Question about Sta Rite Sr400na Max E Therm Pool & Spa Heater Dual Electronic Ignition Lo Nox 400,000 Btu Natural Gas
Gas pool heater SR400NA
Does not turn on. has a digital reading of 123, 124 where the temp reading is located.
  • 640 Answers
The users manual for these pool heaters has a very detailed troubleshooting guide. It has you check things on your heater that you need to be looking at to answer. Try using this guide. It will probably give you the most acurate and comprehensive answer.
http://www.backyardcitypools.com/images/bwp/Max-E-Therm-Manual.pdf
Posted on Aug 19, 2010
I had the same problem. My heater would read between 123 and 126. The heater sat all winter and a corrosion built up around the three sensors in the manifold; I guess I didn't drain it well enough. I pulled out all three and found that rust/sediment whatever had partially plugged two of the three and completely plugged the temp and/or ags sensor. I cleaned all orfices out carefully with increasing sized drill bits and re-installed the three sensors. It still didn't work so I purchased a new thermistor (the one with the built-in probe) installed it and the temperature immediately returned to 64 deg. The heater works fine now. MacGuiver of ECC
Posted on Jun 14, 2009
4 Suggested Answers
  • 83 Answers
SOURCE: Water Temp on heater reads 126 degrees F
I am not sure if you have resolved this issue, or not, but just in case. Yes, the problem is the Thermistor. This is a sensor that "reads" the incoming water temp. It is really easy to replace as well.
Posted on Jul 09, 2009
  • 990 Answers
SOURCE: Water Temprature read 126 on heater and will not Fire
This is a problem with your thermister (heat sensor) You will find this on the left side of the water manifold about half way down. I'm not sure but I think it is a small tube that slides into the manifold and if you follow the wires back to the board it just plugs in. The part is reasonable priced for a heater part and very easy to install. Good luck.
Posted on Dec 21, 2009
jharwell668
  • 640 Answers
SOURCE: Sr400na Max E Therm Pool & Spa Heater Dual Electronic Ignition Lo Nox 400,000 Btu Natural Gas: service heater light on?...
Try the owners manual for these pool heaters. They have a detailed troubleshooting guide that should let you know what you need to do.
Posted on Aug 17, 2010
Sta Rite SR400NA heater is about 3 yrs old. started once this spring and ran for a couple hours to heat pool slightly. 3 months later and trying to start it up and it will not do anything. read out says...
This is a common problem and easy to fix. Your temp sensor screws into the front side of the water manifold. You will just get a new one and swap it out. Your book will show you just where it is, but it's the size of a 1/2" plug on the top front of the manifold when you take the cover off the heater. Good luck.
Sep 19, 2010 | Sta Rite Sr400na Max E Therm Pool & Spa...
Temperature on the display is not the actual temperature. Heater will not come on
Without more info like what the temp reading is and what the actual temp is it is hard to say. The first thing that comes to mind is temp sensor has gone bad. This is located on the side of the water manifold and the wires run back to the control board. You can order one with a model number from your local pool store. These are very easy to replace I hope this does it.
Sep 05, 2010 | Sta Rite Sr400na Max E Therm Pool & Spa...
The heater won't fire and water temp reads 114 degrees. I've replaced the thermistor with no luck.
If the temp reads 144, the heater will not fire because it thinks the water is 144 ... entirely too hot and way beyond the safety limit of this heater.
I believe your trouble is in the thermostat sending unit.
Let me know what happens when you check this sensor.
Thanks for using FixYa.com
please vote
a
Dec 05, 2009 | Sta Rite Sr400na Max E Therm Pool & Spa...
My heater turns on then has a r 6 reading then shuts off?? Help!!
you must open the heater to get the code on the back of the board
Oct 06, 2009 | Sta Rite Sr400na Max E Therm Pool & Spa...
Water Temprature read 126 on heater and will not fire. Pool temp @ 72 degrees. Heater set for spa @ 101 degrees. SR400NA Sta-Rite Heater
Oct 04, 2009 | Sta Rite Sr400na Max E Therm Pool & Spa...
Sta-rite gas heater will not go on.
Part of the ignition system is bad. It is probably the ignitor, if you change it shut main gas supply to unit. Also, shut the power to the heater and turn it back on after repair
Jun 08, 2009 | Sta Rite Sr400na Max E Therm Pool & Spa...
Heater turns on runs for short time display reads 120 or so but temp stays at 80 or so
It is probably your thermistor. It is screwed into the header (the place where the pipes come out). To know for sure you would have ohm it out (I am not sure of the ohms of this particular model). If it ohms out ok then it could be the control board.
Apr 06, 2009 | Sta Rite Sr400na Max E Therm Pool & Spa...
Sta Rite Sr400na Max E Therm Pool & Spa Heater Dual Electronic Ignition Lo Nox 400,000 Btu Natural Gas Logo
308 people viewed this question
Top Sta Rite Pool & Spa Experts
Jay Finke
Jay Finke
john h
steve morris
steve morris
Are you a Sta Rite Pool and Spa Expert? Answer questions, earn points and help others
