Question about Whirlpool WTW5850S Top Load Washer
My ultimate care II washer sounds like transmission is slipping
Apperantly,the washer was filled to capacity,but ran on medium water level. During the spin-out portion of wash cycle,it froze up,yet the transmission is still turning,sounding like it's slipped a gear or sprocket or something,if that's possible. I'm fairly mechanically inclined,and extremely funds-challenged,so any shade-tree fix would be wonderful!!!! Thanks in advance.
  • Whirlpool Master
  • 3,361 Answers
You probably need a new direct drive coupling.
Use the attached video to access the machine and check the coupling.
Posted on May 15, 2009
My Whirlpool Ultimate Care II Washer doesn't stop filling with water
If this only happens when the machine is turned on,the tube from the tub to the water level switch is pinched or broken. If the clear plastic tube is not pinched or broken,the water level switch in the control console is bad. If the machine lets water through when it is in the OFF position,the water valve where the hoses connect are bad.
Dec 27, 2012 | Whirlpool Ultimate Care II LSQ9564J Top...
I have a Whirlpool ZUltimate Care II Washer, Model 3XLSQ7533JQ2. Washer keeps filling in the medium and the super wash level and will not go into the agitation cycle. Works on small load level only.
SInce the washer works ok on the small load size yet overflows on all others the problem is going to be with the water level switch and it should be replaced to remedy that problem.
The part number for that water level switch is W10339229 it could be purchased at your local appliance parts store or online at
searspartsdirect.com
apdepot.com
partselect.com
apwagner.com
repairclinic.com
GENE
Oct 13, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
The washer does not stop filling with water at the chosen water level, small, medium, full etc
your water level pressure switch located inside the control panel is defective,there is wires and a plastic hose to this component,replace it and it will again fill correctly
Mar 19, 2011 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool ultimate care II stops after filling
Hi, could be faulty timer, faulty water level switch, faulty start capacitor for motor, or faulty motor. always put clothes in machine before starting. you can empty machine by lowering drain hose to flow level.
Aug 02, 2009 | Whirlpool Ultimate Care II GSW9650LW Top...
Fills up with water and wont stop
Bad Preasure valve comes to mind first and formost it acts like a level sensor balanceing the size indicated for fill.
Feb 10, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool, top-loading Ultimate Care, 20 lb washerm
The ticking sound is coming from the drive motor.
Removing the back and peering into the guts will tell you if there is a shredded belt causing the problem.
If the transmission has failed, the last one I bought years ago cost ~$130 wholesale.
Jul 19, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool Ultimate care 2 (ABOUT 4 YEARS OLD)
Sounds like the clutch is slipping but sometime catching. Or maybe the transmission is almost gone. Is there a burning smell? If so, probably clutch.
Apr 14, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool WTW5850S Top Load Washer Logo
71 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
