Question about CB Radios
Car Radio loosing memory
I have to store my radio channels every time when I start my car.  It seems that the memory is lost when I switch off my car.  Please help.
  • 1,139 Answers
Re: Car Radio loosing memory
You need to connect the wire that goes to the continuous 12volt.
This is the problem you do not have the permanent 12volt lead wire connected.
I hope this helps,
Thank you,
Posted on Oct 16, 2007
0 characters
3 Points
On a Maxon MCB-30 cb radio, there are three wires. Red, Black and Orange. Red and black are the power and ground, but whats the point of the orange wire and what do you connect it to?
Hello stud
The orange wire is for memory retention for the last channel you were on if the red wire loses power as in switched on and off with the car ignition just hook up the orange to a 12 volt source that is on all the time. By the way those are some neat little radios wish I had one.
May 05, 2010 | Maxon MCB-30 40-Channels Base CB Radio
I'm not getting any response from my one can hear me and i cant hear anyone
This radio has many frequencies and it is easy to "get lost" Make sure you have it on the correct band and check the HI / LOW switch as this gives double the channels that are on the band switch.
Feb 20, 2010 | Connex 3300 240-Channels Base CB Radio
I have a Mod 75-830 installed in a BMW motorcycle. Each time the unit is powered down, it goes back to ch 9. is there a way for the radio to remain on a given channel?
The unit needs constant voltage to keep channel memory. So if you have it wired to accessory, every time you turn it off, it looses memory. You need to wire it to constant voltage, and turn it on/off manually.
Nov 02, 2009 | CB Radios
Where do the 3 wires in back of my Cobra18wxst11 go? Can I use a cigarette lighter plug?
"Where do I connect the three power wires? (radios with 3 power leads)
Answer: Connect the black wire to chassis ground.
Connect the red wire to a switched +12 volt source, such as the fuse for the AM/FM radio.
The orange wire is for the memory retention of your CB radio, and should be connected to a constant +12 volt source. The fuse for the brake lights is usually a good choice.
With the radio wired as above, the radio will turn off when the ignition is turned off. The orange wire will provide power to the radio so that it remembers the channel.
If you are installing your Cobra CB radio in an application where you wish to utilize a cigarette plug to power the unit, connect the black wire to the negative lead (side terminal) on the plug. Connect both the red and orange wires together to the positive lead (center tip) of the plug. Your unit will function properly this way but will not retain the channel memory. When power is applied your radio will come up on channel 9."
Oct 23, 2009 | Cobra 18 WX ST 40-Channels Base CB Radio
Cobra CB
is any wires in the mic catching in the plug as this is a common fault with a lot of radios . eg. pulled mic wires.
Apr 09, 2009 | Cobra 18 WX ST 40-Channels Base CB Radio
I have a cobra cb and it makes a weird sound all the time, when i accelerate the sound gets biger
What you are getting is ignition noise from the engine of your car. Could be spark plug noise or alternator whine. If your radio has a ANL or NB switch, turn it on. If that does not fix it, you may have to get a filter for your powerline or change where you are getting power for the radio. Hope this helps, with the limited info available. Let me know,,,Mechanic
Oct 09, 2008 | Cobra 25 LTD 40-Channels Base CB Radio
Car Radio
Yes, my best bet is that there is no constant power going to the radio. Usually car stereos have 2 power wires. Generically, they are yellow and red on most major car stereos. The yellow wire needs to be powered at all times and the red wire needs to turn on when the car turns on. It is possible that you have them switched around. It would still work if you have them switched just wouldn't hold any memory. If they are correct I would search for a blown fuse. Make sure to check EVERY fuse. If you need further help, let me know the make, model and year of the car you are installing into and the model number of the stereo and I can tell you exactly what you need to do. Good luck.
-Andrew Hawkins
Aug 26, 2008 | CB Radios
Ch 9
Hi larry, That is a normal ch 9 default on electronic channel changers. Small midlands/cobras also do that. Try taking the red/hot power wire loose and attaching it to a power source that is hot all the time. That way there will be power going to the radio with the key shut off and it should retain the last channel you were on.
Hope this is what you were looking for, let us know,, Mechanic
Feb 21, 2008 | Maxon MCB-30 40-Channels Base CB Radio
Some models of the 75-822 do not offer this as a feature. Instructions for it are not included in the manual. I recently encountered a refurbished model packed with a manual such as this. Pressing and holding the "F" button toggles between Channel number and Frequency number display.
Jun 17, 2007 | Midland 75-822 40-Channels Handheld CB...
CB Radios Logo
143 people viewed this question
Top CB Radios Experts
Are you a CB Radio Expert? Answer questions, earn points and help others
