Question about Microsoft Windows XP Home Edition
Internet disconnection after every 10 min. my net connection is gone.and if i want to connect to internet i must restart the system.plz help me as soon as possible. thank you
  • efs_perpends
    efs_perpends May 11, 2010
    Go to your event viewer and see if there are any error logs there associated with the connection failure. If so, report back with the error ids.
    Are you on dial up or something faster? Who's your ISP? What, if any, error messages are you receiving when the connection goes down?
    Do you have an up to date Antivirus running on your system?
    President:
  • Microsoft Master
  • 1,996 Answers
Maybe this will help you...click here or here or here
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on May 15, 2009
How can I fix windows 10 installation error c1900101?
  • Disable (preferably uninstall) your Antivirus utility before attempting the upgrade.
  • Restart a few times and try again.
  • Disable General USB Devices (example - Smart Card Reader).
  • If you are using a SCSI hard disk, make sure you have drivers available for your storage device on a thumb drive and it is connected. During Windows 10 setup, click the Custom Advanced Option and use the Load Driver command to load the appropriate driver for the SCSI drive. If this does not work and setup still fails, consider switching to a IDE based hard disk.
  • Do a clean boot and try again.
  • If you are upgrading using the .ISO file, disconnect from the Internet during setup, if you are connected by LAN (Ethernet) or Wi-Fi, disable both and attempt setup again.
  • If you are updating through Windows Update, when the download reaches 100% disconnect from the Internet LAN (Ethernet) or Wi-Fi and proceed with the installation.
  • If that does not work, try using the .ISO file to upgrade if possible.
  • If you are connected to a domain, switch to a local account
  • If you have any external devices attached to the machine, disconnect them (example, gaming controllers, USB keys, external hard disc, printers, non-essential devices). If you are installing Windows 10 using Windows Update, try the following:
    1. Press Windows Key + X on the keyboard and then select "Command Prompt (Admin)" from the menu.
    2. Stop the BITS, Cryptographic, MSI Installer and the Windows Update Services. To do this, type the following commands at a command prompt. Press the "ENTER" key after you type each command.
    net stop wuauserv
    net stop cryptSvc
    net stop bits
    net stop msiserver
    3. Now rename the SoftwareDistribution and Catroot2 folder. You can do this by typing the following commands in the Command Prompt. Press the "ENTER" key after you type each command.
    ren C:\Windows\SoftwareDistribution SoftwareDistribution.old
    ren C:\Windows\System32\catroot2 Catroot2.old
    4. Now, let's restart the BITS, Cryptographic, MSI Installer and the Windows Update Services. Typethe following commands in the Command Prompt for this. Press the ENTER key after you type each command.
    net start wuauserv
    net start cryptSvc
    net start bits
    net start msiserver
    5. Type Exit in the Command Prompt to close it and then restart the computer.
May 14, 2018 | Computers & Internet
ROUTER WONT CONNECT NO MORE IT SAYS THERE IS NOW ETERNET CABLE
Have you tried updating the driver? search..type in device manager...............right click on the network adapter and choose update
Sep 05, 2017 | Belkin F5D72344 Wireless G Router 54Mbps...
The conection freezes up and looses important work without saving it and it moves real slow. Had computer checked and was told it was the conection.can this be fixed or do i need an upgrade. loss of m
There maybe several explanations for the freeze ups,but I think the major one lies with your internet services connections.Whats the speed of the connection?How's the networks availability?Try this and see what happens:-
  • Uninstall and reinstall the browser[firefox]
  • Set firefox as the default browser.If still freezes;-
  • Choose another network for the internet connections.
Hope this helps.Thanks!
Oct 20, 2011 | HP Computers & Internet
My 3110c switches off iitself after 2-3 minutes everytime.I also changed the firmware but its not working.Plz anyone can help me.Plz give a solution for it!!!!!!!!!!!!!!!!!
Hi aaryandhunge....
If your phone is restarting you need to flash your phone
(formating delete all data including messages,contacts,etc... So i suggest you to back up all the files before formatting You can back up file using Nokia PC suit) To back up your files *Install the Nokia PC suit *open Nokia PC suit >Select Back up
To restore Backed up data *Open PC suit>Tools tab>Restore>Select Restore>select a restore point(restore point is file in which all data's are saved)>Ok and wait for 5-10 mins.
To flash you need
*USB cable compatible with your handset *A Computer *Nokia PC suite of your handset *Internet connection(Min speed 1Mbps) *Nokia software updater(you can download by using Nokia PC suit)
To flash *Install the PC suite *Connect to USB *Open the PC suit *Select UPDATE PHONE SOFTWARE(dowload the Nokia Software updater by selecting this option) *Install the "NOKIA Software Updater"*Select Update**....(It takes 10-30 Mins)
**Please don't disconnect while updation process.
Flash resets security code to 12345.
If your phone is switching of you need lock the battery correctly by putting a piece of paper.
or you need to change battery.
Thank you i hope tis helps feel free to ask queries.
Feb 16, 2011 | Nokia 3110 Cellular Phone
My samsung sgh m-200 mobile problem 1Chalte Chalte hang ho jata hai.2. auto restart hota rahta hai.plz solv my problems thanks
For this you need to scan your handset and memory from a updated antivirus
if problem persists you need to flash your phone
To flash you need *USB cable compatible with your handset *A Computer *PC suite of your handset *Internet connection(Min speed 1Mbps)
To flash *Install the PC suite *Connect to USB *Open the PC suit *Select UPDATE PHONE SOFTWARE(dowload the Nokkia Software updater by selecting this option) *Install the "NOKIA Software Updater" *Select Update**....(It takes 10-30 Mins)
To flash you need *USB cable compatible with your handset *A Computer *PC suite of your handset *Internet connection(Min speed 1Mbps) *Software Updater
To flash *Install the PC suite *Connect to USB *Open the PC suit *Select UPDATE PHONE SOFTWARE *Install the "Software Updater" *Select Update**....(It takes 10-30 Mins)
Thank don't forget to rate
Jan 28, 2011 | Samsung Cell Phones
Xbox 360 elite
hey do u have the rite cables and do u have dsl if u have and alarm hooked 2 the phone line that might be the problem also
May 25, 2008 | Microsoft Xbox 360 Elite Console
Acer Aspire 9304 lan connection problem
is your operating system vista? update your operating system in the internet / microsoft so that it will download all the patches it needs to make your computer works better
Apr 10, 2008 | HP Pavilion dv6000z Notebook
Microsoft Windows XP Home Edition Logo
41 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
