Question about Vizio VW32L 32 in. LCD HDTV
Unsure how to make letterboxed movie expand to full screen
Vizio vw32L flat panel TV: watching letterbox movie but unclear how to expand it to full screen
  • Anonymous Mar 20, 2014
    how do i
  • Anonymous Mar 28, 2014
    While we are trying to watch a on demand movie
    Genius:
  • 1,148 Answers
Check you remote ,,,
Posted on May 15, 2009
Tv full screen picture
thats called letterbox mode it all depends on how the movie or show was filmed years ago it was called cinemascope you can change it manually via your tv remote
May 04, 2014 | Televison & Video
Can't get full screen on Vizio VA19LHDTV10T
This is either due to some incompatibility or change of format of picture. Also the color system should be same like PAL/SECAM etc.
Aug 03, 2012 | Vizio VA19LHDTV10T 19 in. LCD TV
Some shows i don't get full screen picture about
You are watching a show or movie that was recorded in letterbox format, THIS IS NORMAL !
Jul 09, 2011 | Polaroid Televison & Video
Do all Blu-ray discs play with the black area at the top and bottom of the screen; like letterbox format? How can I expand the picture to full screen size on my LG 42LD450 tv? Maybe I'm just not...
They all play with a 16:9 aspect ratio. Sometimes they will be letterboxed and other times you will get a full screen with them. On your T.V. remote there should be a picture size button or format or a zoom button that should get you full screen.
May 05, 2011 | Televison & Video
I am having trouble getting the screen size back to full size. We used the zoom but that makes the picture to big. My TV is a Auria EQ5588
Hi, The " Size " of a flat panel tv ( when not in zoom mode ) is actually controlled by your programming, if using an hdmi cable from an Hd/Blu-ray player-then whatever format the disc was recorded in is what you'll see ( widescreen/letterbox ) black bars at top & bottom of scrteen ) or full screen. Local over the air digital H.D. brodcast's from networks varie from full screen to letterbox-satellite and cable that are standard definition will almost always letterbox a screen for you. Using T.V.s tuner may alleviate most of the issues. Good luck and I hope this helped. Prodzilla
Apr 10, 2011 | Televison & Video
I purchased a DVD that states: Widescreen Format (Aspect Ratio 1.85.1) I'm unable to get 'widescreen/letterbox'. The movie shows up full screen or a 'stretched' view. All other movies I've...
On the DVD recorder remote: press function menu button: enter setup screen - scroll down to connection - TV aspect - select either 16:9 / 4:3 Letterbox / 4:3 Pan&scan. If you are using an older TV which is not a widescreen, set the aspect to '4:3 Letterbox'.
You should now be able to view your DVD movies from this machine through a 4:3 standard TV in letterbox format. (some DVDs do not allow pan&scan so letterbox or widescreen is recommended). Very rare that a DVD title is not compatible with 4:3 TVs. I assume your deck is set to output 16:9 aspect by default.
I find this is the cheapest and easiest solution and can save lots of dollars in service call-outs. You can always reset the unit back to shipping condition later if you need to, or in the rare case of digital channels disappearing from your tuner memory.
Jan 09, 2011 | Panasonic DMR-EZ485VK DVD Recorder/VCR
LG 37lH20 LCD Aspect Ratio Problems
Not ur tv it the dvd format,tries it with other dvd.
Nov 23, 2009 | LG 37LH20 37 in. LCD HDTV
I cant get the whole picture to fit the screen. When I watch games the score is cut off.
This is most likely a setting on your TV, like stretch, or fit, or possibly on your cable box, or dish receiver. look at your dish or cable box settings and turn off any screen adjustments. Example under wide screen setting is strech , zoom, letterbox (choose letterbox).
The TV has these settings as well.
Aug 24, 2009 | Samsung LN46B650 46/49.5 in. LCD HDTV
Wide screen lcd simple question.
Hi pooing stone,
You may sometimes find that even with a television referred to as “widescreen,” widescreen movies still have letterboxing.
This is likely because the movie you are playing is still in the ratio used at a theater. While most televisions are 4:3 for the more square-type or 16:9 for widescreen, a theater screen is much wider still. Unless the movie has been reformatted specifically to 16:9 for your television, you will either see letterboxing or lose portions of the picture by zooming in.
If a movie is available in several ratios, I suggest thinking of all the options before buying. Although purchasing a movie reformatted to 16:9 will prevent the black bars, purchasing it without any reformatting of the size will prevent you losing part of the picture.
FYI: It is very common with Blu-Ray Discs that widescreen means original size, not 16:9.
Thank you,
Jason,
Go Ahead. Use Us.
Jul 03, 2008 | Dynex 32 in. LCD Flat-Panel HDTV
Vizio VW32L 32 in. LCD HDTV Logo
432 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
