Question about Canon PIXMA MP190 All-In-One InkJet Printer
We have a new Canon MP190 printer. Cannot figure
We have a new Canon MP190 printer. Cannot figure out how to install the print cartridges.
I already hate this printer. I'm accustomed to HP ink jet printer. And while it takes some doing to get the cartridges in place, at least it is clear how to do it. The cartridges are labeled A and B but I cannot see how to install them.
  • 2,567 Answers
1. Go to the following link: http://www.usa.canon.com/consumer/controller?act=SupportIndexAct
2. Menu 1, select "Multifunction"
3. Menu 2, select "Inkjet"
4. Menu 3, select "PIXMA MP190"
5. Click "GO"
6. Under "Please enter your question:", enter the following text: "How do I install the ink cartridge(s)?"
7. Click "Search"
8. From the search results, select the first selection. You will get a page with diagrams illustrating how to install the ink cartridges.
Posted on May 16, 2009
New ink cartridges are installed. No error messages but printer not scanning or printing. I have deep cleansed it twice.
Scanning isn't related to the cartridges problem unless you meant copying. The instructions to align the cartridges might help, if it insists on alignment after new cartridges are added.
http://www.manualslib.com/manual/24391/Canon-Pixma-Mp190.html?page=35
Did you remove the (usually pink) tabs from the cartridges before installing?
Did you get a printout from a test page or from the cleaning operation?
Also try a removal, then reinstall of the device.
May 16, 2015 | Canon PIXMA MP190 All-In-One InkJet...
Ink tanks full but blue ink wont print on my Canon MP190
clean the heads if that dont work clean the inside where the cartridge goes in and if that dont work buy a new ink otherwise get new printer
Feb 19, 2015 | Canon PIXMA MP190 All-In-One InkJet...
Cant load the printer cartridges for the pixma mp190
If you are trying to figure out how to load your ink cartridge in you Canon Pixma follow these instructions.
Make sure you printer is powered on. Open the top cover including the key display.
  • Step 2 Allow the ink return to move to left and stop. Remove the old cartridge which should have a 40 Black or 40 color on it by pushing down and popping it out of the holder.
  • Step 3 Now open your new ink cartridge and tear off the protective stip from the ink cartridge.
  • Step 4 Place the new ink cartridge in at a downward angle and then push into a straight position by pushing the bottom into place.
  • Step 5 Close the top an allow for the printer to adjust into place. Do a test print to make sure the printer is working correctly.
  • Step 6 If you experience an error message refer to your canon guide book for troubleshooting tips. Be sure your new ink cartridge in placed in correctly. Should be next to the other ink cartridge in same alignment.
  • Mar 22, 2010 | Canon PIXMA MP190 All-In-One InkJet...
    Canon MP190 not printing using only black ink, color ink finished
    hai there...you try press the reset and colour button in the same time...the printer will back to normallyl
    Feb 25, 2010 | Canon PIXMA MP150 All-In-One InkJet...
    How do i install new ink cartridges in my mp190
    Installing a new cartridge in your computer printer is quite easy. First of all it is recommended that you buy new cartridges every time you run out of ink instead of refilling it. Refilling cartridges will have negative impact not just on the paper but on the printer too. It has been reported that refilled cartridges have ruined many printers. After you buy the new cartridges, remove the old ones carefully.
    Remember the printer should be turned off before going any further. Install the new ones in the empty slot and turn on the printer. Remove a test page from the printer and check whether the new inks work or not. The first one or two times the ink might be a little smudge but that's all right. It will become normal again after one or two print outs. If the problem persists, exchange the inks with your retailer.
    Feb 19, 2010 | Canon PIXMA MP190 All-In-One InkJet...
    My canon printer mp190 ran out of ink while printing. The ink was a refill. I bought new refill cartridges for color and black and cannot get it to reset. It keeps flashing E at me. I have held the reset...
    well, you need to get NEW cartridges because there is a NON-resetable ink level sensor, once that detect no ink is left in the cartridge, it reports a empty cartridge to the printer, no way to change that, the only fix is to replace the cartridge with a new one, on epson printers you can reset the sensor, most other brands you cant
    Jan 05, 2010 | Canon PIXMA MP190 All-In-One InkJet...
    My Canon mp190 printer doesn't print after changing cartridges
    it can not recognize the cartridge due to careless or mishandled.... so you will clean the cartridge using the tisue, be careful 'coz it is sensitive...
    Nov 20, 2009 | Canon PIXMA MP190 All-In-One InkJet...
    How do you reset ink levels on a Canon pixma mp190 printer?
    you can reset low ink error by pressing stop/reset button for 10 seconds
    Oct 19, 2009 | Canon PIXMA MP190 All-In-One InkJet...
    Brand new MP190, cartridge not moving, E22
    E15 = Ink cartridge is not installed E16 – Ink remaining is unknown
    please follow this eror correction
    Aug 12, 2009 | Canon PIXMA MP190 All-In-One InkJet...
    Low ink lamp staying on cannon mp190
    The Canon rep told you the correct information. The printer companies have included circuits on their cartridges that will not allow you to refill them. The printer reads the code and knows that the cartridge already ran out of ink. To date no one has figured out a hack for this issue.
    Aug 10, 2009 | Office Equipment & Supplies
    Canon PIXMA MP190 All-In-One InkJet Printer Logo
    584 people viewed this question
    old marine
    old marine
