Question about RIM BlackBerry Curve 8310 Smartphone
Blackberry tracker ball won't go up!
Tracker ball on my blackberry just started NOT working today...it goes down and to the right but not up..making my Blackberry almost unworkable.
  • Anonymous May 18, 2009
    the ball will move in all directions except for up.
    don't know what to do!!
Its happens to me too so dont worry,,
its probably somthing stuck in there.
you just have to like boof in with ur mouth..lol
like ur cleaning dust..it'll work if u do it couple of times
Posted on May 17, 2009
How do i remove berry tracker lock when i have forgot the password?
My blackberry onyx 9780 is locked. The screen says berry tracker lock and I have forget tha password.
Aug 03, 2014 | RIM Blackberry Curve 9320 Smartphone -...
Mobile tracker
I think you need to update tracker driver or it may be a problem of hardware.
Jun 05, 2013 | RIM BlackBerry Bold 9900 Cell Phone
Cant get my ball to work
usually all blackberry phones with ball trackers experience this type of problem due to overuse
if you can fix it on your own,do it with care cause some parts are to sensitive.
* need a T6 screw driver
* open and unscrew all sides where the screws are located
* locate the track ball and dismantle it
* clean and align the board interface which the ball tracker is attach..
* assemble it with care....DONE
good luck....
Jun 09, 2011 | RIM BlackBerry Curve 8310 Smartphone
My blackberry bold toggle button will not move around the phone.it won`t go up and down or left to right,only works when you press down on it
I had the same problem today. Turn off phone, remove battery. Take Q-tip and use rubbing alcohol to clean the ball...this will also clean the contacts inside. Make sure to move the ball around while putting the alcohol on. You dont need to drown it..just enough to get it covered. Once dry, put battery in and then turn on phone. It should work...mine is working fine.
Mar 05, 2011 | RIM BlackBerry Bold 9000 Smartphone
I will press the button "a" and it types "ou", my buttons are just all mixed up also my send button types out "jk"
This problem is caused by contamination UNDER the trackball. Its picked up from sticky/oily fingers operating the tracker ball. Fix:- 1. Checkout web for videos on dismantling the case (easy, but you WLL need a T4 (or is it T5?) multi-point screwdriver (ebay))
2. After accessing the PCB, unclip the tracker ball (magnifying glass and small screw driver). This lifts out as a single assembly.
3 .The area of the PCB reviled under TB now needs cleaning with a cotton wool swab, soaked in a de-greasing solution. DONT use water (even soapy), as this is slow to dry. Use - IPA (Isopropyl alcohol) - safeclens - surgical spirit etc. These will not harm circuit board or components, but MAY affect some plastics. Test small area if unsure The underside of TB assy and ball should also be cleaned. A clean swab damped in mild soap solution can be used to do general cleanup of dirt on white keyboard membrane, case edge grooves etc. allow to evaporate
DONT touch degreased areas with fingers as this will re-contaminate
4. Allow solution to evaporate (around 1 Min.)
5. Re-assemble tracker ball (clicks into position) Re-assemble case using on-line video (step 1)
Apr 06, 2010 | RIM BlackBerry Bold 9000 Smartphone
My tracker ball won't scroll down
go on ebay and put in the seach your phone model and trackball. they arent expensive and it fixes your problem. that happened to my trackball and i replaced it and now it works great
Jan 03, 2010 | RIM BlackBerry Curve 8310 Smartphone
My tracker ball is not working is there any other way to move the highlighted bar around the screen???
Sounds like you have a broken trackball. Go to your carrier, they might replace it for you for free. If they refuse,the only way to get it up and running again is to open your blackberry2_bing.gif to physically replace the part. If you want somebody else to do it for you go to Blackberry Repair. If you want to do it yourself, here is a Blackberry curve Repair Guide that shows how, the part is available on Ebay.
Nov 16, 2009 | RIM BlackBerry Curve 8310 Smartphone
Blackberry Pearl Tracker ball not working well
pearls have been know to have the track ball go out on them best bet is to take it to store to have them clean it if you try to clean it and you break the silver ring you void the warranty and will have to pay for whole new phone, in the end they will replace the phone for you
Aug 13, 2009 | RIM BlackBerry Pearl 8100
My blackberry cannot find my bluetooth device
put it in discovey mode and ur blackberry in discovery mode so ur bluetooth can alsofind ur phone. should work now,
Jul 15, 2009 | Insignia Bluetooth Wireless Headphones...
My tracker ball works just when i clixk on anything nothing happens also when i try calling a number i get letters instead of numbers blackberry curv
Try doing a hard reset. Take the battery out of your phone with the power still on. Let it start up, which may take a while. If things don't improve then, make sure your blackberry software is up to date with the 4.7 or 4.5 software. If still no luck, call your phone company. Get a replacement or find a technician near you. I wish you the best of luck! Need any help, just let me know ! :)
Mar 18, 2009 | RIM BlackBerry Curve 8310 Smartphone
RIM BlackBerry Curve 8310 Smartphone Logo
1,144 people viewed this question
Top RIM Computers & Internet Experts
ismael castillo
David
Martin Murray
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
