Question about Maytag MER5765RAW / MER5765RAQ / MER5765RAB Electric Kitchen Range
Glass is shattered to to replace
Glass top is shattered
  • Maytag Master
  • 19,396 Answers
To replace the door glass do the following:
1 remove the oven door by pulling it up and removing from the the hinges. If glass is broken , then secure glass with tape. Have a table with a cloth on top ready to lay the door.
2 Remove the outer screws , starting from lower side of the panel.
3Remove the inner screws. Keep all set of screws ordered, and take noteof the order you remove them. You will follow reverse order inreassembly.
4 the frame will be free now,
5 Remove the external glass panel and leave it in a safe place.
6 Replace the inner glass.
7 Clean outer glass and metal door, re-assemble it and mount it back
See diagram below , click on picture to enlarge:
glass is shattered to to replace - dd5ebd3.gifclick here
Inner Door Glass
Posted on May 15, 2009
4 Suggested Answers
jsrock516
  • 5911 Answers
SOURCE: shattered glass top for Hotpoint range/ how to replace
The cook top on your range should come off by removing 2 to 3 screws under the front edge of the cook top. You will need to open the oven door to see them. Once you have them removed the top should lift up. Please ensure you have the range unplugged and/or the circuit breaker turned off before attempting any repairs to the heating elements. Live voltages are still present with the unit turned off. Now...depending on the type and model of your range, the wiring harness may have a quick disconnect type of plug. If yours is so equipped, replacing the top will be a cinch, because you can remove it from the range to work on it. Take the old top and new top and place them next to each other upside down on a padded surface. Placing some towels on a kitchen table or counter top works best. Now all you have to do is carefully transfer the entire harness and burner elements to the new cook top. You should be able to move the entire assembly with all the burners still connected. A second set of hands will make the process go much easier. If your range does not have the quick disconnect type of wiring harness have someone hold the cook top up or prop it up with something. Carefully remove the element mounting brackets from the cook top (with all the elements still attached). Carefully support all the wires as you do so, and lay the entire assembly (elements and wires) on top of the oven cavity insulation. Once you have everything disconnected from the cook top, discard the old one and position the new one in place. Carefully reinstall the elements while supporting the wires. Additional care should noted not to handle the ceramic material of the elements and/or the heat coils themselves. They are very fragile and the oil from your hands can potentially damage the elements and shorten the life of them. Let me know if this helpful to you. If you get stuck along the way, or have any questions, please respond to this posting by adding additional comments.
Posted on Sep 10, 2007
SOURCE: Replacement of glass top
Just a note when you're doing this... when you open up the top, put a towel across each side so that when you drop a clip, it doesn't go down the side between the oven and the outside wall. If it does, hope that it goes all the way to the bottom where you can get at it by removing the bottom drawer. If you put the towel all the way across the oven box before you start taking things apart, you also won't have to worry about where little tiny screws go when you drop them... and, you will drop them! ;-)
Also, the old tops had a reinforcement bar that the ground was attached to. The new ones don't. There's a tiny hole on the flange of one of the right hand burner holes... that's where the ground is supposed to go on the new top. You WILL need a smaller self tapping screw than the original one.
And, forget having a helper... get something to prop the lid open with that won't fall if you raise the lid a little while you're working on it. Helper will just get in the way and can't hold it still enough while you''re trying to man handle those tiny little clips and screws that hold the burners in place.
--Jeff Moden
Posted on Oct 25, 2008
SOURCE: I need to replace the glass cooktop on my Maytag electric stove
  1. Open oven door and remove two screws that secure top.
  2. Lift up front and slide forward about 8 inches so that you can disconnect two wire couplings.
  3. Place on table upside down(I put newspaper down to catch the broken shards of glass) and remove burner unit (1piece, 4 screws).
  4. Place old burners on new stovetop in the same position as original.
  5. Remove 4 white plastic shims (round) from old stovetop and put on new stovetop.
  6. Tighten all screws and then sit it back on stove (two front tabs fit into slots) and then insert screws into holes and tighten.
  7. Took about 20 minutes, including vacuuming broken glass from inside burners and cleaning grease form crevices between burners and old stovetop.
  8. Wrap old stovetop in the newspapers that are underneath it and place it all in a plastic garbage bag to avoid any broken glass from falling out.
Posted on Jan 26, 2010
I've got a rattan Outsunny cube patio set. My glass on the table shattered in the hot weather and I've been trying to get in touch with Outsunny to complain about it. Can you help me please.
Armoured glass is used for table tops, oven tops etc. To get the glass to break/shatter, it requires temperatures exceeding 200 degrees Centigrade and then cooled quickly in one spot or something has been dropped on it.
Jul 12, 2017 | Ovens
My kenmore elite washer keeps giving me the LE error
Kenmore elite 700 series triple action technology glass top load 5.3 cu ft.washer glass lid is shattered..can I replace the glass only or do I have to replace the whole lid top?
Mar 16, 2017 | Kenmore Washing Machines
Why did the glass in microwave door shatter melt?
A spoon in the coffee the cup had metal parts
Feb 20, 2015 | Frigidaire Microwave Ovens
Glass top on my Kenmore oven shattered- is t repairabe
Probably cheaper to replace whole oven try insurance if u have its an accident so insurance may pay if u have.
Oct 16, 2014 | Kenmore Ovens
Glass stove top shattered
yes it can be repaced but they are not cheap may costv a few hunderd dollars thanks from gilles
Mar 15, 2009 | Frigidaire FEF366 Electric Kitchen Range
TKC 8522/2 top oven outer door shattering
It is not a fault with the door, and this sort of event occurs quite often, so is not uncommon.
All sorts of things can cause this, sudden change in temp, getting the glass wet whilst it is still hot, a knock or bang form an earlier time could have weakened the glass.
The list is quite long..
Depending on your household insurance, some policys cover for breakage of glass fittings, would be worth checking.
Plz rate my solution
.Thanks.
Dec 30, 2008 | Tecnik TKC8522 Electric Double Oven
Oven door outer glass shattered
will need a model number to tell you the correct price ... most will have to replace the door... you can also give sears a call .. if you gripe loud ... they may replace it for you...
Sep 28, 2008 | Ovens
Whirlpool glass top stove
The glass top can be change, but be aware that if you have all your cooking element fixed togetter, this could cost plenty of $$$. If your heating element can be remove easyly, you are a lucky owner.
Dec 10, 2007 | Whirlpool ED2FHEXN Side by Side...
Maytag MER5765RAW / MER5765RAQ / MER5765RAB Electric Kitchen Range Logo
672 people viewed this question
Top Maytag Kitchen Ranges Experts
Lawrence Oravetz
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
