Question about Lifetime Professional Mechanic's 5- Piece Gasket, Hose and Pin Removal Set - Lifetim
Gaas leaks when I start the car
My gas leaks when ever i start the car. And according the by standers, I need a gas returning hose.
    Champion:
  • 225 Answers
Trace the fuel line before you start the car looking for signs of leakage takeing note of any stain or clean spots.then start the car and look for leaks around motor if you dont see any there shut car off and retrace lines for wets spots of gas.
Posted on Jun 21, 2009
Gas is leaking badly from a hose coming from the
Check and replace fuel hose from the pump line to the manifold and ensure that it is tight . Check return line from the regulator is tight. Check that the injectors are all tight and the seals are not leaking.
Oct 12, 2013 | 1991 Isuzu Amigo
On an 83 honda accord would a hole in the fuel return line cause the carb to flood.
A leak in the return line would likely not cause this type of problem, but a piece of debris stuck under the float needle would. If you have a leak in the return line, I would guess that the lines are corroded? If they are, then the pressure line may have corrosion particles that made their way up to the carb. Once the float gets a piece of debris stuck under it, it is difficult to remove without dropping the bowl.
Feb 06, 2013 | 1983 Honda Accord
2007 sonata water leaking under throttel body
under the throttle body is the cold start unit where two hose pipes are and the one works as an inlet with first start with cold and after with hot water feeding and the other as out hot water return to engine. The job of that unit is to get the water temperature and as electronic connected with the ecu is giving the message for cold start rev up until the water temperature change to hot and revs dropped to the correct according to ecu. most propably is either one of the two hoses leaking or the flange itself.
Sep 09, 2012 | 2007 Hyundai Sonata 3.3
Power steering leak
LOOK to see where it is leaking from and repair accordingly.
May 10, 2012 | 2005 Ford Focus
SES Light comes on after we refuel vehicle, code is bad gas cap. We replaced the Gas Cap 3 Times. It still comes on after refueling.
this is not just a bad gaas cap code. it is a leak code for the evap system and will need to be tested to find leak. look underneath vehicle and check hoses on the evap canister for cracks or fallen off the canister is next to tank rectangular box. if dont find anything it will need to be "smoke" tested to find the leak
Sep 24, 2011 | 2004 GMC Envoy
Dodge transmission return line leak
The return line is not under pressure so a rubber gas line can be use to fix the leak. Depending on where, cut the leaking section out and bridge the space with gas line and 2 small hose clamps.
Nov 24, 2010 | Dodge Dakota Cars & Trucks
P1456 code on a 1998 Honda Accord. Gas cap was checked out ok. Any other suggestions?
P1456 EVAP CONTROL SYSTEM LEAKAGE ( FUEL TANK SYSTEM)
There are a lot of potential leak points. The canister could be leaking, any number of the system hoses could leak. You could even have a leak in the fuel tank. Do you ever smell fresh gas?
Nov 12, 2010 | 1998 Honda Accord
I baught a 1999 chevy blazer from a man a month ago, I started smelling gas a week arter I vaught it.I called the man and he told me he replaced the fuel pump.I checked for leaks I couldn't find any.what...
The gas vapor return hose may have come off the fuel pump, it's just held on with a hose clamp, the hose may have came off. It attaches at the top of the tank, you may need to lower the gas a tank some to see if everything is connected.
Jun 02, 2010 | 1999 Chevrolet Blazer
2001 dodge stratus check engine light with code p0442 what can it be? thanks
P0442 is a medium evaporative system leak detected. Check your gas cap and make sure it is on tight and the rubber seal is in good shape. If it was loose, tighten it and the check engine light will exstinguish after a few days on its own. If not this usually means there is a small hose in the system that has developed a small split. It could be several other things as well, it is "usually" a hose. You need to take it to a shop that can proform diagnostics to locate the leak.
Here is a list of possable causes;
POSSIBLE CAUSES
LEAK AT GAS CAP
EVAP PURGE SOLENOID OPERATION
INTERMITTENT LDP MONITOR FAILURE
EVAPORATIVE EMISSION LEAK DETECTION
GAS CAP
LDP COMPONENT LEAK
Jun 13, 2009 | 2000 Dodge Stratus
P.s return hose from 1990 honda accord?
transmission line replace the hose new
Mar 23, 2009 | 1991 Honda Accord
Lifetime Professional Mechanic's 5- Piece Gasket, Hose and Pin Removal Set - Lifetim Logo
43 people viewed this question
Top Lifetime Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Lifetime Measuring Tool and Sensor Expert? Answer questions, earn points and help others
