Question about HP PSC 1110 All-In-One Thermal Printer
Printer part I need a printer cable part to go from my printer to my computer
  • Anonymous May 11, 2010
    whatever the type....go and buy one.
  • Divine Fulgencio
    Divine Fulgencio May 11, 2010
    Hi. Let me just verify,this is a parallel printer, correct?
  • 221 Answers
Just go to your local Walmart or office supply store and buy a USB cable, they come in standard lengths with connectors. Use the shortest length that will suit your location.
Posted on May 16, 2009
Need cable from outlet to printer
If "outlet" means 120 Volt AC Power Outlet, then you need a standard 3 wire PC power cable.
If "outlet" means the UBS port on your computer, then you need a USB A to B cable.
If "outlet" means the parallel port on your computer, then you need a computer parallel port printer cable
All of the above are available at computers stores, Stapes, Office Max etc.
Regards,
Yavacotech
Mar 11, 2011 | Office Equipment & Supplies
Offline printing from computer
disconnect printer from computer
cancel documents in queue
if using a straight USB connection, delete all instances of printer. else remove duplicate printer icons.
reboot & reconnect printer (swap cables if not detected)
Oct 20, 2008 | Canon PIXMA MP160 All-In-One InkJet...
I am installing this new printer and need the usb cable to connect printer to computer. Where is it? I cannot see it anywhere.
you cant see the usb cable? or the usb port? Some printers are still not supplied with a USB cable, silly I know, but for some reason they dont supply. If you were not supplied a USB cable you will need to go to your computer store (or the place you got the printer) and purchse a USB cable
Feb 09, 2011 | Brother Multi-Function Center MFC-240C...
What plugs do i need to hook up my printrt to my computer
Follow these steps :
1.1
Position your printer. If you have a laser printer, allow a few inches of space on all sides for ventilation. Ink-jet printers don't require ventilation.
2.2
Buy a bidirectional, IEEE 1284-compliant parallel printer cable. (Printers rarely come with cables. See "How to Buy a Printer Cable," under Related eHows, for more information.)
3.3
Shut down the computer, but leave it plugged into the surge suppressor.
4.4
Compare the connectors at the opposite ends of the cable.
5.5
Attach the 25-pin end of the cable to the parallel, or printer, port on the computer. (The plug will go in only one way.)
6.6
Tighten the hand screws securely.
7.7
Connect the other end of the cable into the printer's socket.
8.8
Latch the retaining clips (on most printer ports).
9.9
Plug the power cord into the printer and into the surge suppressor.
10.10
Turn on the printer.
11.11
Install cartridges according to the printer manufacturer's instructions.
12.12
Turn on the computer.
13.13
Install printer driver software according to the manufacturer's instructions.
14.14
Add the printer to the list of printers your computer recognizes (see "How to Add a Printer," under Related eHows). On a Macintosh, just select the new printer in the Chooser.
Oct 29, 2010 | Brother MFC-210C All-In-One Printer
Printer cable from printer to computer
You will use a USB printer cable for this
Dec 29, 2009 | Office Equipment & Supplies
I need the cable that goes from my printer to my pc
Its a standard "printer usb cable" that can be gotten at any computer store, radio shack, best buy , walmart, etc
Dec 18, 2009 | HP APOLLO P-2150U InkJet Printer
The printer was working fine before,but you just cant print off the laptop any more.iv tyred to reinstall the dics but it come up failed?
Hello.
Give this a try ...
In Printers and Faxes, remove your printer icon.
Disconnect your printer cable to the computer.
Restart your computer.
Reconnect your printer cable to the computer.
Printer should be seen by computer.
Install printer driver (software).
If the printer is not seen by the computer, your printer cable is probably faulty and needs to be replaced.
Hope that helps.
Dec 07, 2009 | Lexmark P6350 All-In-One InkJet Printer
I need the cable from the printer to the computer. where do i purchase one
u can ask for a usb cable 4 pin at the end and square shape on the other end
Nov 07, 2009 | Lexmark X5070 ALL-IN-ONE InkJet Printer
Unable to connect it to computer --Just got a replacement printer and dont know how to get it to work with my computer-
Are you speaking about a physical connection ...???
Printers do not come with a wire for this.
You need a USB printer cable to connect. Get it at the Bog Box store or computer store or ... try K-mart.
Yo need a USB Printer cable ... not a USB cable - printer cable being the operative word.
If I missed your question. please ask
a
Oct 30, 2009 | Kodak ESP 5 Printer
Printer USB Cable un recognized DCP150C
You need to isolate the problem. You tried using multiple cables and reinstalled the printer driver several times, but you never mentioned that you tried connecting the printer into another computer. What if the problem is the USB port of the computer and not the printer cable?
Try connecting and installing the problem printer into different computer for testing purpose only. If it work, then the problem is the USB port of the computer. To fix this, try updating the USB driver of your computer.
If same problem occurs using another computer, then you need to contact the manufacturer of your printer. I've heard this problem before and I don't have an update if there's a fix with it.
Have a great day!
Oct 01, 2009 | Brother Office Equipment & Supplies
HP PSC 1110 All-In-One Thermal Printer Logo
32 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
