Question about Zanussi TC7102W Electric Dryer
Dryer does not dry clothes
The dryer drum does move but there is no heat so therefore not drying the clothes. Does the dryer have a reset button anywhere.
I have lost the manuel and am finding it frustrating as to what to do.  Please can you help? Thanks
  • 1 more comment
  • emmanuelir Nov 11, 2007
    The dryer does not heat tumble turns weel, checked both heat fuse at the back, they are fine, bypassed them with wire, same no heat.
    I suppose there is an other fuse of something somewhere that need to be checked ?
    Any help would be greatly appreciated.
    An other thing i can check
    What shall be the voltage between the fuse wire and the earth ?
    Where can i find a electrical diagram, i'm electrician myself and would like to follow step by step the supply to the eater resistance.
    thanks
    emmanuel
  • Jpgomez Dec 08, 2007
    I have a whirlpool electric dryer and the drum spins, but no heat comes out what do i do to fix it?
  • 94 Answers
If the dryer tumbles but does not warm up, you either have one or two blown thermal fuses, a burned out element if it’s electric, or a burned out igniter if it’s gas.
If one of the two thermal fuses are blown you will not get heat.  Thermal fuses blow (and are not resetable, they must be replaced) when the machine gets too hot.  Often this is caused by not enough air flow through the machine.  Check and make sure your exhaust vent is not clogged.  Clean it the best you can to get all the lint, dead mice, bird nests, etc. out.  Also make sure air is blowing out of the machine when it is turned on.  If not you have a blower problem.
The thermal fuses are located on the element casing.  They each have two wires coming out of them.  They are about 3/4 inch round with screw ears on the sides so they are about 1 1/2 inch long and about an inch across.  With a multimeter, check the continuity across the terminals.  If there is no continuity the fuse needs to be replaced.
To check the element(s), you can either visually look and see if it is broken or check the continuity with a multimeter.  No continuity means the element is broken.  Replace if necessary.
To check for a broken igniter, take out the old one and look at it.  If it looks broken or very burned, replace it.
Posted on Oct 17, 2007
  • Peter Grantham
    Peter Grantham Jan 09, 2017
    "If the dryer tumbles but does not warm up, you either have one or two blown thermal fuses, a burned out element if it’s electric, or a burned out igniter if it’s gas" - Is not 100% correct.
    The first thing to do is to check that the airflow within the tumble drier is not blocked. Remove ALL filters clean and check them. It is the cheapest and quickest solution, before you even consider calling an engineer.
    New Friend:
  • 21 Answers
The first thing to do is to check that the airflow within the tumble drier is not blocked. Remove ALL filters clean and check them. It is the first thing that you should do with all tumble drier not getting hot problems.
Posted on Jan 09, 2017
I HAVE A LG GAS DRYER AND IT DOESNT DRY CLOTHES. I HAVE NO POWER GOING THE COILS AND THE IGNITOR GLOWS RED BUT TURN ON A FLAME. THE TIMER STAYS ON 6 MINUTES FOR ABOUT AN HOUR AND DOESNT DRY CLOTHES. THERES NO POWER GOING TO THE COILS. WHAT CAN IT BE?
Posted on Jun 24, 2011
The dryer wont heat up the clothes dont get dry everything eles works on it the drum turns ok the timer works also it just wont dry the clothes
Hello,Sam
The usual reason a dryer will heat yet not dry the clothes is going to be a air flow problem. What ya need to check is for a blocked vent and or lint build up in the blower assambly.
By far though a leading cause of that on Maytag dryers is a broken blower wheel and therefore no warm air is being drawnthrough the clothes,to check that remove the front panel and the front drum support and in the lower left corner will be the blower asm. check to see if it moves free and doesnt seem to be attached to the motor shaft.
GENE
Sep 20, 2011 | Maytag MED5770TQ Electric Commercial Dryer
Dryer taking to long to dry
Overloading
1. One of the simplest problems to remedy could simply be that you are putting too many items inside the machine during the drying cycle. Avoid overloading your dryer, as this might cause your dryer to work extra hard to dry your clothing, extending the length of the dry cycle.
Wrong Heat Setting
2. A common issue with clothes dryers could be the wrong heat setting. Most home dryers feature several settings, from low heat settings to high heat and permanent press. Be sure the setting you choose is right for your needs. Another setting to check is the load size of your dryer. If you are drying a large amount of clothes, be sure the setting for large loads on high heat is selected. Choosing the wrong heat setting or load size can cause your clothes and linens to take longer to dry.
