Question about Delta TP305 12 - 1/2" Portable Planer
Belt on delta planer
How to change a belt on a delta planer
  • easthill May 18, 2009
    After looking at the manual you posted I still could not find anyway to replace the belt by removing bolts, so I put it on like you would a tire with two screw drivers. This is probably not the right way to do it but it is on and working. Thanks for the help
  • 2,176 Answers
I went to Dewaltservicenet.com and looked at a parts explosion and also the instruction manual for this tool. The manual doesn't say anything about how to do it, BUT the explosion is good quality and should guide you thru replacement. Please let me know if I can help further and if I answered your question would you please rate it accordingly Thank you.
Posted on May 16, 2009
I need all manuals for my SAC RS 63-S Surface Planer
Planers - Single - West Coast Machinery
www.wcmachinery.com/WCMACHINERY/myinventory.asp?...S...
Delta/Invicta RC-63-D 24" Planer in excellent condition. ... Table jack screw sprocketshave been replaced ... 16" single surface planer, - 5HP 208-230 volt single phase belt drive motor, - push ... with operation manual, - excellent condition but offered "as taken from service". ... 2240/440V, three phase S/N 203851 1974 year.Missing: my
Wood working machinery > Planers > Thickness planer (used)
www.machineseeker.com/2-106-65.html
Used Dickte SAC, further information will follow shortly... 2.500 EUR ... Thickness Planer, Thicknesser Huefner & Soehne 63 ... Thicknessing machine Sicar S 500... Working width: 500 mm Working height: 200 mm 2 speeds 2 Table rollers manualtable lift 4 knives - Safety shaft. ... Thicknesser mitTersawelle SAC RS 53Missing: my
Woodworking Planers - Southwest Machinery & Equipment
Dec 14, 2015 | Masonry Tools
How do I replace the infeed dolor on a delta 22-260 planer
Most parts bought will come with the installation instructions
Delta 22 560 Type 1 Planer Parts
Cheers
Billy of Hayward
Sep 26, 2014 | Delta 12" Portable Planer Model 22-560 W/...
Replace the drive belt
Do you mean replacing the cutter head drive belt?
With power off start the ribbed belt on the motor pulley, insert allen wrench into cutter head shaft. slowly rotate cutter head while feeding belt onto cutter head pulley. While rotating head, alternate between pulleys feeding it on one rib at a time. Softening the belt in hot water is NOT necessary to install the belt in this fashion.
Complements of
http://www.ereplacementparts.com/delta-22560-type-planer-parts-c-3275_3571_3579.html
Cheers
Billy of Hayward Delta 22 560 Type 1 Planer Parts
Sep 16, 2014 | Delta 12" Portable Planer Model 22-560 W/...
Planer problems
If you're looking at the planer from the infeed side, there's a belt guard on the right side of the head. Remove it and check the condition of the drive belt. If it's broke the motor will spin without powering the cutterhead and feed rollers. The drive belt is still available as part number 22-563 on sites like http://servicenet.dewalt.com/ and www.ereplacementparts.com. Just put your model number in their search box and find the drive belt in the breakdown.
Aug 01, 2012 | Masonry Tools
How do I replace the drive belt on my dewalt planer
Hi ladyccowboy1,
The drive belt is on the side with the handle (you might already know that :>)).
Take the top off, then remove the lifting gears. Remove the side cover. You'll see the cutterhead pulley that has ridges on it to keep the belt from moving in and out. Remove the pulley.
Change your belt and reassemble.
Hope this helps. If it does, I'd appreciate a 4 thumbs up. Thanks,
Handie Andie
Apr 24, 2011 | Delta TP300 Shopmaster 12-Inch Portable...
How to change blades in delta 12" planer
http://powertool.manualsonline.com/manuals/mfg/delta/tp300.html
Sep 24, 2010 | Delta TP300 Shopmaster 12-Inch Portable...
My 13 inch delta planer will not feed the stock through the planer. Any suggestions why?
I have a 12" Portable Planer Delta Model 22-540 - Planer will not feed the stock.
Sep 09, 2009 | Delta 22-450 20" Planer DC-580 3-Phase, 5...
Delta 12 inch thickness planer blade change
Go to this link and at the bottom center of the page insert your model number. You will be able to download the manual for that machine.
Delta manual
If your question has been answered, or I fixed your problem, please take just a moment to rate this post...thanks!!
Mar 23, 2009 | Tools & Hardware - Others
How to change planer blades on the Delta PT400LS 12.5" planer?
you will need the directions from the owners manual , do not guess at this it can be a hazard if not done properly i have manual and will try to look it up and figure how to get the info to you
Nov 19, 2008 | Delta TP300 Shopmaster 12-Inch Portable...
Delta TP305 12 - 1/2" Portable Planer Logo
692 people viewed this question
Top Delta Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
Debbie
Are you a Delta Craft and Hobby Expert? Answer questions, earn points and help others
