Question about MSI K9N6PGM-F Motherboard
I got this machine gun sound from my computer but before that i put a a guitar cord connect from a mixer to the microphone input of the computer... could anybody help me? please it's from the speaker that sound... because when i use the speaker on a mp3-player it sounds good...
How do I hook an EQ to my yamaha m65 amp?
your eq should either come between the outputs of your mixer and the inputs of your amp, or you can connect your source (guitar, keyboard, microphone) into the eq and out into either a mixer or straight to the amp
Feb 09, 2014 | Yamaha Audio Players & Recorders
Tip
How to play guitar using a computer
<p>Playing a guitar using a PC at home is a simple process that some audio devices and a computer to an analog line or microphone port on your sound card to obtain. There are two kinds of freeware, that a user can provide to the task. Basic freeware that standard on any Windows computer, including audio drivers free, microphone input, even if the computer's speakers to play. Users to make recordings of your own burning freeware, however, were interested in Windows freeware called "Sound Recorder" can do the work in the most elementary sense. <br /> <p><br /> <p>1. Plug the Phono-style audio cable into the guitar phono audio jack. <br /> <p><br /> <p>2. Connect the large to small-RCA adapter to the end of the other side of the RCA cable. <br /> <p><br /> <p>3. Connect the adapter cable and phono large on the back of the computer through a computer microphone. <br /> <p><br /> <p>4. Adjust audio properties of the system from the Start menu and Control Panel of your computer to play audio into the microphone port on the speaker. The exact process of adjusting the settings may be proprietary software, the sound card came with the computer system vary. If you have problems, ask the help documentation for software and manual for your computer sound. On most systems, the microphone volume level using the properties menu of the extended microphone system sound settings. <br /> <p><br /> <p>5. Set the switch to the guitar pickup - the pickup is a version of power - the "on" position. Adjust the volume on the computer so the computer speakers clearly the natural sound of the guitar can be heard. <br /> <p><br /> <p>6. Play a few notes on the guitar. If your computer speakers to play the guitar sound, the method proved unsuccessful. <br />
on Jun 22, 2011 | Computers & Internet
Can a Behringer C-1microphone connect directly into a computer and record? What other equipment will I need? Thanks
you could get away with getting a small behringer mixer that has +48V of power for the mic. Put your mic cable into there and then run straight out using 6.5 (guitar) cable to your computer. you may need some connectors to convert your jack.
Jan 27, 2013 | Behringer C-1 Microphone
No sound
This is not a powered mixer and so you must connect a power amp to the "line level" outputs of the mixer. Other "no output" problems could be related to buss assignments and other signal routing issues. Check for output by connecting "Main Out" left or right to a guitar amp input instead BUT turn all volumes down to zero before conductiong this test as guitar amps are designed for "Microphone" level inputs. Owners and Hookup manuals can be found here...
http://www.mackie.com/products/1604vlz3/
Sep 09, 2012 | Mackie 1604 Vlz3 16 Channel Mixer
I have a superlu pra-h7a. I also have a cable that connects to the bottom via a three pronged male plug with with a female connector on the other end. i have not used this in years, and can't remember how...
You need to connect it to a mixer first and from there to an amp/speaker combo. This microphone needs phantom power and you can only get it via the mixer. Also, you can control the volume via the mixer. Depends on what kind of speaker you have (active or passive) you will need an amplifier. If you're trying to plug it into a guitar amp, it won't work without a mixer. Plug the 3-prong xlr male cable into the input of the mixer. The 3-prong female xlr end goes into the mic.
Oct 08, 2010 | Superlux PRA-H7A Professional Microphone
Hi i have djx 750 and i have connect the master output on my amplifire and the tape or both to my line in from my pc sound card!!! the problem is that when i have open the mic from my mixer i can here it...
i have djx750 mixer, and i want to connect speakers to it,but the cable for the speakers are guitar jack leads and back of mixer are scart can i get a cable with guitar jack and scart on same lead??cheers
Dec 14, 2009 | Behringer DJx700 5-Channel Pro DJ Mixer...
I have a Yahmaha MG12/4 mixer or whatever and a speaker
heres a link to the manual for your mixer (big file)
http://www2.yamaha.co.jp/manual/pdf/pa/english/mixers/MG16_4E.pdf
to connect a guitar to a mixer you really should have DI box (direct injection) its matches the imbalances between the mixer and guitar for proper operation. If you have a guitar pedal this usually works as well. but if you just want to make it work plug the guitar into a channel input NOT INSERT. hope that helps
Mar 29, 2009 | Yamaha Mg12-4fx 12-Channel Mixer with...
Using the dp-01 as a interface mixer
If you're asking about being able to use the DP-01s knobs and sliders to control the virtual knobs and sliders on some PC recording software the answer would be 'no'.
But if you just want to use the DP-01 to act as a mixer for incoming signals (like microphones and or guitars or other instruments) the answer is 'kind of'. The DP-01 cannot act as a usb interface for your PC, but it can sit in front of a usb interface or sound card and act as a mixer of sorts to mix input from instruments through the monitor outs and then into your computers sound cards or usb interfaces audio-in jacks. You are however limited to two simultaneous inputs though as that is all the DP-01 can handle.
Cheers.
bd.
Oct 20, 2008 | Tascam DP01 All-In-One Recording Package...
Input audio to PV-GS250 from an external mixer
Problem check list:
- Try another cable in the connection to rule out the cable
- Make sure the 1/8 plug goes in all the way
- Make sure you have it connected to proper outputs on the mixer (and that it's not a powered mixer!)
- Make sure you don't have the output volume up too loud on the mixer
Dec 01, 2007 | Panasonic PV-GS250 Mini DV Digital...
MSI K9N6PGM-F Motherboard Logo
Top MSI Computers & Internet Experts
vsri9
David
David
Matthew Spark
Matthew Spark
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
