Question about Garden
Lawn tractor mower stops running
The mower stops running after running for a while ,will run when first started
acts like an electrical shorting problem
  • 8,220 Answers
I have had problems with my mowing equipment. After 15 minutes the mower would die then when cool it would run again. I changed the plug, the gas, the fuel filter,cleaned the air filter, and changed out the magneto coil, none of which fixed it. I removed the fuel solenoid from under the carb and nipped the end off the plunger with snips. That fixed it. The function of the solenoid is to kill the gas when the key is shut off. Near as I can tell the solenoid was going out when hot and working while cool. You cannot just defeat the solenoid by unplugging it because that releases the spring loaded pin and the pin shoves the float up and therefore kills the gas. I had to either spend $50 on a solenoid or nip this problem in the bud. Nipped the plunger and all is well. I posted the solution with photos HERE.
Posted on Aug 07, 2010
  • Dan Webster
    Dan Webster Aug 07, 2010
    http://foggyfacts.blogspot.com/2010/08/r...
  • Dan Webster
    That solenoid kills power to the engine when the key is turned off to prevent backfires. Unplugging it won't fix it. That just kills the gas. The solenoid gets hot and fails shutting off the fuel to the motor. Very aggravating to diagnose. I removed the solenoid and nipped off the tip of the plunger. reinstalled it and have had no more problems. At the end of a mowing session I idle down the motor to a crawl for 5 minutes That prevents backfires. My fixya tip
  • 86 Answers
How old is your mower if older problem is points if newer problem is module ,most of the time you can run these until they get hot then they will act up if you let it cool you can start it up and it will run ok until it gets hot again.
Posted on May 16, 2009
I have already checked seat safety switches-good. When tractor is running and brake released stops running, why? Also I have checked PTO switch-good.
Hi Dawn, Does your mower have a safety switch on the brake... The links below are YouTube videos that might get you out of trouble...The 1st video is a craftsman mower that stalls out after driving off..... Also there's videos down the right side of the links that may help as well....... I hope they help......... CHEERS...
shows a craftsman mower with problems....
Craftsman Lawn Tractor stalling out
How to test lawn mower electrical safety switches....
Shows all safety switches disabled....
Disable all lawnmower safety switches
Apr 28, 2016 | Garden
180 john deere riding lawn mower
Your deck belt slipping. It need adjusted or replaced
Aug 11, 2014 | John Deere Garden
Mower stops running after I've been mowing for about 30 minutes. I changed the spark plug and fuel filter. It seemed to work and I was mowing the lawn then it just started acting like it was running out of...
Mower stops running after mowing about 5 minutes. acting like it was running out of gas unitl eventually stops. I wait 10 minutes and then it restarts, runs good, then erratic...then quits again?
Aug 23, 2009 | Garden
I have a craftsman electric key start lawn mower. I used the key start twice and have charged it after each mowing, but now the key start won't turn it over.
the battery probably got over charge & shorted the cells the tractor should charge the battery as it runs if it was equiped with electric start the battery charger more than likely over charged it killing the battery
Jun 07, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Blades stop working
Does your mower have an electric clutch ? If so your problem is most likely a connection
May 07, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
The electric Starter motor will not stop running
If the starter continues to spin after the engine is started..replace the key switch, it is bad
Apr 10, 2009 | Garden
Lawn hog electric mower
Sounds like the brushes are bad .or you have a direct short.
Aug 30, 2008 | Black & Decker 19" Electric Lawnhog...
Garden Logo
421 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
