Question about Zio Corporation CameraMate ProPix OnTV for PC
CD Burning Having installed Propix on TV it all seems to be ok until I try to copy to disc and then I only have the virtual copier to choose from. It doesn't list my cd copier.
0 characters
1 Points
How do I install Roxio cd-dvd burning from a disc
Load the disc and should automatically go to "SETUP" if not them open the fiel manager and search that drive for "SETUP"
Jan 28, 2015 | Roxio Easy CD & DVD Burning for PC
Unable to burn discs using Corel Video Studio X2. Program all OK until final phase of burning. Using Windows 7 on new PC. Could problem be Windows 7? Any help appreciated.
Make sure that you have all the patches installed from Corel's site, there is a known issue that the buttons will not show up on Windows 7 unless you have the latest patch.
If you have all the update installed there could be a few different issues.
1. update direct x from Microsoft
2. Make sure your video card drivers are up to date
3. Try rendering the project first and then burn the rendered file to the DVD
4. Try burning a Disc image, the option is on the final burn screen, if you are able to create the disc image try a different burning software that you may have installed on the system
Sep 11, 2011 | Corel Video Studio Pro X2 for PC
I can play cds in windows media player but i cannot burn to cd it comes up with error message C00D119F , how can i repair this
You need to be sure that your cd drive is also a cd burner. If it is then the problem might be fixed by any of the following: 1. Clean your disk that you are writing to or try a different one. 2. Use a cleaning CD to clean your drive. 3. Close any other programs that might be using your drive, song, or windows media player. 4. Restart Windows Media Player. 5. Restart your computer. 6. Try a different brand of cd to write to. 7. Choose a slower writing speed. Please rate my post if it was helpful! Best of luck to you.
May 03, 2011 | Microsoft Windows Media Player
I have had to replace my hard drive on my pc how can i get my music back on to pc from my ipod and back into i tunes
Backing up your iTunes library to a CD or DVD To burn a CD (CD-R or CD-RW), your computer must have a compatible CD burner. To burn a DVD (DVD-R or DVD-RW), your computer must have a compatible DVD burner. Check in iTunes Preferences to see if a drive is compatible. See below for steps.
To create your backup disc
  1. Choose File > Library > Back up to Disc.
  2. Select the option you want from the resulting dialog and click Back Up.
  3. The two options you can select from are:
    • Back up entire iTunes library and playlists
    • Back up only iTunes Store purchases
    Whichever of these two options you choose, note that you can also choose "Only back up items added or changed since last backup" to perform an incremental backup.
  4. Insert a blank disc (CD or DVD) into your computer's optical drive. iTunes will scan the disc and begin burning.
  5. Note: If the disc you insert does not have enough space to hold all of the content you will be backing up, a dialog will appear asking whether you wish to backup to multiple discs. You can click Data Discs to continue.
iTunes burns the number of items that fit on one disc and then asks you to insert subsequent discs to continue burning the remaining files. Don't eject a disc while a backup is in progress.
Spoken programs purchased from the website are not backed up.
Discs you create using the iTunes backup feature can be used only to restore; they can't be played in a CD or DVD player.
Restoring from a backup disc
  1. Open iTunes.
  2. Insert your backup disc.
  3. iTunes will ask whether you want to restore from this disc. Click Restore.
Check drive compatibility
  1. Choose a playlist on the left side of the iTunes window.
  2. Click the Burn Disc button on the bottom right corner of iTunes.
  3. If the drive is listed, it's compatible.
Aug 16, 2010 | Apple iTunes
How can i run platinum 16 on windows 7. it says there is compatability issues cannot find any driver updates
The recommended solution is to upgrade for version 18.
I'd guess you already tried running the installer by choosing Run this program in compatibility mode (by right clicking and choosing properties) and then right clicking again and Run as administrator.
Your next option is to run a virtual PC within your Win7 computer (or a dual boot system) with a compatible OS running on the "other" machine. With Win7 Pro and Ultimate, there is an option to download two programs and install them for a free WinXP virtual computer (XP mode). For the other primary OS's you'll need to have a valid license of the compatible OS to install in program that runs the virtualization or the second boot disc. Then install the Printmaster in the "machine" with the correct OS. You may find you need to save the files to external media to transfer them. (The virtual computer won't let you have one printer installed on both the virtual system and the real computer.)
I hope this helps.
May 01, 2010 | Broderbund PrintMaster Platinum 16
DVDs I burn will not play on other players. Players reject disc
Check that the burner is finalizing the discs. This can be set in Roxio or in the optical drive properties. In Windows 7, right click on the optical drive, choose Properties, then the Recording tab. Then the Global settings lets you choose to finalize the disc on eject. Try a different brand of DVD+R and check that the other players support DVD+R discs. (I know some DVD players only support DVD-R.)
I hope this helps.
Apr 15, 2010 | Roxio Easy CD & DVD Burning
Instead, for *FREE*, access
and search for "AShampoo Burning 6", download it, and install it.
It is FREE software for burning CD/DVDs.
Oct 19, 2009 | Roxio Creator 2009 Ultimate for PC
I can copy and burn one dvd. When I try and do a
OK I'll try to make this as easy as possible, you may have to get back to me if you don't understand anything but it is simple just follow the instructions below.
2 free programmes to download
DVD Shrink from here(removes restrictions)
ImgBurn from here
Install both then put DVD in drive but cancel when it tries to open.
Open DVD Shrink select open disc and wait while it reads it (about 1 1/2 mins)
I suggest you create a folder where you want it to save the temp files to on your desktop but you can do it anywhere.
Select main movie folder then click on back up on the top.
It will tell you where it is going to save the files but you can browse to the folder you created and save them there. As back up target use the drop down menu to select ISO image file. Click ok
Once DVD Shrink has finished you can usr ImgBurn to burn as many copies as you want without the original disc.
Jul 29, 2009 | Roxio Easy CD & DVD Burning
I have roxio creator & my dvd 9.0 de ; how do i burn my movies
I am trying to burn a movie onto a dvd using Roxio easy cd & dvd burning. The problem is that when I do burn it, it burns as a data disc. I try other things on it and it says to use the disc copier application to burn a dvd. I have searched everywhere on this progmram and there is nothing that says disc copier.
Jan 19, 2009 | Roxio Easy CD & DVD Creator Platinum...
DVD not copying
Try a different media brand.
Dec 30, 2008 | Roxio Easy CD & DVD Burning
Zio Corporation CameraMate ProPix OnTV for PC Logo
20 people viewed this question
Top Zio Graphics Publishing, Design & Multimedia Software Experts
Are you a Zio Graphics Publishing, Design and Multimedia Software Expert? Answer questions, earn points and help others