Lint Trap
3. One of the simplest fixes for drying issues might just be that your lint trap is clogged. Each time you use your dryer, lint will form in the trap. If the lint trap and vents are full, this could block air going into your dryer and slow down if not completely stop the drying process. After you use your dryer, remove this lint trap and empty it fully. Even if the lint trap is full, your other dryer vents might be clogged as well.
Clogged Vents
4. If your clothes are in the dryer for a long amount of time, but still not drying, the reason for this could be a clogged vent. A sign that your vent is clogged is if your clothes are warm or hot to the touch after sitting in the dryer, but still damp. To unclog your dryer vent, you may need professional assistance. This is especially necessary if your dryer vent leading out of the house is particularly long.
Heat Source
5. If the dryer is not getting enough heat to dry your clothes,something could be wrong with the heating system. After the drying cycle, touch your clothes to see if they are warm. If not, this means that the heating mechanism is malfunctioning. It will need to be repaired or replaced by a professional.
Feb 28, 2011 | GE Profile Harmony DPGT750GC Gas Dryer
We have a Kenmore 400 Series dryer. It heats up but our clothes is not getting dry. We have to cycle it twice to get our clothes dry on high heat. Any idea why it would take 2 cycles to dry?
This was the out vent of my dryer... If it gets this bad... open up the dryer housing and clean inside too. Also make sure the intake is free of lint.
Aug 23, 2010 | Kenmore 74602 Gas Dryer
The dryer drum moves but no heat. Clothes do not
most of the time it is the heating coil their is a
series of springs the heat up and then the blower
sends air pass them and into the dryer to dry the clothes
you will need to remove the back of the dryer
and get to the heating element and look at it
and see it any of the springs are broken
cost for the part 80.00 maybe
good luck
Jan 10, 2010 | Zanussi TC7102W Electric Dryer
My dryer is heating up but isn't drying the clothes
I would be REALLY suspicious of the exhaust vent. If the dryer is heating up and the drum is turning, it has to dry the clothes UNLESS there is no air going through the dryer. Disconnect the air outlet flexible plastic duct at the back of the unit, and turn it on. If there is no or very little air coming out, the inside of the unit will be plugged with lint. If there is lots of air coming out, the exhaust duct or the outside flapper will be plugged. Sometimes if the exhaust is routed through a cold space there will be so much condensation in the duct that it will droop and literally fill up with water.
Sep 09, 2009 | Whirlpool Dryers
No heat will come from the dryer
Check the dryer breaker pair in the house electrical box. Push off, then on. If the breakers trip immediately, then you have a direct short circuit in the dryer, usually the heating element which involves removing the drum to get at the element(s). If the breakers hold, then try the dryer. If you get heat--ok. If drum turns, but no heat--check with a voltmeter across the two slanted slots in the power socket. You should read ~220 volts AC. If near zero, then one of the breakers is probably bad. Get an electrician to replace the breaker pair.
Aug 17, 2009 | Dryers
The drum on my dryer won't move
Does it produce heat to dry the clothes? If it does it sounds like the motor may have burned out or disconnected, best to call someone out
Apr 13, 2009 | Kenmore Dryers
DRYER RACK DOES NOT DRY CLOTHES
try timed dry cycle instead of the auto-sensing setting. In your drum if you have auto dry such as less dry normal dry and more dry, There is a sensor sometimes in the drum and sometimes in the exhaust right after the blower. If in the drum then your clothes brush by this and if moisture is sensed then it keeps on drying. With your rack the clothes can't touch the sensor so it tells your dial to turn and that items are dry which in fact are not. Try this and see how it does.
Feb 17, 2009 | Samsung 7.3 Cu. Ft. 9-Cycle Electric Dryer...
My indesit widl126s
my washer works fine but the dryer wont heat up or dry the clothes it goes onto dry but all the clothes are still coming out wet and the drum is cold
Apr 01, 2008 | Washing Machines
On the top of the heater box there is a thermal fuse that blows if the dryer overheats, on this model it could occur if the air circulation fan is faulty, or the condenser valve is faulty, alternatively the sump hose filter may be blocked, only a closer inspection of these items will determin which the problem is.
Regards
Advisor
Nov 13, 2007 | Hotpoint Aquarius WF000 Front Load Washer
Zanussi TC7102W Electric Dryer Logo
2,792 people viewed this question
Top Zanussi Dryers Experts
Tim Whalen
Marvin
Marvin
Are you a Zanussi Dryer Expert? Answer questions, earn points and help others
