Question about GE DBL333EBCC 5.7 cu. ft. Electric Dryer
How do i take the back panel off a dbl333 electric dryer
  • GE Master
  • 3,361 Answers
You can not access this dryer through the back panel. You must enter from the front.
Posted on May 15, 2009
Model 5030D
Instructions
Unplug the electrical cord of the dryer from the electrical outlet before attempting to fit a new belt on the dryer.
Remove the lint screen from under the lint screen cover and locate the screws that are underneath the cover.
Unfasten the screws with a screwdriver and remove them from the lint filter slot, setting the screws aside.
Place a putty knife between the top and the cabinet on both sides of the dryer near the front, lifting up to dislodge the lid from the plastic clips that hold the top down.
5
Flip the top back toward the back of the dryer and let it rest against the back wall.
6
Locate the front kick panel and slide the putty knife just behind both sides of the panel, pulling forward to unfasten the panel from the plastic clips. Move the panel out of the way.
7
Locate the screws that hold the front panel on the dryer cabinet at the top on the inside of the cabinet. Remove the screws using a screwdriver.
8
Unfasten the electrical wire connector by hand, pulling it straight out from the back of the front panel. Move the panel out of the way.
9
Place a couple of wood blocks under the front of the dryer drum to support it while you are removing the old belt. The drum is the cylinder that holds the clothes as they are drying, located just behind the front panels.
10
Push the idler arm forward just a bit to relieve the tension on the belt, and slide the belt off the idler and motor pulleys. The idler arm is located next to the motor near the back of the dryer and has a pulley on a metal arm with a tension spring attached to it.
11
Lift the drum up off the blocks just a bit, slide the old belt off of the drum, and take it out of the dryer cabinet.
12
Hold the drum up just enough to slide the new dryer belt around the drum and fit the belt into the V-slot in the center of the drum, laying the remainder of the belt on the bottom of the cabinet near the idler pulley so you can access it easily.
13
Loop the end of the belt around the idler pulley and over the motor pulley, pushing back on the idler pulley to release the tension on the belt.
14
Let the idler pulley move back into place and check the alignment on the belt to verify that it is seated properly on the drum and the pulleys.
15
Remove the wood blocks from under the drum when the new belt is installed and attach the front kick panel to the dryer cabinet, pressing the panel onto the plastic clips.
16
Place the front panel over the kick panel and attach the electrical wire connector to the back of the panel by hand, pressing the connector back over the electrical prongs on the back of the panel.
17
Attach the screws at the top of the front panel on the inside of the cabinet with a screwdriver. Lower the top of the dryer back down over the cabinet.
18
Press the top of the dryer down over the plastic clips until the lid is secure and fasten the screws on the inside of the lint filter cover.
19
Slide the lint filter into the lint filter slot and plug the electrical cord of the dryer into the electrical outlet.
Jan 09, 2013 | Hoover Dryers
How to remove dryer cover?
Instructions
    • Open the dryer door and locate the screws underneath the front lip of the dryer top. Unfasten the screws with a screwdriver and set them out of the way.
    • Flip the dryer top back so it is setting on the rear hinges. Locate the screws on the inside of the front panel near the top of the dryer.
    • Unfasten the screws on the inside of the front panel with a screwdriver and set them in a safe place. Lift the front panel up so it comes off the metal clips at the base of the dryer in the front.
    • Unplug the two-pronged electrical wiring connector from the back of the front panel by hand. Set the front panel of the Amana dryer cabinet out of the way.
Jul 02, 2012 | Amana ALE230RAW Electric Dryer
The dryer operates but does not produce heat. i think it is the heating element but i can not get in to the back of the dryer to check. i would like to get a service manual so i can check the element
1 Unplug the power cord from the electrical socket.
2 Remove the screws located around the edges of the back panel of the DVLR223 dryer. Move the back panel away from the cabinet.
3 Push the idler pulley away from the belt to loosen the belt tension. Remove the screws on the panel behind the dryer drum. Remove the panel.
4 Remove the four screws located on the underside of the top panel. Lift the top panel off of the cabinet.
5 Lift the drum up through the top of the cabinet and set it aside.
6 Unplug the electrical wires connected to the heating element assembly. Remove the old heating element from the DVLR223.
7 Insert the new heating element where the old one was previously located. Plug the electrical wires into the heating element assembly.
