Question about Compaq Evo N410C Notebook
Wireless adapter I cant work out how to switch my internal wireless adapter on so i cant use my wireless router please help !!!
  • Jester24 Oct 16, 2007
    I was sold it under the impression that it had one but then again it was second hand so maybe ur right, if this is the case would i need to buy a card or a USB adapter and do they cost much??
    Problem Solver:
  • 11 Answers
Are you sure you have an internal wireless adapter because I checked your labtop's number and find no wireless adapter iunside.
check this link
http://h18002.www1.hp.com/products/quickspecs/11375_div/11375_div.HTML
Posted on Oct 16, 2007
Network adapter hp6505f
If your computer has a wireless network adapter, Windows will automatically detect wireless networks in range of your computer. You can see a list of wireless networks that Windows has detected in Connect to a Network.
  • Open Connect to a Network by clicking the network icon (eff2d36c-9e0d-4d1a-9859-3af14fa4ccfc_73.jpg or da12251d-1e9a-4032-afae-009876c6c5a3_80.jpg) in the notification area.
If Windows doesn't detect a network that you think is in range of your computer, it could be because of one of the following reasons:
  • The wireless switch on your computer is turned off.
    Many laptops have a wireless switch on the front or side of the computer. If your computer has a switch, make sure it's turned on. Some computers also use a function key combination to turn the switch on or off. Check the information that came with your computer for details on locating the wireless switch.
  • Your computer is too far from the wireless router or access point.
    Move your computer closer to the router or access point. If the computer is portable, try moving it around to determine the range of the wireless signal and the best place to use the computer.
    If you can't get closer to the router or access point, consider buying and installing an external antenna for your wireless network adapter. Many wireless network adapters are set up so that you can attach an external antenna to them, which provides better reception than a built-in antenna. Check the information that came with your wireless network adapter to see if you can install an additional antenna.
  • The wireless router or access point is turned off or isn't working properly.
    There are two things to try:
    • Make sure the router or access point is turned on and that the wireless signal light is illuminated.
    • Reset the router or access point by unplugging it, waiting at least 10 seconds, and then plugging it back in.
Sep 10, 2012 | NEC Computers & Internet
My laptop can't find the router
Hi Ted,
If your Laptop cant find your router there are things that you need to check to be able to know if the problem is caused by the router or by the computer. On your computer you can check if the wireless adapter is properly installed or check if the wireless switch is on. If your not familair with the wireless switch of your laptop you can refer to this link. Just find the model of your laptop. Then after you enable the switch of your laptop you can check the Wireless Settings Page of the router if the wireless is enable.
To access your router you need a working computer connected to the router then open a Browser then type 192.168.0.1. the username is admin and the password is blank. Go the the Wireless Settings Page and under Wireless Network Settings make sure that there is a Tick or a Check on Enable Wireless.
Rate me if this helps so i can help others.
Thanks for using Fixya.
Feb 03, 2011 | D-Link AirPlus DI-524 Wireless Router
My card will not connect to my wireless router. Why? It's installed and recognized as working properly in my system. Is their another program that needs to be installed to connect to the verizon dsl...
Is the internal wireless turned on? Depending on the computer, there may be a switch on the outside, and, there is also a software switch on some computers to turn the internal wireless on and off.
What type of computer is the computer that has the "internal wireless"?
Security can be setup following the instructions int he router manual, but I can help you as well. If you want, I can set you up remotely, for a charge.
Dec 17, 2009 | Intel PRO/Wireless 3945ABG Network...
Wireless card works. says cant find wireless
There's a little switch on the right hand side below the keyboard...
Regards.
Aug 06, 2009 | Acer Aspire One PC Notebook
Belkin N wireless modem router cant connect
http://en-us-support.belkin.com/app/answers/detail/a_id/534/kw/7001/r_id/166
go this website select your version and model number download the drivers and install
go to ->run>services.msc
select wireless zero configuration -.>right click and start it
Jul 17, 2009 | Belkin (F5D7001) 802.11g/b Wireless...
Lexmark N2050 wireless adapter for X3500-4500 series printer
i cant tell you too much because i dnt know too much about your situation but try completely resseting everything and try sending something again
if its allwireless c if you can pick up the wireless points if you cant there's your problem
Dec 29, 2008 | Lexmark N2050 for X3350 (14T0300) Wireless...
Hooking up wireless router and adapter to share wireless
See first if your adapters are compatibles.
You will find help about how to set a wireless network here:
http://www.microsoft.com/athome/moredone/wirelesssetup.mspx
Let me know if you need additional help.
Have a great day!
Pablo :-)
Oct 17, 2008 | Computers & Internet
HELP PLZ setting up o a 2wire router with gaming adapter
Could it be possible that the game adapter is out of range of your router?
Dec 29, 2007 | Linksys Wireless-G Game Adapter [ WGA54G ]...
Compaq Evo N410C Notebook Logo
93 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
