If by "Doesn't connect to the PC" you mean won't play games, it's because only new games can use the 360 controllers as it doesn't use the DirectX input, but uses XInput instead.
There are supposed to be solutions, sometimes through updates for the games (an example in reverse was an update for GTAIV, which allowed the use of the older DirectX joypads.) I've also seen software (switchblade) that allows various pads to work with RPGs. Not too sure if that would be suitable for you though.
Since I have both types of controller (both X360 and a Saitek Pad) I've never had to resort to any other fixes.
See if any xbox controllers will connect to your 360. If you can't get any to connect to your xbox 360 then that means you have a bad controller board. If you can get other controllers to connect then that means you need to configure your xbox to accept that xbox controller.
Remove and reinstall all USB controllers
To remove and reinstall all USB controllers, follow these steps:
Click Start, click Run, type sysdm.cpl in the Open box, and then click OK.
Click the Hardware tab.
Click the Device Manager button.
Expand Universal Serial Bus controllers.
Right-click every device under the Universal Serial Bus controllers node, and then click Uninstall to remove them one at a time.
Restart the computer, and then reinstall the USB controllers.
Plug in the removable USB storage device, and then test to make
I can not locate a Remote For PS3 By Gigaware now if its a controller Follow these steps
Connect to PS3 1. Turn on your console and plug the receiver into the first port on the console. The RX indicator on the receiver flashes. 2. Slide POWER ON/OFF to ON to turn on the controller. The controller’s POWER indicator lights and the 4 port indicators flash. 3. The controller connects with the receiver automatically after about 3 seconds. If successful, the RX indicator on the receiver lights. 4. Press the PS button to assign a controller number. The corresponding port indicator lights. Manual Search If you are unable to automatically connect, try manual adjustment. 1. Repeat steps 1 and 2 under “Connect to PS3.” 2. Press CONNECT on the receiver. The RX indicator flashes. 6 3. Press and hold SELECT and L3 (left analog stick) on the controller simultaneously for at least 3 seconds. When the RX indicator stays lit, release SELECT and L3. 4. Press the PS button to assign a controller number. The corresponding port indicator lights. n Notes: • Repeat “Connect to PS3“ or “Manual Search“ if the connection fails again. • If you purchase a new receiver for the controller, but have previously been using it with the supplied receiver, you will have to follow connection steps again. Reassigning a controller number 1. Press and hold the PS button for one second. The functional screen displays. Select “Controller Settings”, then “Reassign the controller.” Press X to confirm. 2. Use the D-pad to select the number that matches the controller’s port. 3. Press X again to confirm. The corresponding port indicator lights up. 7 Connect to PC 1. Plug the recevier into a PC’s USB port. The receiver’s RX indicator flashes. 2. Slide POWER ON/OFF to ON to turn on the controller. If connection is successful, the RX indicator on the receiver lights and the 4 port indicators on the controller turn off. Test the controller 1. Open the control panel on your PC, and double-click “Game Controllers.” Then click “Properties“ and the testing screen appears. 2. Press the buttons of the controller. After testing, press OK to exit. You are now ready to play games. Troubleshooting If the controller stops working at any time, or will not connect to PS3 or PC, follow “Manual Search“ steps on pages 5-6.
