Question about Dyson Flowcheck CRO1 Front Load Washer
Water supply was too low,machine stopped mid cycle.pessed start again machine restarted but then stopped again about 10 mins later. call service centre is now displayed on the screen when machine is turned on. i have since changed the water supply valves but still says call service centre.
I suggest you check the fuse on electronic module which is located to the right side of the drum. Getting to it no easy task as you must remove the rear panel and top cover and jam an object thick enough for your arm to passbetween the drums and the machine body. Please ensure you earth yourself before touching this pcb as the static in your body may blow the intergrated circuits and eproms.
I hope this solves your problem.
Posted on Apr 02, 2008
Why won't it restart?
check the discharge hose that its not plugged or kinked
Oct 26, 2015 | Washing Machines
Frigidaire FDB126RBS2
Be very careful, it sounds like an electrical failure, were the machine has cut out to protect you and itself. You need an expert there and quickly. Water and electric are a bad mix and more house fires are caused by washers than most other appliances.
Sep 23, 2012 | Dishwashers
LG dishwasher error code after 2 minutes
fault with the programe as it has stoped in mid cycle
Aug 01, 2012 | Whirlpool Dishwashers
We have a Samsung front loader. Model # WF328AAIWIXAA. We started the machine to do a load, and later we were going to transfer the clothes to the dryer. It appears to not be getting power. We cant open...
Is the display (User interface) is lighting up and on. That means you are getting power.
If display on and cycle stopping at mid cycle and cannot open door.
If the machine water level sensor detects sufficient water in the machine it will tell the control board not to release the door.
Is there is water in the machine. May be your drain pump is clogged. Does it give a error code on display.
Don't force open the door. You will break the lock and you will need $ 200/= parts and labor to change the door lock
Call a local service guy
Oct 25, 2017 | Samsung WF337AAL Front Load Washer
Stops mid cycle. Light flashes, cant get it to move on so have to start all over again
Hi there.
I have the same problem with my machine. Whatever program I select, the machine runs fine until it reaches 54 mins of the cycle remaining. To overcome the problem just to select a cycle that will not stop mid cycle, select a program which is less than 54 mins. I think the 40 degrees and quick wash select is the one to run with. The cycle is 45 mins, obviously less that 54 mins. The LED timer will display the cycle time. No problems with this cycle whatsoever. Not the total solution, but at least you're able to complete a cycle. After it's completed, I also run the spin program at 1200rpm. I hope this helps.
Regards, Ian.
Nov 22, 2010 | AEG Lavamat 72640 Front Load Washer
Opened lid during wash cycle. Machine stopped but later restarted. The same thing happened two weeks later, but the touchpad has no function. It is getting electrical power to the dishwasher. Thoughts?
Ok so your dishwasher won't do anything... it justs sits there and "Hums" you can't make it respond to any controls, and the ONLY way to Stop it. is to unplug the unit, replugging back in it simply "Hums" again and will do nothing.
Now this happens because, the STOP Button, is pressed and the "Door Opened", during the Wash Cycle. This should NOT be done. You shouldNEVER TURN IT OFF MID-CYCLE. you should instead, Simply, pull on the handle, to Open the door, the system will take care of everything, after, you close it,and pick up where it left off. The turning OFF, makes the machine "Think" that a New Cycle, is going to be done, before the old one is finished, and resets itself to do it all again. But it still has water, that's not meant to be there so it must dump it out.
Now, the FIX. Take the Dishwasher, out, and tip over on it's side, tip to about a 45' angle. Water will come out from underneath, this is from a small "Overflow" reservoir. this reservoir has an "Anti-Flood" switch. The removing of this water will "Reset" this Switch, and allow the dishwasher to work again.
So what happens, is this, when the STOP button is pressed Mid-Cycle, the machine must "Dump" whatever water is still in the machine, into the "Overflow Reservoir". This water then causes the Anti-flood switch to jam, and this stops the machine, until it is reset,by the above method.
May 06, 2010 | Dishwashers
Power light and extra rinse rapidly flashing
Sounds like a cold water supply fault which could be the solinoid valve, the water turned off, a kinked or twisted cold supply pipe or a wiring fault. Check out the error code sequence here. You never said what make or model you have (the error codes are only for Hotpoint, Creda and Indesit machines)
Mar 20, 2010 | Washing Machines
Whirlpool 6th sense front load washing machine stopping mid cycle. Have to turn power off to reset & restart
I have the same problem. Stops randomly during the cycle and turning off the power for a second re-starts it.
I think it is one of the sensors is faulty - for example the sensor that detects if the load is un-balanced, or if the machine has enough water.
Seems to be a common poblem for these machines.
I'm going to try to find which one later today.
Dec 20, 2009 | Whirlpool AWM6120 Front Load Washer
DU1100 Stops mid cycle.
main control cpu unit failing
needs to be replaced
May 09, 2008 | Whirlpool 24 in. DU1100XTP Built-in...
The pressure tube switch tubing gets clogged on these machines. The best way to repair is remove the 4 torx screws securing the control panel, On the water level switch remove clear tube from switch, with some water in tub, i suck water up and back down the tube, clearing the tube. After tube is clear spin machine for 3 mins. Test water fill again.
Dec 04, 2007 | Washing Machines
Dyson Flowcheck CRO1 Front Load Washer Logo
64 people viewed this question
Top Dyson Washing Machines Experts
Starnley Johnwells
Starnley Johnwells
Gerry Harvey
Gerry Harvey
Are you a Dyson Washing Machine Expert? Answer questions, earn points and help others
