Question about Kenmore Refrigerators
Ice maker hasn't worked in years. A couple of days ago food below the ice maker was thawed. Today I felt that the ice maker was hot to the touch. Is there anyway to disengage the power to the ice make
Kenmore sode by side with ice maker inside the freezer part. Ice maker has not worked for years. The last few days food below the ice maker has been thawing and today I notices the bottom of the ice maker was hot--really hot to touch. About 45 minutes later, I checked it ans it was no longer hot. (I pushed the knob for the size of ice from large to small when I discovered it was hot.) Is there anyway to disengage the power to the ice maker?
  • Kenmore Master
  • 4,655 Answers
Yes you will need to take the screws that mount the Ice maker to the side of the freezer and unplug the cable plug that is hidden behind the back of ice maker. The only time that element is needed to become hot is the moments before the ice maker drops ice. Thanks, Sea Breeze
Posted on May 16, 2009
Ice maker not making ice.
TRY DISCONNECTING THE ICE MAKER FROM INSIDE AND RUN HOT WATER OVER IT UN TIL IT IS COMPLETELY THAWED, THEN RECONNECT IT AND SEE IF IT WILL MAKE ICE NOW. SOMETIMES ICE MAKERS CAN BECOMED BLOCKED BY ICE.
Apr 12, 2010 | GE 25.0 Cu. Ft. Side-by-Side Refrigerator...
Jen Aire Fridge ice maker fingers are below the
This one you have to take out the ice maker and run hot water from the kitchen sink into the tray to get the ice out. need model number if you want detail explaination how to. or just use a hair dryer that will work to!!! if fingers dont rotate after defrost ice then the gears are stripped, replace ice maker
Mar 27, 2010 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
Turned ice maker off prior to a ten day vacation. Upon return, it would make thin shelled ice cubes and finally stopped altogether. Could the water line be frozen How does one de-ice?
Fastest way is to remove the ice maker tray so that you have an open area where the ice maker filling tube is, then cover your food with a towel or something to help prevent it from thawing while you let refrigerator defrost for about 20 to 30 minutes with a hair drier on warm or a small fan blowing directly on ice maker where the water fill tube or opening is. I does not need to be right next to the ice maker just an unrestricted open area to let it warm sufficiently to thaw it out without thawing out your food in the freezer. A small piece of ice can stop the valve from opening and this can happen if it is not used regularly.
Oct 08, 2009 | GE Profile 20.7 cu. ft. CustomStyle...
GSH22SXA & several problems
For some reason my post has disappeared. I left you with a lot of information and now All I have is a clarification request. Something is going on with the server here today.Sea Breeze
Oct 03, 2009 | GE GSS25JFM Side by Side Refrigerator
Sideby side whirlpool- 3 years old- ice maker stopped working 3 weeks ago. today everything in freezer is melting
Verify condenser fan is running. Check evaporator coils for frost. IM will quit if freezer does not go below 5 degrees. The cooling was slowly dieing and finally warmed enough to defrost the food.
Eric
Jul 16, 2009 | Refrigerators
Ice maker stopped dropping ice or even making ice.
Try using a hair dryer to thaw out the rubber tubing leading to the ice tray. On mine, I opened up the front door to the icemaker and found the rubber tubing leading in. I squeazed it, it felt frozen, so I applied heat. Water began dripping out, the area thawed, and I had ice again within a short period of time.
Mar 20, 2009 | Whirlpool ED2FHEXN Side by Side...
Sounds likw the water fill tubs is frozen shut, look where the tube comes into the freezer compartment and take a hair drier and thaw it out. Good Luck
Jan 07, 2009 | Kenmore 53642 / 53644 Side by Side...
Whirlpool refridgerator icing problem
2 things, first off if its under one year give whirlpool a calll, you would be coverd under warr. let them fix it, second i would ask you to open the door and remove the ice from the chute one more time, then check too see that the ice door flap is sealing properly against the chue, if theres a gap warm air will get in. perhaps the door feels real loose as if not sealing at all in which case perhaps a bracket has snapped and needs to be replaced,
Aug 07, 2008 | Whirlpool Refrigerators
We have a Whirlpool gb22dk refrigerator freezer. The bottom freezer keeps meat frozen but will not keep sea food ice cream bread ect frozen. This fridge came with our house which we purchased 2 years ago...
1st.Check the freezer door gasket for any place it maybe torn or not making a 100% seal when you close the door.That would make temperature drop. 2nd.take off bottom kick plate so you can look under the refrigerator.Using a flashlight make sure there is not alot of lint / dust stuck on the coils .If there is remove it carefully and you will see temperature lower. PLEAS RATE THIS!
Jun 09, 2008 | Whirlpool Refrigerators
Relay clicking, not cooling either side
check you paperwork , and manual. sounds like a compressor issue, which "should" be covered by 5 year manufacture warr. reason i say "should" is hte warr's all changed jan1/06. only one year form there . but check your manual itll have the warr info in it
Mar 20, 2008 | Hotpoint HSM25GFRSA
Refrigerators Logo
249 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
