Question about GE Profile PSW26P Stainless Steel Side by Side Refrigerator
I need to know how to install a defrost thermostat on a PSWLSRDSS side by side GE refrigerator
  • 144 Answers
Easy you need unplug the unit from power.Now take the lower back panel off from inside the freezer you'll then see a defrost thermostat that looks the same as the new one unplug this and plug in the new one. Cheers
Posted on May 15, 2009
My GE model GSH25KGMB BB side by side refrigerator is not cooling on fresh food side. Freezer and ice maker side working fine. How should I troubleshoot this?
On your model I would go straight to the defrost heater and defrost thermostat and check them first after defrosting the evaporator first with a hair drier. Both parts need to be replaced=> WR51X10055 Defrost Heater Assembly 25953576-emtx2i4tcmlh0qfjbwwrn2z1-2-0.jpg and the=> WR50X10068 Defrost Thermostat APPLIANCE 911
Nov 11, 2015 | GE Refrigerators
The defrost timer where is it located in a ge refrigerator
HI would need to know model, but if it has a timer and its a top mount it will be located in the panel by the thermostat inside the refrigerator, if its a side by side its in the same place right inside the panel by the thermostat control. If its newer than 2001 it will not have a timer.
Sean
Mar 25, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
GE SIDE BY SIDE REFRIGERATOR NOT WORKING BUT FREEZER IS FINE.
You either have frost building on the rear wall of freezer indicating that the defrost heater and defrost thermostat need replaced or the damper that controls flow to fresh food section is shut or both. Let me know if you would like my assistance, Thanks, Sea Breeze
Dec 22, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerator not cooling
Look into the back of the freezer and if there is a layer of frost building on the rear panel it's possible that your refrigerator is not defrosting. If yes unplug and remove the frozen goods to the fresh food section. Remove the rear panel and defrost with a hair dryer or by setting a large bucket of hot water in freezer and close the door until the ice is melted.There are a few reasons for this happening and they are defrost heater, defrost thermostat, control board and other things that could cause this because of the way the refrigerator is designed. But the most likely reason is the defrost heater and defrost thermostat. Try defrosting and then letting me know what you find. If you need one one one free assistance I am here for you! Let me know what you find, Thanks, Sea Breeze
Oct 28, 2009 | GE GSS25LGM Side by Side Refrigerator
FREZZER IS COLD FRIDGE IS NOT
OK, Sounds like we have a problem with the defrost. Need to unplug and lets remove the rear panel and examine the defrost heater, It has a glass tub around it so it will be easy to see if its burned out. WR51X10101 Defrost Heater if you need to change the defrost heater it would be a good idea to replace the defrost thermostat also. Part number WR50X10054 Defrost thermostat. Let me know if I can be of more help. And please rate my solution, Sea Breeze
email appliancepartsse@yahoo.com
http://servicepartstec.blogspot.com/
http://appliancepartsse.blogspot.com/
http://appliancepartseast.blogspot.com/
Aug 12, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
The refrigerator side of my side by side does not get old. cool but not cold.l
We need to check three things. Need to have you OHM the defrost heater and check the defrost thermostat and Main Control board for burn marks on both sides. Thanks, Let me know, Sea Breeze
Jun 16, 2009 | GE GSL25JFPBS Side by Side Refrigerator
Where (specifically) is the defrost timer located on my GE GSS22JEMD (Side by Side) Refrigerator? How Do I check to see if my thermostat is working or not? Please help.
The timer is controlled inside the control board on rear of your refrigerator. Four possibilities are the defrost element, defrost thermostat, Temperature CLIP EVAP THERMISTOR or the control board is defective. Let me know if you would like me to help you on this, Thanks, Sea Breeze
Jun 16, 2009 | GE GSS25SGMBS Side by Side Refrigerator
My GE fridge is not defrosting the coils in the back. What's up?
if u have frost build up in the freezer it will affect the temperature
and it needs to defrost
problems could be
defrost timer.
thermostat.
terminator.
heater s.
unit problems (unlikely) if even frost coating.
Jun 16, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Side by Side (3 yrs Old): Freezer iced up, refrig not cooling
Most GE defrost problems are bad defrost thermostat and defrost heater.
It requies removing the back wall panel on the inside of the freezer to access the parts.
Mar 17, 2009 | GE GSL22JFPBS Side by Side Refrigerator
G.E. refrigerator
I do not suggest attempting this! If you think you have a defrost problem you need to test other thermostat and heating elements FIRST! But, I will tell you from experience that 90% of the time it is the computer board that needs replaceing.... Only if your having a defrost problem..IE., ice build up on evap coils. Replace the board and defrost all the ice with a hairdryer. And since you have the back wall off in the freezer you might as well replace the thermostat.
Goodluck,
Brian
If you still REALLY just have to know how to put refrigerator in defrost cycle just let me know.
Jul 21, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Profile PSW26P Stainless Steel Side by Side Refrigerator Logo
119 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
