Question about HP Pavilion dv6000z Notebook
Network problem Why can't pick up the internet?
  • BWilson May 11, 2010
    You'll need to provide a little more information if you want to get a useful response. Try adding a description of what's connected to the computer including the type of Internet service you have (cable, dsl, dial-up modem, etc.). Also, include any error messages you may be receiving.
Tip
How to connect your PS3 to the internet wirelessly
Before we connect the PS3 console to the internet we must be familiar with the settings of the router. Listed below are the steps on how to access the router and how to connect the console to the internet wirelessly.
How to access the Router:
1. You need to know the ipaddress of your router. You can refer to the manual or check the Default Gateway of your computer (Make sure that you connect the computer to the router using an ethernet cable for you to get the Default Gateway). Click on START then RUN. Type CMD on the small box on the lower left of the screen. Type IPCONFIG on the black window and get the value of your DEFAULT GATEWAY (it starts with 192.168.x.x)
2. Open a Browser, Type the DEFAULT GATEWAY on the address bar of your Browser. It will ask you for a username and password. (Refer to the manual of your router or post a reply so that i can provide you the username and password of your router)
3. Go to the Wireless Settings Page of your router. Look for the SSID or the Network Name and the Network Key or Passphrase. You can personalize it so that you can easily remember the details.
4. Make sure you connect to your SSID and enter the Network Key to make it secure.
Steps on Connecting PS3
1. Power-cycle ALL network equipment. Turn off (unplug) ALL of your network equipment, including any Wireless Access Points, Routers, Voice Over IP (VOIP) Modems, and Broadband Modems for two (2) full minutes.
2. Confirm that your internet connection is enabled. in the home menu, go to Settings > Network Settings > Internet Connection and select Enabled.
3. Scroll down to Internet Connection Settings and When prompted, "Do you want to continue?" select Yes. On the next screen, select Wireless as your connection method. Pick "Scan"
4. From the list, pick your SSID.
5.On the next screen, press right on the directional pad to continue
6. Pick your WLAN Security Setting (either WEP or WPA-PSK/WPA2-PSK). If none, pick None (and skip the next step).
7. If you selected a Security Setting, enter your Security Key or Network Key with the keyboard. Press the Start button to exit the onscreen keyboard. Press right on the directional pad to proceed to the next screen.
8. The system will check your network configuration settings and display the information. Save the Settings.
9. Test the connection on the next screen.
10. When the test is complete (usually less than a minute), it will display the results ("Succeeded" or "Failed"). If you have successfully connected to your network, Congratulations, you have completed the network setup process.
on Feb 03, 2011 | Video Game Consoles & Games
What is wreless network connection
wireless network connection or wifi lets you connect to the internet via ethernet modem with wireless capabilities, with your particular laptop it should pick up the signal all you need is the network key to have internet on your laptop
Aug 12, 2014 | Lenovo G575-438343u Amd E-350 1.60ghz...
Using a Acer Aspire Revo. Running with linux Unbuntu 10.4lts. I have a BTHomeHub trying to connect my NWD-270N Wireless N-lite USB Adapter however it picked up the Hub and established a connection...
Select from the computers default internet networks, Recent computers are wireless enabled as the prefered networking. Attempting to introduce another network would share the connection capacity to any availabe signals. decide on the network type required. Pick wireless and disable the remaining networks to achieve an express signal reception and transmition.
Jan 29, 2011 | Zyxel NWD270N Wireless N USB Adapter...
How do i hook the dang think up to my computer?
Turn your cable-modem (or DSL-modem) off.
Turn the router off.
Turn your computer off.
Cable-modem <---- Ethernet cable ---> WAN (or 'Internet') port on the router.
LAN (or 'network') port #1 on router <---- Ethernet cable ---> network-port on your computer.
Turn the modem on. Wait for its lamps to settle-down to a repetitive pattern.
Turn the router on. Wait for its lamps to settle-down to a repetitive pattern.
Turn the computer on. Wait for Windows to start-up.
You now should have Internet access.
Click Start
Click Run
Type CMD
Press Enter
Type IPCONFIG
Press Enter
Look for output like "Default Gateway ... 192.168.xxx.yyy"
Start Internet Explorer
Type http://192.168.xxx.yyy
Press Enter
Login to the web-interface "inside" the router
Click to run the "Wireless Networking Setup Wizard" to configure the router's "wireless" configuration:
* pick an SSID
* pick an encryption-level, e.g., 'WPA'
* pick a password
Now, your "wireless" devices can connect to the router.
Dec 11, 2010 | D-Link DIR-615 Wireless Router
Doesnt pick up internet conectivity
try downloading the drive from your manufactors website andalso try to boot into safe mode with networking and run a virus scan http://onecare.live.com/site/en-my/default.htm?mkt=en-my
Jan 17, 2010 | Dell Inspiron 6400 Notebook
My dell inspiron e1505 tells me that it cannot pick up wireless networks. My computer was picking up wireless earlier today in front half of house. we extended the signal via ethernet cord and plugged in...
Depends apon the signal and how you have the computer settings some of the older computers have programs where differant places will not be picked up !
Did you check your internet options in your control panel?
1.Check your internet options and see if your lan settings have a check mark in the top box for lan atuomatic detect settings click ok then your internet should pick up ..... if you are still haveing prombelms please let me know ... Lala linda
has a check mark on the top box so there is a
Dec 24, 2009 | Dell Inspiron 1501 Notebook
Cannot figure out how to turn wi fi on on inspiron 1705. Must be a function button but don't have manual
Go to
  1. Start Menu->Control Panel
  2. Then Find Network Connections (Double-Click)
  • If it's in the -Category View- Then Click on:
  • Networking and Internet Connections, and Then Find Control Panel Icons:
  • Network Connections (open)
3. Find your Wireless Network Connection. (Not Local Area Connection)
4. Right-Click on Wireless Network Connection- and Pick -Disable-. NOTE BELOW (This Step)
5. ALL Done.
Note: To re-enable, Follow Steps 1-4, and then Pick -Enable-
I Hope This Helps.
Jan 20, 2009 | Computers & Internet
Interner connection
well first is it wired or wireless?
Wired: just plug in your Ethernet Cable in the back of the PS3 and go to Network Settings, Internet Connection and pick wired. do a Connection test and your good to go.
Wireless Network Settings, internet Connection then pick wireless, pick our access point and put any security codes in(WEP, WPA-SK) connection test and it should work.
But i recommend using the Wired connection cause the internet is a lot faster.
Feb 09, 2008 | Sony Playstation 3 (PS3) Console
Problem Picking up certain network
it is possible that your phone is locked to a specific network, and will not allow you access another sim card from a rival network. you will have to get your phone unlocked and it will then accept different networks. you will have to ring your network provider that supplied the phone and get them to give you the unlock code..or you can use various internet like http://www.unlockitnow.com/
Jun 28, 2007 | Samsung SCH-i600
HP Pavilion dv6000z Notebook Logo
318 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
