Question about Toshiba Computers & Internet
Black at the right side of the lcd, about 2 inches and gray at
Black at the right side of the lcd, about 2 in, and gray at the bottom of about 1/2 in.
    Sergeant:
    Champion:
  • 225 Answers
Probably there's an internal hardware problem in your monitor - cold soldered / defective electronic part/s. I suggest to bring the unit to an authorized service center for proper diagnosis & fix the problem. best regards
Posted on May 17, 2009
My 42 in phillips LCD flat seen has a black horizontal line toward the bottom how can I fix this.
Samsung LN46B650 Thin Black Horizontal Lines - Forums - CNET
www.cnet.com > Forums > Samsung
CNETI'm experiencing thin black lines from the top of the screen to the bottom. ... by babes808gpa / January 15, 2010 1:42 AM PST ... lines are about 1/4 inch apart from top to bottom of screen. starts on the right and about a 1/3 of the way toward the ...have the exact same problem, my lcd tv has multiple lines are horizontal it ...
Faulty HD- LCD - LED TV - Horizontal Lines STRIPS on the ...
? 3:05
https://www.youtube.com/watch?v=KiqJuMiEiak
Jun 8, 2013 - Uploaded by Sameh Moustafa
Faulty HD- LCD - LED TV - Horizontal Lines STRIPS on the picture SOLVED .... I just have one black line ...
TV Repair Help for Vertical & Horizontal Lines on Your TV ...
? 2:47
https://www.youtube.com/watch?v=b0sI7LB4cZE
Dec 20, 2015 | Televison & Video
I have black line down right side of 42 inch hitachi lcd tv screen
You have a CCFL lamp that is failing in the panel, time for a new TV
Jan 22, 2018 | Hitachi Televison & Video
Where would i find the fuel relay switch on 94 s10 blazer
the fuel relay is on the fire wall, drivers side, upper corner.facing the truck its on the upper right side there are two 1 and 1/2 inch by 1 inch black plastic relays with connections attatching at the bottom you want the one on the right,that is the fuel relay.
Sep 27, 2009 | 1994 Chevrolet S-10 Blazer
Dark vertical bar on right side of display
Please let me know if you find a fix. and what the problem was. Eddie.
May 28, 2009 | Samsung DLP HL-P5663W 56" TV
Iphone screen white, clicks and turns on and off but cant see!
if is not water damage , apple should repair it. If not well open the iphone go to youtube see vid how to open it. turn off iphone open it just pull off #1 and put back in. that's the lcd connector. This should work if not take #1 then #2 and # 3 put all conector back that should work. #1 Lcd conectot #2 is the Digitizer #IS the ligth. If you got gray lines the lcd may be broken.
Apr 04, 2009 | Apple iPhone 3G
Screen Problem
Unfortunately the fix is a new lcd. The tab welds at the top of the lcd are not allowing that portion to work correctly. As these tabs are fused to the lcd you will need to replace the lcd. My Toshiba M105 is almost the same.(I Have 4" Gone) on the right side. so to use it I clicked and dragged my system tray from the bottom to the side. And shrunk my web pages to utilize tthe good portion.
I suppose I should replace it but being only 18months old the LCD's run about 160.00 USD.(sometimes I just hook up an external monitor.
Apr 16, 2008 | Toshiba Satellite P105-S6207 Laptop
Proview pl926wbi 19 inch monitor case removal
Hey Bob,
I just did this and the following worked for me.
1. Orient the monitor so the base is facing towards you and the top is facing away from your. Make sure the monitor is LCD up.
2. Grip the gray plastics just above the buttons and flex it up and towards you. You should be able to see the button control panel.
It should flex enough for you to rest the bezel and screw holes on top of the underside bezel. When doing this you have to wedge your finger tips between the LCD panel and the gray plastics to separate it. The trick is not to apply too much pressure to the LCD panel itself so you don't damage it. Almost all your pressure should be applied to the gray plastics as you lift "upwards" away from the LCD.
3. Once you have done this, you need to slide the bezel away from you towards the top of the monitor in order to release the side tabs and the top tabs. I found the best way to do this is to push upwards or away from you along the bottom left and right corners of the monitor and move upwards along the side of the monitor.
4. Once you have release the side latches the whole bezel should just slide upwards or away from you.
Note: When replacing the bezel you need to start from the top and insert the top tabs first. Then align the side tabs and last align the bottom button portion of the bezel.
Dec 10, 2007 | Proview PL926WBi 19" LCD Monitor
Computers & Internet Logo
81 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
