Question about Xerox WorkCentre Pro 416DC Copier
Paper stop before the fuser
Paper dont come into the fuser
  • artanys2 May 16, 2009
    The paper is printed a 3/4 of the pages , the sheet don't have any damages . Thx
  • Rick Kasper May 11, 2010
    Is there any damage to the paper, or any print on the paper?
  • 30 Answers
Hi,clean drum cartridge or fuser espicially fuser.be sure little papers in fuser.
Posted on May 21, 2009
  • sasheevja1 Oct 09, 2010
    Ofcourse.... check T/D corotron assembly, clean it; check "Transfer guide roller" fixed to this T/D assy; check ground plate contact, misplace of bushes
Open the fuser for FS-C2126 MFP
there is a blue mark on the right side of the fuser simply pull it towards you and that should allow you to see the rollers and remove paper if not its four screws and three connectors to remove the whole fuser
Jan 17, 2014 | Kyocera FS-C5030N Led Printer
Hp 2300d paper stops at exit roller
Probable causes: First have you tried running the paper thru the manual feed tray and see if it stops at the fuser unit.. if so then proceed with checking the exit area of the printer(fuser) and make sure there is no obstruction blocking the path, could also be the fuser actuator, small black arm generally pushes the paper during it's delivery(exitiing) of paper.. Worst case scenario is a paper feed timing issue.. but first check the exit area of the printer and the paper tray.
If you need further help, reach me via phone at https://www.6ya.com/expert/howard_563901c2e8628759
Feb 08, 2012 | HP LaserJet 2300d Printer
Printer prints out but all powdery and wipes of page .
I agree the fault is almost cetainly with the fuser unit.
Oct 30, 2011 | Samsung CLX-3170FN All-In-One Laser...
We have XC865 the copier was working just fine until today. The paper keeps jamming inside. It would start to copy and then just gets stuck in the middle of the cycle. So I have to open the machine up...
Most likely a common problem of a broken fuser drive gear. This is especially true if the lead edge of the paper is stopping at the fuser assembly. This is the assembly that is hot to the touch. There is a upper fuser roller drive gear that breaks on these and causes the fuser roller to stop turning. So everytime the paper gets to the rollers it stops and a jam reults. The gear is 16.00 at precisionroller.com part number M510X
Here is a picture of the gear.
Sep 17, 2010 | Xerox Office Equipment & Supplies
My samsung printer clp 315 has a paper jam with about 1/3 of the paper out the exit everytime
From You Tube:
http://www.youtube.com/watch?v=5fJHykzkfww
DIY video tutorial on how to repair the Samsung CLP-315, CLP-301 laser printer "paper jam" problem, where the paper stops printing about halfway through for no apparent reason. My printer worked great otherwise, but was out of warranty. It would have been less expensive to get a new printer.
The problem is a very cheap sensor.
This repair takes 15 minutes and is inexpensive. Read the comments below.
I got the part from SamsungParts.com. Search for part #0604-001393
Jun 16, 2010 | Samsung CLP-315W Laser Color Printer
After I print a few on a good quality paper the print is smurred and gets worst as it prints could it be my fuser
first check if the media(paper) you used are correct in the printer drivers, HP for each kind of paper quality, have diferent speed to cross the fuser, when de printer are new, the fuser are good and dont need change that, but before 10 months you need say to the printer what kind of paper are used.
If your paper are from more tha 20 lbs, used the paper say heavy paper.
If after you check this and dont correct, probably 70% are the fuser.
Aug 07, 2009 | HP Color LaserJet 2600n Printer
HP laserjet 5500dn paper jam at fuser
I was able to fix my problem. On the left side of the fuser assembly there are two small plastic tabs or flags that move up & down. One is attached to the plastic rod/flap that you can see from the top of the fuser and moves when the paper comes out of the "chute". The other tab, which is below the first tab and moves when the paper has passed some point in the fuser, was broken off. I glued the tab back on and now the paper is ejected from the printer like it is suppose to.
I'm thinking that the broken tab was part of a page sensor flag that would tell the printer to stop rolling the fuser assembly when the paper was ejected. Without the flag, the sensor would disengage the fuser prematurely and stop ejecting the paper while the paper was still in the fuser.
Charlotte
Apr 17, 2009 | HP LaserJet 5500DN Printer
Xerox Phaser 5500 printer...paper stops halfway thru fuser unit.
Are the paper tray settings correct? If you have the tray mis adjusted, such as the tray thinks it has 14 inch paper in it and it has 11 inch, it will just shut down like that.
Make sure the settings are correct on the computer and the printer.
Also, its unlikely but the latch for the load springs in the fuser may be unlatched, but you shold NOT be able to close the covers like that.
Jan 06, 2009 | Xerox 5500/DT Laser Printer
Xerox WorkCentre Pro 416DC Copier Logo
71 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
