, 2015 | Goldstar Microwave Ovens
I have a Maytag mmv4205ba microwave. I turned it on, and it ran for about 2 seconds, then made a surging sound, and died. I replaced the fuses today, and the power came back. But when I tested it, it...
It may be a shorting high voltage capacitor, but may also be a bad magnetron or high voltage transformer.
Here are some links you
or someone you know can use for test help, but read their safety
warnings first:
http://www.microtechfactoryservice.com/diode.html
(if it\'s not shorted or burned, it\'s
probably okay)
http://www.microtechfactoryservice.com/cap_test.html
http://www.microtechfactoryservice.com/mag_test.html
http://www.microtechfactoryservice.com/xformer.html
You can find
helpful exploded view diagrams and order parts by entering your full
model number from the tag on the oven
here.
We\'re
happy
to help you with free advice and we\'d appreciate your thoughtful rating
of our answer.
Oct 07, 2011 | Maytag MMV4205 Microwave Oven
May microwave Oven Model MMV4205BA won't heet
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Aug 10, 2011 | Maytag Microwave Ovens
Microwaver not heating,my # is mmv4205ba
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Dec 29, 2010 | Maytag MMV4205 Microwave Oven
The microwave wont respond to the timer. It keeps cooking unless you open the door. After the timer runs out it seems like it cuts off but there is still a low buzzing sound and it is still cooking. Have...
low buzzing can be a power relay or a (solid-state)
triac which both supply power in their own right to the power transformer to operate the magnetron tube,even though you say it quits cooking when you open the door,i would still check the micro-switches in the door for proper alignment and operation, because it can be a door switch mis-alignment or a leaking triac still supplying power to the unit
Jul 14, 2010 | Kenmore Microwave Ovens
Kenmore 721.80524500 makes a buzzing, grinding noise
Your problem is due to the "magnetron" arcing to the wave guide within the microwave. Picture someone arc-welding stuff together inside the microwave casing, that's essentially what's happening. It is a fire hazard and you should stop using the microwave immediately. As far as I know, there isn't a recall on that particular model (though there was on another similar Kenmore/Whirlpool model) so if it's out of warranty, you're out of luck.
Sep 08, 2008 | Kenmore 63662 / 63664 / 63669 Microwave...
Maytag MMV4205BA internal fan quits
As promised, here is your solution information:
You can download Maytag owner's manuals, installation instructions, and parts lists here.
You can find the service manual (which may not have a parts list) by selecting Literature by Model on this page and entering your exact model number with suffix. (Also try it without suffix if you have trouble).
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
You need all three of those documents in some cases.
Finally, you can find helpful exploded view diagrams and order parts by entering your full model number here.
At our site, we now have a video available showing how to remove a typical control panel assembly in under 5 minutes.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Aug 28, 2008 | Maytag MMV4205 Microwave Oven
Maytag microwave - mod# mmv5100aaw
CHECK MAGNETRON RELATED CIRCUIT, HIGH VOLTAGE CIRCUIT, CONTROL CIRCUIT,AFTER CHECK MAINS FUSE.
Aug 29, 2007 | Maytag MMV1153A Microwave Oven
Microwave makes loud buzzing sound when on and no heat
Have you tried putting a cup of water in it and cooking on a low power level? If it buzzes only when it is on the cook cycle, that would narrow it down. More detals might help us help you, including the model number.
Mar 20, 2007 | Kenmore 62622 Microwave Oven
Maytag MMV4205 Microwave Oven Logo
904 people viewed this question
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
