Question about KitchenAid KCMS145J Microwave Oven
Rust inside the microwave oven
I have rust forming on the inside corners of my 15-year-old Panasonic Microwave Oven. Is this dangerous? Is heating food safe?
  • lindsayneise May 16, 2009
    Did it solve my problem? I'll let you know. I'll find out which is cheaper. Repainting the old one or buying a brand new microwave oven. After all, it is over 15 years old--how safe is that?
  • 61 Answers
This is just okay but if you're quite doubtful you may bring this to any appliance service center for repaint
Posted on May 15, 2009
  • Divine Fulgencio
    Divine Fulgencio May 16, 2009
    It would be much better to purchase a new one. Who knows some of the wiring may have worn out. It will just cost a little higher than repainting
Paint is peeling off how can I fix it and do you know if its dangerous
I wouldn't advise trying to fix it and it's not dangerous. When heating food it causes condensation on the inside of the oven which pools at the bottom and causes rust and paint peel.
Oct 11, 2012 | Microwave Ovens
I have a Danby Designer Microwave, model DMW1153W, 1100 W, and there's a dime sized rust spot on the inside of the microwave, it's along the crease where the back of the microwave is joined to the...
Rust can form from the steam and condensation as you say, and it's a good idea to always cover food and wipe the oven out after using it. You can sand off the bad paint and rust the same way you can on a car, and then touch up the paint if it's a minor amount. Spray paint specifically made for microwave cooking cavities is available. (You don't want to use paint that may have metallic components.) It may be available locally if you have appliance parts stores in your area, and you can find the paint online as well. There's no need to replace the oven just yet, unless you find a good deal on a new one and you're looking for an excuse.
May 31, 2011 | Danby DMW1153 Microwave Oven
I have a Panasonic microwave and it has rust inside is that dangerous?
It should not pose a hazard as far as operation goes.. only if it becomes a sanitary issue..
Clean the interior per mfg suggestions.. and you may have to clean it more often now that you have this issue.
Microwaves cannot travel through metal.. you can actually use small pieces of foil (flat pieces) in most microwaves to shield items.. without any issues.
Best of luck
Apr 17, 2011 | KitchenAid KCMS145J Microwave Oven
On the back seam of the oven where the floor meets with the back side, there seems to be some rust. is this a problem?
It is strange as the inside of micro wave ovens are usually stainless steel. Clean off the rust, you may find it is not rust at all. If it is rust it will be problem because it means that eventually dangerous radiation will be able to escape from the oven. But clean it first and inspect if there has been any corrosion of the material under the rust.
Mar 06, 2011 | Maytag Appliances Over-the-Range Microwave...
Coating inside oven has de-laminated and rust is forming under coating. Warranty?
Hello spark... no warranty unless the microwave is under 1 year. If there is a lot of rust and delamination you are best off to replace this oven.
The problem with delamination is that it exposes bare metal and can result in dangerous arcing.
If it is not real bad, sand off the rust and spray paint it with microwave cavity spray paint available at this link http://www.appliancezone.com/ShowProduct.aspx?ID=8338&AspxAutoDetectCookieSupport=1
Joe
Thanks for choosing Fixya!
Feb 20, 2011 | GE Microwave Ovens
Cracked seam inside Microwave
It will have to be sanded smooth and clean and dried thoroughly.
Then if the steel seam is actually cracked / separated, then you can apply a very thin bead of steel-based epoxy "J-B WELD". When it dries thoroughly, you can sand it smooth.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart, Lowe's or Builder's Square.
If it's just the paint that's cracked, it will have to be sanded smooth and clean and dried thoroughly.
Jun 27, 2009 | General Electric Microwave Oven
My microwave oven has are rust spots;can I paint over them?
Yes, you can paint over the spots and no, it's not dangerous. I'd let the paint thoroughly dry before using the oven -- it could otherwise cause paint to buckle/ripple/etc.
May 03, 2009 | Microwave Ovens
Paint damaged in side microwave oven
1) How is the cavity damaged? Is it just peeling paint, or is it rust? If it's rust then the microwave could be dangerous.
2) The antenna cap usually has a small hole in the centre, but if there are any other holes in it the magnetron itself could be damaged, and holes caused by the magnetrin arcing.
Mar 25, 2009 | Sharp R-820B Convection/Microwave Oven
Rust inside the microwave.
The areas can be sanded and painted, but first make sure there are no holes rusted through. If it's all surface rust, then sand and clean as best as you can. If you have any areas rusted through - get rid of the microwave.
Use the paint sparingly - don't try to cover in one or two coats. Best results are obtained with very, very light coats drying 10 minutes or so (depending on the humidity) in between. 10- 15 coats usually works well.
It's best to do this outside, as you'll have lots of overspray.
As far as the paint - the best I've used for the last 20 years or so comes from A.M.I. Parts. You can find them @ www.amiparts.com or toll free 1-800-522-1264.
Jul 04, 2008 | Magic Chef CMV1000B Microwave Oven
KitchenAid KCMS145J Microwave Oven Logo
2,081 people viewed this question
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Stu Ungar
Darial Jr Lasaria
Darial Jr Lasaria
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
