Question about Electrolux Refrigerators
Freezer works, fridge does not,runs constant though
Freezer works, but fridge does not...runs constant...HELP frs26zrg
  • steve
    steve May 11, 2010
    Is the fan in the freezer running?
  • 144 Answers
Try turning it off and defrost it for 48hrs with both doors open. Then turn it back on if it's still not colling the fridge then you need to check to see if the fan in the freezer goes at all. If it cools for a few days then goes warm again you may need a new D'frost element, D'stat or something else cheers
Posted on May 16, 2009
My kenmore 253 upright freezer/fridge is not cooling the fridge part correctly. It's cool but not cool enough to keep the food fresh. The freezer works well sometimes. And sometimes it seems that it's not...
Try this test. Set a window fan behind the fridge to constantly blow air across the lower coils at the floor. If the fridge works well after a while of this, then the lower fan on the fridge needs replaced. Sometimes though, after a while, the fan will finally start working again because the cycle has finally corrected itself with the test. Leave the window fan run on low for a few days before removing it. The hum you hear is the compressor moving the coolant and is supposed to do the hum sound. That's good. Now once the fridge is working, and you still have a good freezer section and not cool enough below in the fridge for you, there is a knob that sets the cool lower by opening flaps under the freezer to let more cold down to the fridge area. Set this knob to colder and the flaps will open more.
Nov 11, 2014 | Refrigerators
Which numbers give the coldest setting in the fridge section of the Frigidaire Refrigerator
THE COLDEST SETTING IN THE FRIDGE SECTION OF THE FRIGIDAIRE SIDE BY SIDE FRIDGE, MODEL # FRS26ZRG IS # 6
Oct 21, 2014 | Frigidaire Refrigerators
Hello, our fridge has stopped working, the fan and motor are still running but the unit wont get cold anymore.I think it might be a freon problem but I cant be sure. The motor and fan are running constant
Your right! A freon leakage system problem cause no cold anymore.
But a temp control must be check.
A defective temp control will also cause no cold of the freezer.
The same also if compressor motor is defective even though it is running.
Call a service technician to verify the trouble of your fridge.
I hope I give you idea regarding your fridge problem.
Jun 28, 2011 | Whirlpool ET1MHKXM Top Freezer...
Freezer working fine the fridge is not
The motor running constantly means the fridge is not sealed properly so that it is losing cold to outside. Check if the door of the fridge seals properly.
Jul 05, 2010 | Maytag MSD2756G Side by Side Refrigerator
Fridge of my Hotpoint FFA90 fridge-freezer freezes
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Mar 11, 2010 | Hotpoint FFA90 Bottom Freezer Refrigerator
Fridge/Freezer - fine bottom half, warm top half
Sounds like the fan in the freezer is not working ( pt# WR60X190 ) .
Jul 30, 2009 | Refrigerators
Fridge stopped working, freezer still works
Light going out is a separate problem. If the freezer is still working and the fan in the freezer operating check for frost on the back wall. If there is frost on the back wall you have a defrost system problem.
Possible open heater, bad timer, or defrost thermostat. If the freezer is not working check for power to it. Reset the breaker if necessary.
If the light went out because of some power loss the freezer would not be working.
May 26, 2008 | Frigidaire FRS26ZSG
New Frigidaire side by side running constantly and still warm
If the frost build up is on the back panel of the freezer then it has a defrost problem which causes a no cool situation. Let me know more about this frost buildup and what you have done.
Oct 07, 2007 | Frigidaire FRS3R5EMB Side by Side...
Refrigerators Logo
233 people viewed this question
Top Electrolux Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you an Electrolux Refrigerator Expert? Answer questions, earn points and help others