8 Replace the drum inside the dryer cabinet. Replace the top panel and the four screws that go on the underside of it.
9 Replace the panel behind the drum. Replace the screws that hold it in position.
10 Reposition the back panel onto the DVLR223. Replace the sheet metal screws around the perimeter of the back panel.
Jun 19, 2011 | GE DVLR223 Dryers
My dryer starts to squek real loud when it is running
The source of this noise is usualy the dryer drum drive belt.
  • Unplug the electrical cord before replacing the dryer belt.
  • 2
    Pull open the dryer door and locate the screws underneath the top lip that secure the top of the dryer.
  • 3
    Unfasten the screws holding the top on with a screwdriver and lift the top, flipping it back and resting it on the hinges.
  • 4
    Unfasten the holding the front panel on the cabinet, using a screwdriver. These screws are at the top on the inside of the panel.
  • 5
    Disconnect the door switch wires on the back of the front panel by hand, pulling the connector straight out off the electrical prongs and setting the front panel aside.
  • 6
    Locate the idler arm pulley next to the motor on the bottom of the cabinet near the back and push the idler arm forward to relieve the tension on the old belt.
  • 7
    Remove the old belt from around the idler and motor pulleys as well as from around the dryer drum and take the belt out of the dryer cabinet.
  • 8
    Place the new dryer belt around the drum in the center of the cabinet, fitting the belt inside the V-groove in the center of the drum, and lay the rest of the belt on the bottom of the cabinet near the idler pulley so you can access it easily.
  • 9
    Move the idler arm forward to allow room for the belt and thread the end of the new belt around the idler arm pulley and over the motor pulley, letting the idler arm move back to apply tension to the new belt. Check the new belt over to verify that it is lined up correctly in the V-groove on the drum and around the pulleys and that there are no twists in the belt.
  • 10
    Place the front panel back on the dryer cabinet, securing it with the screws on the top of the panel with a screwdriver, and plug the door switch wires back into the electrical prongs, pressing the switch wires on by hand on the back of the front panel.
  • 11
    Lower the top of the dryer back down onto the cabinet and secure it with the screws underneath the lip of the front panel.
  • 12
    Plug the electrical cord of the Hotpoint dryer into the electrical outlet.
  • Dec 28, 2010 | Hotpoint Dryers
    Model #MDE8057AYW I need to know how to get the lid off so I can see if I need a new belt
    1.Unplug the electrical cord of the Maytag electric dryer from the electrical outlet.
    2.Open the dryer door and locate the four screws on the inside,unfastening the screws with a screwdriver.
    3.Pull on the corners of the top front panel,rolling the corners forward to release the clips.
    4.Tip the front panel straight out and slide it up until the panel comes loose of the clips.
    5.Set the front panel aside and slide the top of the dryer forward.
    6.Lift the top of the Maytag electric dryer up,tilting it back and resting it against the wall.
    Aug 28, 2010 | Maytag Neptune MDE5500AY Electric Dryer
    Had electrical circuit breaker (240v) change out.
    check where the pigtail connects to the drier.
    Dave
    Feb 22, 2010 | GE DBXR463EBWW Electric Dryer
    Dryer squeak and back panel is hot? Frigidaire Dryer FDE436RES1
    It sounds like you have a rear bearing bad.
    as far as over heating check the vent line. Your thermostats are ok or your high limit would blow and you would have no heat.
    Sep 01, 2009 | GE DBXR463EDWW Electric Dryer
    Whirlpool GEW9868K Electric Dryer remove back panel
    You will need to pry the front corners of the top to open and then remove the front to get inside. Please unplug first , Thanks, Sea Breeze
    Mar 29, 2009 | Whirlpool GEW9868K Electric Dryer
    Replacing door on electric whirlpool dryer
    On the bottom right and left of the dryer cabinet are 2 metal clips.
    They are about 3 inches from the floor.
    The door panel has corresponding slots in it for these clips to go into.
    Put the clips in the door panel slot first, then align the door panel with the cabinet and close it shut. Replace 2 screws in the top right and left inside panel.
    Feb 11, 2009 | Whirlpool LER4634J Electric Dryer
    Dle5932w electric dryer
    the back of the dryer have about 16 sheet metal screws.remove all the screws with a nut driver.the back should come off.
    Jan 08, 2008 | LG DLE5932W Electric Dryer
    GE DBL333EBCC 5.7 cu. ft. Electric Dryer Logo
    116 people viewed this question
    Top GE Washing Machines Experts
    Dan Webster
    Dan Webster
    Tim Whalen
    Are you a GE Washing Machine Expert? Answer questions, earn points and help others
