Question about Microsoft Xbox 360 Console
When you put in a disc the drive will not engage. The play screen says "open Tray" instead of play "game"
  • cato_is_the_ May 16, 2009
    Same, just keeps saying open tray
  • Anonymous May 16, 2009
    inces=rt disk, close tray with controller or by concol says reading then open tray
There are several things that could cause this, but what happend to mine a few months back is a really simple mechanical error. Probably what is happening is that when the disk drive closes then either the reader is not spinning or it is not engaging.
If you open the disk drive up then power up and see what happens you can diagnose it. Open up the silver box, look underneath and press close. If when you do this the white toggles reach the end of their run (the last 3mm are not used) then the problem is likely its not spinning if it doesnt then the problem is not rising.
To fix either, lift up the two plastic locks on the tray itself and remove it so you can see inside. There should be a cog with teeth on your left, a medium and a small cog running a band between them in the middle and a white line with teeth at one end and a control on the right.
If its not spinning then the problem should be that the two cogs with the band arnt turning/are snapped, simply replace them and all should be hunky dory.
If its not rising then pushing the white line to the right untill it engages with the teeth cog on the left and it should rise, this problem can be permanently fixed simply by adding a tiny block to the end so it can still disengage but will be imediately re-engaged when needed.
Posted on May 17, 2009
    Problem Solver:
  • 10 Answers
For open tray message,there is a possibilty that the game disc is causing the issue or the console itself.
try using a different gamedisc,or a DVDs,CDs, if the same message appeared, call xbox support hotline or go to service.xbox.com to process a repair for the console.
My 360 will not play black ops. i have tried many new disc and nothing works. it will read other games but this one.
Try downloading the game to your hard drive and then taking out and putting the disc back in. If it says open tray several times in a row, try making the xbox vertical instead of horizontal.
Jul 23, 2011 | Microsoft Xbox 360 Console
The xbox 360 elites keeps on saying open tray when trying to play
1, the disc may be dirty
2. the mian reason for this your xbox drive cannot read the disc , because the power of the lens is gone(not completely) ,
solution:
1. keep your disc inside the drive and switch off the console, again swith on try this 2 to 3 time
2. keep the console in vertical position or little slanding position(180 dg) make sure it does not fall
3. its better to buy hatddisc and load the game inside it , so that u lens life increased
4. change the entire drive
Feb 09, 2010 | Microsoft Xbox 360 Console
I tried to fix a scratched disc using toothpaste but it didn't work. Now when I put another disc in , it won't play and nothing is reading it is saying open tray
The open tray problem is either a drive motor or drive magnet or a laser issue, If you turn your console off and lay it flat, turn it on,and give it a rap with your knuckles where the center of the disk should be, if the game loads its either the motor is too weak to engage the magnet or the magnet has become detached, either of these need the console opening to fix properly.
If the console won't load its a laser issue, try cleaning with a dvd cleaning disk.
Remember thumbs up if this works.
Feb 07, 2010 | Microsoft Xbox 360 Console
Open/Close tray message
This means that you need your DVD drive replaced. If you are under your 1 year warranty from MS go to www.xbox.com/support and fill out a repair request. If you are out of warranty make sure that you only let an experienced professional perform this repair. If you do the repair on your own, or have someone that doesn't know what they are doing do it then it's very likely your Xbox will never play games again. There is vital information on the old DVD drive that must be extracted and put into the replacement in order for your 360 to allow it to play games. I can do this repair for you if you'd like. Email me at Jordan@jordanselectronics.com for more info.
Dec 28, 2009 | Microsoft Xbox 360 Console
Wont read disc,instead says open tray
Try turning the xbox on and off. Try removing the power from the xbox and plugging it back in. Try other discs and see if it works. Try doing updates on your xbox360 and see if that fixes the problem. That fixed mine with Halo.
Aug 07, 2009 | Microsoft Xbox 360 Pro System Console
It only plays Normal Xbox games
The open tray and unplayable disc is because the lens isn't strong on the drive and needs to have a Pot calibration done to it to make the lens signal stronger. That should fix the open tray/unplayable disc issue. I have done this to quite a few drives and all have been working fine since.
Jul 12, 2009 | Microsoft Xbox 360 Console
My xbox 360 doesn't play my games
the lens of the disc drive needs a check up...
May 29, 2009 | Microsoft Xbox 360 Console
Xbox 360 won't play discs
This is the thing to do. Open the drive and look at the tray. Then go to this site to identify your dvd make http://www.llamma.com/xbox360/Xbox_360_DVD_Drive_Comparison.htm
buy a good working drive or a new one you have to open the drive and change the pcb board (circuit board in the dvd drive) from your drive to the good or new one. Then reinstall everything. The motherboard and pcb board are keyed together so you can't just use the drive with out changing the pcb's. If you need a drive I sell good used ones for $29 and $10 shipping.
Mar 22, 2009 | Microsoft Xbox 360 Console
X Box 360 Won't even attempt to read disc
when i put a game in the xbox 360 it keeps on saying clean the disk whith a soft cloth
Aug 05, 2008 | Microsoft Xbox 360 Console
Disc Drive
u need a new drive
Jan 02, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
244 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
