Question about Microsoft Office Professional 2007 Full Version for PC
When in games it so slow
I bought 2 Gbyte Ram , 2 Gbyte of hard disk , and 2mg Hz Processor but still when i use it in Games it so slow.
  • Sphynkter
    Sphynkter May 11, 2010
    what kind of computer do you have, and what game are you trying to play?
Format ur hard disk or games might b corrupt
Posted on May 18, 2009
JEWEL QUEST 2 FREEZES IN WIN 7
Make sure that your system meets minimum requirement for playing it. Game may freeze due to less available hard disk, low capacity RAM and processor. So I would suggest you to follow these simple tips to avoid your games from freezing:-
- Disinfect your system using some reliable antivirus program.
- Upgrade hardware (RAM, CPU, graphics card, etc.)
- Uninstall unnecessary programs (Games, crapware, toolbars, etc.)
- Click Start> 'Run' Type msconfig > Enter > Start Up. Uncheck the boxes for the programs that you think you may not use often.
- Clean all the junk files, registry errors and all the cache (Must use reliable program like I always use RegInOut for it.)
Thank You :-)
Jan 19, 2014 | Video Game Consoles & Games
Game freezes
- Clean all the junk files, registry errors and all the cache (Must use reliable program like I always use PCFresher for it.)
Thank You :-)
Nov 08, 2013 | Square Enix Kingdom Hearts II for...
My pc is very low.I need fix
Slow PC does not mean it has problem only with motherboard. Speed of the PC also depend on the following factors :
  1. Processor
  2. RAM
  3. Virtual memory
  4. Operatin system
  5. Video graphics card
To fix the problem you should first check which type of processor is used in you PC. Is it pentium4, Dual core, Core 2 duo or core 2 quad ? Core 2 quad is much faster if used with 4 GB RAM. RAM is also the cause to slow the PC. If you are using less RAM automatically your PC will be slow. So use RAM higher i.e 2 GB or more.
Virtual memory does not have much impact on speed but it is also a factor to slow down the PC. But if you can correct any of the three parts then no need to check virtual memory.
If you are using operating system like Vista then computer may be slow. Instead use XP professional, Windows 7.
If your PC doesn't have graphics card then it will be slow while playing games, watching videos. So if you are a game lover then change your graphics card with higher value such as 2 GB or more.
If you will fix these problems then you can speed up your PC
May 29, 2011 | Computers & Internet
Computer runs slow on some games HELP!!!!
In order to play RollerCoaster Tycoon® 3, you will need a PC running Windows with the following minimum requirements.
Minimum and recommended computer specifications are as follows:
Operating System: Windows® 98/Me/2000/XP (Windows® XP recommended)
Processor: Pentium® III 733 MHz or compatible (Pentium® 4 1.2 GHz or compatible recommended)
Memory: 128 MB RAM; 256 MB for XP (256 MB; 384 MB for XP recommended)
Hard Disk Space: 600 MB free CD-ROM Drive: 4X CD-ROM or faster (8X or faster recommended)
Video: Any ATI Radeon™ or GeForce™ 2 with 32MB or higher; or other video card with 32MB and hardware T&L (ATI Radeon™ 64 MB SDR or GeForce™ 2 Pro or other video card with 64 MB or more memory and hardware T&L recommended)*
Sound: Windows® 98/Me/2000/XP-compatible 16-bit sound card*
DirectX®: DirectX® version 9 (included) or higher
Apr 06, 2010 | Computers & Internet
Laptop slow in playing facebook games
This is such a small laptop that it comes with a very weak processor. The games make the processor work hard to display the images properly so that is your problem. You may want to consider returning the laptop and buying a better one. If you're in the Washington DC area I can help you choose a laptop that does what you need. I work with Dell and HP.
Nov 03, 2009 | Acer Aspire One PC Notebook
I have Geforce Fx5200 128mb pixel shadder 2.0 and i cant run crysis, call of duty 4 is there any way to run these games ?
Yes with a better graphics card. You need Shader 4.0 at least on that graphics card. (Plus a lot more Stream Processors)
The GeForce FX 5200 is an AGP style of graphics card, and uses 8X speed. (0.8 Volts)
It is a Budget graphics card, and does not have the graphics 'power' needed for the games you stated.
(If memory serves it has 16 Stream Processors)
There is no 'miracle' program, or tweaking of settings, that will allow you to run the above stated games at a decent capability. Even at low settings for the games.
I would suggest an ATI HD Radeon 3850 at least.
HOWEVER, other things come into play.
You need a 400 Watt power supply that has 30 Amps on the 12 volt power rail. The power supply must have a 2x4 power cable. (Example:
http://www.playtool.com/pages/psuconnectors/connectors.html#eps4plus4 )
OR, enough 4-pin Molex power cables that are unused to put in a 2x4 power cable adapter.
Your processor has have the processing power needed also, or you will have a 'bottleneck' of graphics information.
A graphics card has it's own processor. (GPU. Graphics Processing Unit)
It also has it's own Ram Memory. (Graphics ram memory)
However if the processor is too slow, the graphics information cannot be processed from the processor to the game program, and vice-versa, in a speedily fashion.
Graphics information, (Data), hangs up. Frames freeze, and frame rate slows down.
Post the computer name , model name. and model number, and we'll see if a better graphics card will help.
(Example: HP Pavilion D5200t)
Sep 24, 2009 | Computers & Internet
Lenovo n500 3000 display driver problem?
Other than RAM there are also other things to be considered to be able to experience great gaming experience. Commonly the slow and laggy experience are due to insufficient RAM, low video memory, internet connction if your playing online,disk space and processor. And no its nor a driver issue. The best way is to solve this is to check the recommended "system requirements" of the games your playing. If all requirements are met i'm pretty sure you'll be able to play games smoothly. good luck!
Aug 24, 2009 | Lenovo 3000 N500 Notebook
Games run slowwwwwwww on new emachine
check you RAM amount processor and graphics card. and check the requirements of the game.
Apr 17, 2009 | eMachines ET1161-03 PC Desktop
Slow running games
Hi clean your hard disk thoroughly by formatting it more than once and reinstall the OS and drivers afresh . The Processor nor the Ram or any of the components in computers only get burnt out , they never get degraded slowly so if game was running well before it was because of clean install without the presence of virus or malware.
May 24, 2008 | Intel D915GAV Motherboard
Should I get a new cpu for dell dimension 3000?
HII MARLBOROMANZ ,
YEAH THE PROCESSOR IS BIT SLOW FOR GAMES TO RUN PROPERLY.
I WOULD SUGGEST U TO BUY MOTHERBOARD THATS INTEL 965G AND CORE2DUO PROCESSOR.
U DONT NEED TO UPFRADE THE RAM AND VIDEO CARD U CAN USE THEM IN NEWLY UPGRADED MOTHERBOAD AND PROCESSOR.
I AM SURE U WILL ENJOY GAMES IF U UPGRADE ONLY OTHERBOARD AND PROCESSOR.REST ALL IS FINE.
Nov 03, 2007 | Dell Dimension 3000 PC Desktop
Microsoft Office Professional 2007 Full Version for PC Logo
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
