Routers
Problem for Routers
Generic problem for all Routers
I just installed a new MSI RG60SE wir...
By zeepontiff on May 15, 2009
I just installed a new MSI RG60SE wireless router and i don't know how to secure my network
Best Solution
posted on May 15, 2009
Very Helpful)
dante777
Rank: Guru
Rating: 91%, 422 votes
You can find the manual for your router here.
Comments:
May 15, 2009
- Sorry - I hit the "submit" button a little premature...
Let me try again:
Ok - the manual can be found here. Look at page 27 onwards - it explains pretty well how to set up encryption on your wireless network.
Try to use WPA or WPA2 (you have to check of your computer can handle that). Try to avoid WEP, because it is not secure enough anymore.
Do the setup while your computer is connected via an Ethernet cable, otherwise you loose the connection when the settings are saved.
Tip: save the key in a notepad file and copy it later when your computer asks for it - that way you don't have to retype it.
Also - use a strong password:Upper and lower case letter mix and numbers - something like (Vg5iem3ohPhohs89oJUp4k) - you get the idea: something that is not easy to guess.
If you get stuck or have any more questions, just come back and leave a comment - I'm happy to help.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Routers
Questions and Unsolved Problems for Routers
Answer
We have a 3000 sq ft split level house, so range is critical (could we extend range with antennas,... (More)
Answer
Security(wps) light not lit on router
Answer
how to change the NAT and upnp settings of motorola PSA15R-240
Answer
What port number is associated with the printer port? I am trying to use the USR5461 router with... (More)
Answer
I bought an Encore 802.11n Wireless Router ENHWI-N2 so that my family's laptops can connect... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Routers:
Top Router Experts
Rank: Guru Guru
Solutions: 3663
Experience: Semi retired, was network administrator, proficient with hardware, software, networks, CAD systems
Ask Me
Find more Router Experts
Top Computer & Laptop Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
