Question about Kenwood VR-707 Receiver
Linking DVD/CD to Receiver
Was wondering what is required to link the Kenwood Receiver VR707 to a 5 disc Sony Carousel that appears to only have two output ports from the DVD to link to the 6 ports for the Dolby Digital 6.1.
Can anyone share how they were able to do this?
I can only seem to get two speakers working at a time.
    Problem Solver:
  • 9 Answers
You use rca cables to hook them up to each other. On the back of your Reciever make sure it is hooked to the cd. There should be speaker outlets in the back of the reciever. You should have suroundsound, Center, left and right speaker ports. I've never seen just 2. Crazy
Posted on Apr 21, 2009
SOURCE:
I have dish network and a dvr and cd disc changer i need to hook up to my kenwood vr-615
Hi shelleyhelle, I was reading over your post and see where you want toconnect the CD disc changer and you want to connect it to the Kenwood VR-615. Iwill send this link, http://www.retrevo.com/support/Kenwood-VR-615-Receivers-manual/id/480bh228/t/2/and it will help with the setup for the Kenwood VR-615 receiver.
Jan 23, 2011 | Kenwood VR615 Receiver
I have a Jensen DV2007 CD/MP3/WMA/DVD Player/Receiver and was wondering if it will play my Sony DVD-RW 3"mini disks
No they will not work as the loading mechinism would not be able to grab ahold of the discs. Normal cd/dvd's load because the mechanism grabs by the sides of the disc and the 3'" disc would be to small.
Sep 21, 2010 | Jensen AM/FM/CD/MP3 PLAYER WITH DETACHABLE...
400 disc changer (dvd/cd) has stopped playing the voice tracks from dvd movies. can hear all the rest of the soundtrack.
DVD movies usually send out a digital signal, like dolby digital, and this requires a matching decoder in your receiver in order to hear anything. Regular CDs don't use dolby digital, usually. Check you receiver to make sure it can decode the digital signal, and check your optical or digital coaxial cable.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Jan 12, 2010 | Sony 400-Disc MegaStorage CD Changer with...
Connection problems
If the CD player has left and right outputs and the receiver has those inputs for a CD or DVD then there's a start.
Speakers...match them up to positive and negative with no power to either component.
Jun 09, 2009 | Kenwood VR-307 Receiver
A cd has gotten stuck in my Sony 5 cd/dvd carousel player. Appears that the label on the CD had gotten soft (sticky) and when the carousel rotates it stays stuck underneth the top while the carousel moves...
As long as the cd hasn't caused any other damage to the electronics or mechanics of the player, it should be an easy fix. First, open your carousel then unplug the player to avoid shock. Remove the top lid of the player via the screws on the exterior holding it in place. From there, the stuck CD should be right there for you to reach in and remove. Hope this helps!
Mar 24, 2009 | Sony CDP-CE375 5-Disc CD Changer
Sony CDP-CX455
This is a player only that requires a receiver or pre-amp/amp combination to drive speakers. The output from this unit is what is called "line level" and can be connected to any CD/DVD/VCR or TAPE input on a receiver.
Dan
Jun 02, 2008 | Sony CDP-CX450 400-Disc CD Changer
Dubble den kenwood dvd player
There is a bulletin on the mech which requires 2 springs to be replaced. When you install disc the cd pushes on two sliders that push on switches to detect the position of the sliders the springs pull sliders back to original position. Sometimes the slider may stick due to not enough spring tension and possible restriction due to dust dirt etc. This would be a possible problem for your symptom . kstahl65@att.net
Feb 07, 2008 | Kenwood DDX7015 RB DVD Receiver With 6.5"...
Gears Not Aligned
I actually got it to finally work! It works like a champ, now. (My brother owes me know!)
Jan 20, 2008 | Sony DVP-NC600 Multi-disc DVD Player
Centre channel not working on SACDs
http://www.retrevo.com/search?q=Sony+SCD-XE670%2C+center+channel
May 23, 2007 | Sony SCD-XE680 CD Player
Kenwood VR-707 Receiver Logo
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
rigger094
Mike Duncan
Mike Duncan
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
