Question about Brother MFC-640CW All-In-One InkJet Printer
Brother MFC-640CW Replaced Black catridge becomes empty
I replaced the black catridge with Office Depot made compatible catridge and it drained very quickly.  Is this a known issue? Not sure where all that ink has gone; I just printed three test pages. Please help.
  • santaclara Nov 04, 2007
    Thank you for providing the solution. I apologize for not rating the solution sooner. I did not get a chance to replace the Black catridge until yesterday. This time I have LC41BK from Brother, but I still have the same draining problem. When I first inserted the Catridge, the printer's ink status showed full ink level for black, but did not print when I selected copy and print in black. So, I pressed the catridge a little bit into the catridge holder. That fixed the printing in black colour issue, but the ink drained in about 4 to 5 hiurs. Not sure if pressing it in could cause the draining. I am going to open up the printer and clean the assy as Mix-it-up has suggested. I will keep you guys posted. I am also considering to get rid off brother printer and go for HP or some other brand.
  • 832 Answers
Compatible carts do make a lot of trouble. One point is the draining! The ink has flown into the cart assy and beyond that to the bottom of the printer. As long as you can print without problems you dont have to do anything. If the test pages wont show the correct color you have to open the printer and to clean the assy and the bottom.
Do use original ink carts though these wont drain and give correct info to printer. You can very simple refill them with dye ink. Dye ink only!!!
Posted on Oct 16, 2007
  • Mix-it-up
    Mix-it-up Nov 04, 2007
    OK. You need a new ink assy as a spare part because the foil which builts the ground leaks and let the ink pour out. Unfortunatly you cant fix the assy.
Brother mfc-240c
The digital display on the printer will tell you which color is low and when it needs to be replaced, either black, magenta, cyan, or yellow.
Oct 02, 2009 | Brother MFC 210C All-In-One InkJet Printer
Not detecting ink cartridge - or saying empty - Brother MFC 240c
Is it an ORIGINAL BROTHER cartridge ? ?
OR
A cheaper version ? ?
Aug 22, 2009 | Brother Multi-Function Center MFC-240C...
Black line 1cm in from margin when printing
this is a catridge problem so pls replace your printer catridge.
Aug 22, 2009 | Brother MFC-9420CN All-In-One Laser...
Will not print black
There is a Firmware Up Date that fixes problems with ink jet cartridges and near empty issues:
http://welcome.solutions.brother.com/bsc/public/us/us/en/dlf/dlf/000000/002800/dlf002854.html?reg=us&c=us&lang=en&prod=mfc640cw_all&type2=4&os=7&flang=4&dlid=dlf002854&dispforlist=1
Download with printer hooked up..printer may beep while loading...Do not shut off printer....
hope this works... Kiddrock
Jan 17, 2009 | Brother MFC-640CW All-In-One InkJet...
Replace black ink in brother mfc-465 inkjet & now it won't print
are you using brother oem ink? you ,may check and see if the seal is still on the cartridge, if not try and take a paper clip and insert it in to the air hole on the catridge, some times it gets clogged up. brother tech
Jan 13, 2009 | Brother MFC-465CN InkJet Printer
Brother MFC-210C does not reset after ink is replaced
The usual obvious fix is to buy a new catridge, insert, power off machine, then switch back on to reset any sensors. But if the circuitry on the machine itself is faulty it wont fix it.
I used to own an MFC 260C. It had a perfectly good full ink catridge in it, that was working fine, until...it suddenly did not recognise the cartridge anymore.
I pulled the machine apart and found that 2 of the 4 sensors on the cct board at the back of the cartridge housing were loose. These sensors pass light through the exposed part of the cartridge to see if ink is there. So if these are faulty, you will never clear the "No Cartridge" or "Ink Empty..." or "Near Empty Ink ..." messages on the MFC260C and probably other similar printers in the MFC range.
Why did they fail? Because the soldering on these sensors was poor quality.
I would never buy another Brother machine because of this, also because they design the machine to be totally useless unless all the ink ccartridges are full. Shame on you Brother, and kiss my *** for the $160 pile of junk I bought off you that was only on its second batch of cartridges (ie very little use)
Nov 21, 2008 | Office Equipment & Supplies
Printer says ink near empty
Black electrical tape works like a charm on a Brother MFC-465CN. Thanks for the tip! :-)
Jan 16, 2008 | Brother MFC 210C All-In-One InkJet Printer
See here: http://www.fixya.com/support/t192382-near_empty_yellowe
Sep 07, 2007 | Brother MFC 420CN All-In-One InkJet...
Brother MFC-640CW All-In-One InkJet Printer Logo
238 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
