Question about HP Pavilion dv2700t 2.5GHz Intel Core 2 DUO Mobile T9300 4GB 320GB DVDRW DL LS WebCam 802.11a/b/g 14... (KQ654AA) PC Notebook
Hp pavillion will not turn on, took battery out and put back in still not working. blue light around power cord on and blue lightening bolt flashes
Hello, My daughters computer is a HP pavillion entertainment laptop, product dv 2700 but by the warranty it says dv2910us when you open it and look on the upper right corner it says dv200.???. anyway when plugged in the blue light around the plug is lit up so I know the cords are plugged in correctly. I push the power button and the lightening bolt flashes three times I believe and then stops. the computer will not turn on. I have taken the battery out for a minute put it back in and still the same thing... right now i have had the battery out for about 10 minutes and am now pressing the power button to get the static out of the computer (I am going to school for computers and I remember something about needing to do that but not sure it I remmeber it correctly haha) I put the battery back in and still nothing but the flash of the beautiful blue lightening bolt... HELP!!
    Scholar:
  • 145 Answers
Hi Iceprincess5
The three flashing lights indicate the battery is dead. Since it still wont power up with the cable plugged in I'd say the port has gone. Try wiggling the adapter about in the port to see if it begins to charge. If not then you would need to take it to a laptop repair centre to get a new dc port soldered on or buy a docking station.
Posted on May 15, 2009
HP Pavillion dv6700 - won't power up
Hi have you tried to power up without battery?
Feb 16, 2013 | HP Pavilion Computers & Internet
Hello.The most common reasons for power issues are the battery, power jack and power adapter/cord.Power off and remove the battery. If the laptop powers on with just the adapter connected, your battery is faulty.If you move/wiggle the hp pavilion dv6700 power adapter at the point where it connects to the laptop, and the power goes off and on, the power jack is the problem.The power jack is inside the laptop and either needs soldering or replacement. If a power jack problem, it should be addressed by someone knowledgeable.If no change, the power adapter is probably faulty and needs replacement.Hope this helps.
MY HP 60 235DX WILL NOT TURN ON. I TOOK BATTERY OUT AND HELD DOWN POWER BUTTON, PLUGGED IT BACK IN AND IT STILL WILL NOT WORK. NO POWER LIGHT WHEN THE POWER CORD IS PLUGGED IN. BUT WHEN I DO PLUG IN...
fan turns? hear it and feel it.blow.? in must.
cd drive ejects? (button)
no text ever on the screen? this is first. all else more complex.
do the flash light trick?
http://www.pcdied.com/monitors.html#flashlighttest
no beeps
no flashing caps lock key (codes) if yes, what code.
step one is get BIOS and its screens working
even using and external VGA monitor will help.
and the magic Fn+F4 key to turn that on.
hp is down this morning...(support pages)
the G60 series uses a CCFL lamp, that blows out (easy)
or its inverter.
if external monitor works, and flashlight trick works
CCFL back lamps are dead.
Aug 23, 2017 | HP G60-235DX Notebook
I have an HP Pavillion dv9000 the blue lights come on for just a sec and then nothing. It will turn on periodically and works great when it on. But that is the problem it hardly ever does. Just the blue...
This could be lots of things. so lets try the easiest.
Blow out the dust in and around the fan(s)
replace the AC power cord and/or battery.
replace hard drive
and the big one replace Motherboard (which i done once in my lifetime)*
* = most likely not it.
Nov 02, 2010 | HP Pavilion dv9000z Notebook
My HP Pav laptop just died (shut down on me) and wont turn on
1.remove the battery and disconnect the power cord from the laptop. 2.hold down the power button for 1 minute 3.now connect it only to the power cord.keep the battery away 4. as soon as you press the power button to turn it on, keep on tapping F8 key. 5. If you see advanced option, you can choose safe mode with networking and it hit enter. 6. now remove the security like Norton or macafee and scan it with malwarebytes(www.malwarebytes.com) 7. Now, restart the computer 8. If data is not important you can restore the computer to the factory setting, but all of the data would be lost. 9.to restore the xp computer start press F10 at the startup 10. to restore the vista computer start press F11 at the startup.
Dec 08, 2009 | HP Pavilion dv9000z Notebook
Let the battery power down, plugged back in and now computer will not come on at all, took battery out, nothing, not even the little battery flash light, even tho power cord in and blue light around cord
Need to check the power cord to see if it is running at 19.5 fisrt. The power cord may be your whole problemand it cheaper than the other problem I see.
If power cord is ok take battery to the battery store to check it's cells. it sounds like to battery is bad. but the power cord should still bring the unit up. If the battery is ok and the power cord checks out the charging unit is bad and is costly.
Dec 07, 2009 | HP Pavilion dv9000z Notebook
My comp shut off and wont turn on anymore.. lightening bolt comes
Please remove the battery and ac adapter and then press and hold the power button for 25 - 30 seconds after that connect the battery back and then try to turn on the machine. if not remove the battery and just plug in the adapter and then try to turn on the machine. If still not working then try to swap the ram. or else your system motherboard requires to be replaced.
Jul 15, 2009 | HP Pavilion dv6000z Notebook
HP Pavillion dv9700 won't power up
Try removing the battery and using only power cord to turn the laptop on. If that fails, try turning it on without power cord, just on battery.
If none of those work, then most probable cause of your problem is motherboard. Hopefuly you are either under manufacturer warranty or you have extended warranty with your vendor where you've purchased the laptop.
If your laptop turns on on power cord, but without battery, then battery is the problem. Also, if laptop turns on when it's only on battery but it doesn't when you plug ac cord in it, then the adapter is the problem.
Jun 01, 2009 | HP Pavilion dv9700t Notebook PC
TRY HOLDING DOWN F10, F12 BEFORE YOU TURN ON THE SYSTEM, WE ARE TRYING TO GET IN THE SAFE MODE TO CONTINUE IN WINDOWS TROUBLE SHOOTING GUIDE, REMOVER THE BATTERIES AND UNPLUG THE SYSTEM TO FORCE IT TO TURN ON IN SAFE MODE THAN SELECT THE ONE MOST LIKELY SOUND WHICH ONE WILL DO THE BEST JOB FOR THE BANG.
Feb 13, 2009 | Computers & Internet
HP Pavilion dv2700t 2.5GHz Intel Core 2 DUO Mobile T9300 4GB 320GB DVDRW DL LS WebCam 802.11a/b/g 14... (KQ654AA) PC Notebook Logo
792 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
