Question about Bosch 24 in. SHU43 Built-in Dishwasher
Bosch Dishwasher starts the new cycle and then stops
Bosch Millenium Series
I have had this dishwasher for several years from new. Today it started by filling with water and then just stops. I can follow the reset instructions and it drains the existing water. When I start over it just repeats the problem.
  • 2692 Answers
SOURCE: Bosch dishwasher slowly fills with water after cycle is done
Replace the water fill valve, it's leaking.
Posted on Dec 21, 2008
  • 833 Answers
SOURCE: Bosch SHU3306UC dishwasher stopped
dave...why did the breakers pop? Sometimes, this is caused by a floating ground...the voltage from the other side of the line comes across and starts to fry things like circuit boards. What did the electrician do? Did he check the connection at the dishwasher itself?
Posted on Dec 09, 2007
SOURCE: Bosch Dishwasher not letting in water
The float switch may be stuck in the up position which shuts the fill solonoid valve off. you should be able to find the float switch under the lower dish basket.
Posted on Jan 14, 2008
SOURCE: Bosch sgv53e13gb Integrated dishwasher - wont start a new cycle!?
Thanks for the input Dicky...I think my dad will be onto the place of purchase first thing tomorrow!!
Posted on Jul 13, 2008
  • 1462 Answers
SOURCE: bosch dishwasher
i know this sounds daft but --
turn off water. disconnect fill hose from water supply. wait 5 seconds and reconnect fill hose then try it out
Posted on Oct 14, 2008
SHE45M05UC Bosch dishwasher
open the help booklet and follow the instruction if it is not working you can get replacement.
Dec 11, 2007 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
My Bosch dishwasher fills with water but when it comes to the wash cycle it does nothing.
If your dishwasher is brand new, then call Bosch service as they can repair it under warranty.
Feb 26, 2012 | Bosch Dishwashers
Dishwasher will not start. Several cycle buttons
check carefully on display buttons 2 buttons are marked reset push these together as you turn mchine on this should clear error if not you may have control pcb fault will need service tech.
May 26, 2010 | Bosch 24 in. SHY66C05 Stainless Steel...
Dishwasher signals "clean" inside five minutes
I would check tosee if your water meaning hot water temp is hook up correctly. i have seen cold water going to machine and causing the machine to do funny things. 1 the unit drains.2. it fills.3.it washes if the water is cold there is your problem .make sure b4 you start machine the water going in is hot. let me know how you made out maybe we can further check. p.s im a old bosch tech:)
Jan 26, 2010 | Bosch SHE4AM16UC 24 in. Built-in...
Bosch dishwasher timer freezing
There is a recall on the control board of many of these models, butyour problem is likely not related. It sounds like a plugged drain system or a possible bad drain pump. That's why you are hearing the pump running constantly. I have written a guide to help. It is here. Thanks!
Mar 24, 2009 | Bosch Nexxt 300 Series WFMC2201UC
Our bosch diswasher on auto wash will stop functioning in middle of the cycle start beeping and there is an icon of a faucet on the display. What does this mean?
Hello zeviemail
Welcome
You said, your Bosch dishwasher on auto wash will stop functioning in middle of the cycle start beeping and there is an icon of a faucet on the display.
What is your model number and the year of the dishwasher?
Oct 04, 2008 | Bosch Dishwashers
Bosch Dishwasher
carry out a reset.
This should reset the board back to factory settings,
Deep Diver
Dec 28, 2007 | Bosch 24 in. SHU5305UC Built-in Dishwasher
Bosch Dishwasher wont drain
have you removed the filter? if it gets clogged the dishwasher wont drain. other wise is sounds like a faulty drain pump
Nov 17, 2007 | Bosch 24 in. SHY56A05 Stainless Steel...
Bosch 24 in. SHU43 Built-in Dishwasher Logo
149 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
