Question about Coleman Electrical Supplies
Engine runs but no power aat outlet????
I have a coleman powermate powerbase series 2250 watts generator. engine runs but no power though outlets. what should I BE LOOKIng for to fix it.
    Scholar:
  • 79 Answers
Start with brushes and rings. Make sure your rings are clean and the your brushes have a good length. Flash the fields with 12V battery. Apply positive to the brush nearest the bearing and negative to the back brush, while genset is running. Use rubber gloves when doing this and keep hands away from rotating parts. You should see the voltage climb when you flash the fields. This would mean that you need a voltage regulator. If voltage does not climb, then you will need a new genset.
Posted on May 17, 2009
Power cord does not retract immediately
Coleman Powermate Generator 5000 Watts / 6250 Watts ...
? 3:27
https://www.youtube.com/watch?v=IROa5QfPqkU
Nov 8, 2012 - Uploaded by Carlos Roman
This 5000 watt generator is great for backup power at home or forpower ... Coleman Powermate Generator 5000 Watts / 6250 Watts ... This feature is not available right now. ... folding handle, 1 quart, of oil, and 25ft generator convenience cord. ... How to convert a generator recoil starter to an electric starter!
pull cord won t retract Power Generators Questions ... - Fixya
www.fixya.com > Forum > Tags > pull cord won t retract
Power Generators pull cord won t retract questions and answers. Ask your pull cordwon t ... Question about Powermate Powermate 5000W Generator. 2 Answers · I was running my coleman powermate 6250 gen power ... cord 6250 trips out ... The pullcord does not rewind onto the pulley when pulled. At first I thought it was ...
Best Portable Generator Reviews
Feb 03, 2016 | Coleman Powermate Powermate 5000W...
The generator hasn't, been used in a while and is not cranking. Gas is getting to the spark plug and the plug is clean. What could be the issue?
Coleman starter not cranking Power Generators Questions ...
www.fixya.com > Forum > Tags > starter not cranking > Power Generators
Coleman power generators starter not cranking related questions and answers. Ask your ... Ad. Question about Powermate Powermate 5000W Generator.
Powermate coleman 5000 gen. with subaru engine ... - faqqq
www.faqqq.com/.../powermate-coleman-5000-gen-with-subaru-engine-col...
Question Product: Coleman Powermate Powermate 5000W Generator Question ... it would crank for a second, then i open the choke, it would die, would not stay ...
Fixing Electrical Problems in Coleman Powermate Generators
www.alpharubicon.com/altenergy/colemanpenwu.htm
*Fixing Electrical Problems in Coleman Powermate Generators* By: Penwu 29 April 2006. All of Coleman's portable Powermate line of generators use brushes ...
Coleman 5000 watt generator cold start - YouTube
? 4:35
https://www.youtube.com/watch?v=pcT989l0rm0
Nov 3, 2011 - Uploaded by stevenpturcheck
well im starting to cycle though my equipment before winter so more cold ... How To Change Oil On Coleman Powermate Generator / Yearly ...
Jan 21, 2016 | Coleman Powermate Powermate 5000W...
Coleman Powermate Powerbase 4000 -no AC Need Field test procedur
Check the voltage sent to the field when running. It will probably be around 12 volts. You can try connecting a lantern battery BRIEFLY to the field to re-magnetize the field. Try bothe polarites.
Some have had a bad rectifier and one had a bad transformer that generaates the low voltage from the generated output. He had a broken wire from the winding to the wire from the transformer. He was able to reconnect the failed solder joint.
Apr 16, 2010 | Coleman Powermate Premium Plus 6250W...
I'm reading 130VAC on the output. Can this be
It should read 115v-120v with full load. Yes, you can slow the engine down just a little, depending on the engine, there will be a high rpm adjustment. 130v with full speed, no load, is really not too bad.
Nov 26, 2009 | Coleman Powermate Powermate 5000W...
I have a coleman powermate 6250-5000 running watts-generator. The generator starts and runs but does not produce current to outlets,the outlets are fine-they have continunity,I removrd the armature and...
You may have just lost residual magnetism in your rotor. Start genset then apply 12 vdc to 120 v outlet for less the 1 seconds. This will be enought to restore the residual magnetism to the rotor and the unit should be producing power now.
Nov 17, 2009 | Coleman Powermate Premium Plus 6250W...
I have a Coleman Powermate 6250. Runs Great, No power to outlets!
Excite the genset.
with the gen engine running,
1) plug a 3/8 drill into an outlet,
(make sure the drill is set to the forward rotation)
2) hold the trigger in the run position
3) by hand, rotate the drill chuck with a quick flip of your wrist.
*** NOTE: BE PREPARED !!! this will excite the gen-set and the drill will start to run as normal.
Oct 07, 2009 | Coleman Powermate Premium Plus 6250W...
Looking for a Pricesheet
google"coleman powermate". on the site look for manuals. the price list is the top manual. kinda small. you may have to increase magnification. mike
Nov 17, 2008 | Coleman Powermate Premium Plus 6250W...
Motor runs but have no power coming out of outlets of mygenerator
1 - Check the circuit breakers on the front of the panel where the outlets are located.
2 - Make sure the black molex plug on the back of the panel where the outlets are located is plugged in securely.
3 - Carefully take the plastic endbell off the generator ( you'll need a 7/16 inch wrench and socket) and look for broken or missing brushes, broken wires, etc.
4 - If you're not up for #3 take it to a good repair shop. :-)
Nov 13, 2008 | Coleman Powermate Premium Plus 6250W...
Electrical Supplies Logo
583 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Shawn DuRee
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
