Question about SanDisk Sansa e250 MP3 Player
I was updating my Sansa e250 player while connected to my computer (windows xp), and then when I disconnected it (using the "safely disconnect hardware button), the usual message appeared on the Sansa -- "refresh database", which usually disappears after 10-25 seconds. However, this time it's frozen in that message. The player will only turn on and off. Help! was updating my Sansa e250 player while connected to my computer (windows xp), and then when I disconnected it (using the "safely disconnect hardware button), the usual message appeared on the Sansa -- "refresh database", which usually disappears after 10-25 seconds. However, this time it's frozen in that message. The player will only turn on and off. Help!
  • 385 Answers
You are limited here as it is locked up, remove the battery to try reset it. leave out for few hours to drain the internal ICs
Or You will have to wait for the battery to die, then try the update again, as it has failed,
Hope this helps
Regards
Richard.
Posted on May 15, 2009
I was updating my Sansa e250 player while connected to my computer (windows xp), and then when I disconnected it (using the "safely disconnect hardware button), the usual message appeared on the Sansa --...
You will need to get your player into Recover mode.
1) Move "Hold Switch" to "Hold"
2) Press REC switch and power on switch untill the display shows "Recover Mode"
3) Then connect your player to your PC. The player should now show up as a removable drive.
4) Open "Notepad" on your PC and save an empty file named sansa.fmt on that removable drive.
5) Safely remove the drive and move "hold" switch to "No-Hold"
6) The display should say something like "formatting"
7) Then your Sansa will restart in MTP mode.
May 14, 2009 | SanDisk Sansa e250 MP3 Player
My sansa e250 keeps connecting and disconnecting from the computer. every time i plug it into the computer, it keeps saying that it's connected and disconnected to the computer. this switches repeatidly...
If it is flashing constantly, go into Start --> Control Panel --> Printers/Other Hardware --> System --> Hardware --> Device Manager --> and uninstall either the Sansa or the MTP device. Disconnect the Sansa from the computer, and reinstall the software that came with the mp3 player.
-Tha Mp3 Doctor
Jan 17, 2009 | SanDisk Sansa e250 MP3 Player
Sansa MP3 player e250
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Jul 23, 2008 | SanDisk Sansa e250 MP3 Player
SANSA E250 PROBLEM
Call Sandisk - best advice
but if you like pain:
-Tha Mp3 Doctor
Jul 09, 2008 | SanDisk Sansa e250 MP3 Player
Sansa doesn't work
May have to substitute HOLD or REC for Volume +:
Jun 23, 2008 | SanDisk Sansa e250 MP3 Player
MP3 player freezes in MTP mode when using Rhapsody
Try this: disconnect the player from the computer, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
or
-Tha Mp3 Doctor
Apr 16, 2008 | SanDisk Sansa E280 MP3 Player
Sansa e250 won't show up in devices!
I had the same issue. Brand new Sansa e250 player. My XP SP2 computer would not recognize it. I updated my Windows Media player to version 10. Bingo, all is working now. I previously had version 9. Good luck!
Dec 24, 2007 | SanDisk Sansa e250 MP3 Player
Disconnecting player while in MTP mode
It is not designed to show up as a Removable Disk in MTP mode, therefore it wont show up in the Safely Disconnect Menu.
If you are using Windows Media Player to transfer, as soon as the SYNC is complete, it says "ok to disconnect". You can disconnect without any problems.
If you are using Rhapsody, or the Best Buy Digital Music Store, you can right click on the device in the Sources Menu and select Disconnect.
Best of Luck,
Nov 15, 2007 | SanDisk Sansa e250 MP3 Player
Sansa Media Converter will not locate the e250
Use volume + method listed below to get converter torecognize device
-Tha Mp3 Doctor
May 30, 2007 | SanDisk Sansa e250 MP3 Player
My e250 wont let me add or delete any files
-Tha Mp3 Doctor
Dec 30, 2006 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
23 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
