Question about GE WBSR3140DW Top Load Washer
Will not agitate or spin
Ge washer model number wlsr3000g1ww will not agitate or spin. HELP!!!!
  • genebarnard May 16, 2009
    If I have the washer empty it will agitate and spin when I put cloths in it it will NOT agitate ar spin what can be done
  • GE Master
  • 3,361 Answers
Check 1. the water level switch, 2. the timer, 3. the lid switch.
Posted on May 15, 2009
I have a GE spave maker Laundry that fills up with water than stops!
GE Washer Not Agitating Repair Guide
www.appliance-repair-it.com/GE-washer.html
If your washer will not agitate or spin take a look at this page GE Washer Not ... If the washer fills up with water then doesn't do anything at all and you do not hear ... if this were the problem, the water would not stop running, over-filling the tub.
GE washer spin cycle not working - ApplianceBlog
www.applianceblog.com/.../217-GE-washer-spin-cycle-not-working
Mar 12, 2005 - 10 posts - ‎3 authors
I have a GE "Spacemaker Laundry" (Stackable) model number ... Today it filled withwater initially then stopped working all together when it ... Bad motor, something jammed/seized up holding the motor back from running?
Jan 10, 2016 | GE Spacemaker Washer and Dryer Electric...
How do I check why my ge doesn't spin or agitate I look. In side put it on it doesn't move
Your problem sounds like the lid switch might be defective--if the switch doesn't close correctly or is worn out, the washer won't agitate or spin because it thinks the lid is open--safety feature. You did not provide a model number so my help is limited to the symptoms you describe.
Aug 02, 2015 | GE Washing Machines
Ge top load washer won't agitate or spin after
what is your model number is then we can started then okay
Sep 15, 2011 | GE Washing Machines
GE washer model WWA8955 agitator won't spin. I can see the screw at the top of the agitator turning back and forth and hear the it running but that's the only thing moving. The spin cycle works. ...
The agitator connects the part (transmission) that makes it agaitate by a piece in the bottom of the agitator and that connecting part has teeth on it that interlock on the transmisson shaft. That connecter is stripped so when trans. agiates that peice is slipping. That coupler needs to be replaced. This video here will show you how to replace that part. The part number for that peice is WH49X10042 it could be purchased at your local appliance parts store or online at,
searspartsdirect.com
apdepot.com
repairclinic.com
apwagner.com
assuredparts.com
I hope i have been able to help you fix your washer,GENE
Aug 15, 2011 | GE WBSR3140DW Top Load Washer
Agitator spins tub doesnt
GE USUALLY PUTS THE NUMBERS UNDER THE WASHER LID ON A METAL TAG. BUT I HAVE SEEN THEM ON THE REAR OF THE WASHER WHERE THE HOSES ARE LOCATED
Sep 16, 2009 | GE Profile WPSR3120WWW
GE washer won't spin
you need to post your model number
Mar 31, 2009 | GE WDSR2080D Top Load Washer
Washer will not agitate or spin
HI,
you can view this site to have some ideas about your agitator problem.
http://sites.google.com/site/sublimeappliancerepair/washer-will-not-spin/agitator-woes
any further question let me know.
thanks,
Mar 29, 2009 | GE Profile WPRE6100G Top Load Washer
GE washer won't agitate
try repairclinic.com
give the guru the make and model number. They are the best with appliances.
Good Luck !
Feb 25, 2009 | GE WBSR3140DW Top Load Washer
GE Washer Knocking During Spin Cycle
remove the agitator and inspect the main shaft on the gear box.and check the belt underneath.if the shaft is bend you will need a new gearbox. hope this helps.
Feb 09, 2009 | GE Spacemaker Washer and Dryer Electric...
GE Washer Model WJSR2080V3WW Agitates, Pumps, but will not Spin
I solved the mystery of the non spinning washing machine by GE. I pulled the agitator off and to my horror was a broken " hub". This the part in the middle of the basket under the agitator. The transmission shaft comes up through the center of it. Any way, it was severely broken and wedged in so it would not spin. Not sure if this is the only problem but I am going to buy a new machine. I can not get it unbolted to replace the hub and don't want to **** around with it. THANKS.
Jan 25, 2009 | GE Washing Machines
GE WBSR3140DW Top Load Washer Logo
430 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
