Question about E-Machines emachines (emachinees) CD-ROM Drive
Dvd rom not working
Dvd rom drive e worked fine until powered off for awhile(about 2 mo.)when powered back on it dosnt work it will eject and load but says there is no disk
  • chrsguin May 17, 2009
    tryed solution but did not work what else can i try if anything
    Sergeant:
  • 199 Answers
Please uninstall the driver and then unplug the dvd rom and then restart the system and then install again all things new.ok
Posted on May 17, 2009
Sony DVD-Rom DDO 1615s not ejecting
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
you might have physicall unplug the dvd drive from your computer restart the plug it back in this should activate the found new hardware wizard
hope it helps
Feb 19, 2012 | Sony DDU-1615 / 16x DVD-ROM / 48x CD-ROM /...
My cd rom tray will not eject and the light is
have you manually tried to eject the disc tray? There's a little hole on there somewhere, stick an unbent paperclip or safety pin in it and push until the tray starts to come out, then pull the tray out with your fingers.
Once you've done that, push the button to allow the tray to automatically retract.
Jul 22, 2010 | Teac DW 28E CD-RW/DVD-ROM Burner
A dvd is stuck in the drive. It resists all attempts at removal including the ''eject cd'' command in Open Firmware. Can I manually remove it?
The iMac (Slot loading) computer's disc eject mechanism is electrical instead of mechanical. To eject a CD-ROM disc at startup that contains system software, press the mouse button until the computer ejects the disc. If the disc does not contain system software, wait for the iMac to start up and drag the disc icon to the Trash.
If either of these steps fails to eject the disc, push the drive's manual eject button with a small, blunt object like a paper clip. This button is located to the right of the CD/DVD slot as shown in Figure 1. The computer must be turned on to eject a disc in this manner.
ht3007_1.gifFigure 1 Manual eject button
Once the disc is ejected, it extends just beyond its center hole so you can remove it from the drive. If the disc fails to eject, while holding in the paper clip, use another CD to gently push against the inserted CD. This gentle pressure may help to release the inserted CD.
Important: After ejecting the disc with the manual eject button, you must restart the iMac in order for the CD-ROM or DVD-ROM drive to work.
DONT FORGET TO VOTE
Oct 10, 2009 | Apple iMac G4 Desktop
Brand new PC, Plays DVD s fine but ejects CD-Roms
Try reinstalling the driver, If that does not work take it back to the shop and explain your problem if its new.
Jul 19, 2009 | Computers & Internet
DVD RW Drive will not eject
Perform a system restart on your PC. As soon as it comes back up, hit the eject button..
May 15, 2009 | Teac DW 28E CD-RW/DVD-ROM Burner
Dvd burner/ cd rom drive not working
Sounds like a failed optical drive as it was requiring more power to operate normal. Will it even open if you try the software method (right-click on the drive in My Computer and select Eject)? You could also try manually ejecting the tray if there is a manual eject hole you can insert a straightened paperclip into. You will most likely need to replace the optical drive.
Jan 28, 2009 | Gateway Notebook PC (MX6710) PC Notebook
Dvd tray and cd tray won't open on hp pavillion a 250n
Did it work OK under XP Home ?
Did you do a clean install or Upgrade your sytem when you "upgraded" to XP Pro ?
Jun 18, 2008 | HP (176135-630) (176135630) Internal 48x...
Dvd rom automatically eject & loading frequemtly
I'm afraid when a drive starts to eject the draw especially on boot up, it's a sure sign that the unit is faulty and needs replacing.
Jul 11, 2007 | Samsung (TSH492BLACK) CD-RW/DVD-ROM Combo...
Dvd-r/cd-rom automatically ejects
My Dvd-r/cd-rom automatically ejects. Please help!
Justis
Feb 07, 2007 | Dell (Y4081) CD-RW/DVD-ROM (Combo) Burner
CD/DVD ROM disappears
I would think either your IDE cable is faulty or the IDE connector on the motherboard, try swapping cables or use a double IDE cable on IDE 1 connector. You may have a faulty drive ide connection input in which case a new DVD Rom is the answer, only cheap nowadays.
Nov 07, 2006 | Samsung (SC-140B) Internal 40x CD-ROM...
Computers & Internet Logo
163 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
