Question about General Electric GSS25JET Side by Side Refrigerator
Fridge is freezing up. not going thru defrost cycle we have a side by side ge fridge and it freezes up and we unplug it letit defrost and it will be fine for few days.& then is does it again; we replaced the defrost thermostat ( the book says it is called an overtemperature thermostat). and it is still doing it. we were told to check the defrost timer but don't know where this item is. could you help us??
  • GE Master
  • 3,361 Answers
The defrost heater must be replaced when the defrost T-stat is replaced.
The main control board located on the rear of the fridge controls defrost sequence.
Posted on May 15, 2009
GE profile side by side fridge freezing and thawing randomly
Defrost entire unit, put food in coolers with ice and unplug. Wait 24 hours with doors open. Any clogs in freon lines should be gone, plug unit back in and see how it works.
Jan 24, 2014 | GE GSS22SGM Side by Side Refrigerator
Side by side GE TFT28PFBBWW freezer ok, refrigerator side cools interminently, most of the times does not cool at all
The problem is defrost.
Its defrost problem, the freezer should cool, then freeze, then defrost cycle should start. In your case freezer is cooling, then freezing, but its not defrosting. That's why fridge section is not cooling.-------
Click this link below and follow the troubleshooting:----
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
This will help.Thanks.Helpmech/.
Oct 10, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
The freezer on my side by side refrigate won't freeze, It continues to defrost. what the problem
Hello there: The way you described the problem you have seem like the fridge is stuck on the defrost cycle and not coming back on the freezing cycle. Try the timer first and see how it goes. Hope this help.
Oct 05, 2010 | GE Profile 23.3 Cu. Ft. Counter-Depth...
Fridge running but not cooling
It sounds like you are having a problem with your defrost cycle. If your unit either does not go into defrost, or you have a defective defrost componet, it will cause your evap. to freeze. Hope this helps
Sep 09, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
My ge side by side fridge freezer coils in back of freezer keep freezin up what could it be i can fix it but havin hard time trubble shootin it?
if your freezing up then your unit is not going through defrost cycle. usually with ge refrigerators its most likely the defrost heater. but check and verify defrost timer and thermostat
Jun 22, 2009 | Freezers
Refrigerator freezes fresh food section and always runs
Please read it appears that there are two defrost timers for your refrigerator one for the freezer one for the refrigerator
http://www.partselect.com/PartDetail.aspx?Inventory=310858&SourceCode=4#RepairStory
May 02, 2009 | GE Refrigerators
Evaporator coil freezing over
You are probably correct, the auto defrost sub-system is faulty -- and probably the timer. You'll have to take the back panel out of the freezer to see the defrost timer.
Apr 29, 2009 | Refrigerators
Maytag MZD2766GES side-by-side Refrigerator warm
is it frozen up? do you have any air flow thru the air tunnel from the freeze to the fridge? Check your air flow with the door switch pushed in. also check to see if the damper door opens... 1) if it is iced up you have a defrost problem. most likely a defrost timer. Turn off or unplug untill all the ice has melted off the evaporator back of the freezer..plug back in and it will work fine untill the ice builds up again. if this work you do have a defrost problem.. if not let me know and we can go deeper...
Aug 18, 2007 | Maytag MZD2766GES Side by Side...
General Electric GSS25JET Side by Side Refrigerator Logo
193 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
