Question about HP Pavilion dv2120us Notebook
No Display Please help! my HP Pavillion dv2120us is no display at all! even a shadow in LCD no display at all! please help what can i do? im a electronic technician can you give me a guide how to fixed it!?! thanks in advance!
  • donnamaguire Jul 20, 2008
    I have the same problem no display it is black, if i shine a light into it i can see the screen and all else functions except the red light on the mousepad won't go out and it is not functional either
I have no display on my HP Pavillion dv2120us laptop. How did you fix yours?
Posted on Oct 19, 2008
    Novelist:
  • 85 Answers
First make sure everything else is getting power and operating okay, and that it is only the LCD display that is non-functional.
If you get no video signal or power at all, even at boot time, you probably have a dislodged ribbon cabling or power connection. Usually when LCD monitors go bad they show colour banding or all white, etc., but usually continue getting power.
As a last resort, try disassembling the lower case (with the power disconnected and the battery out of course) to expose the LCD monitor mounts, and then following the wiring from the screen into the laptop and check for anything loose or disconnected. You could also have a loose ribbon cable going into the LCD array, which will require disassembling the LCD cowling and mounts.
If you are handy and comfortable with electrics and find nothing loose, put the battery in and test the power line going to the LCD backlight, which should be getting above 7V (I think). Below that and you either have a bad video controller or bad wiring/solder joints somewhere. Otherwise, if the unit has been dropped or had a hard life generally, it could also be the connections between the LCD connector bus on the monitor array and the array itself. As a last resort, try unplugging and reconnecting all ribbon and connector cables, cleaning the exposed brass coloured runners lightly with rubbing acohol or even a pencil eraser.
Good luck...
Posted on Nov 16, 2007
My HP pavillion elite computer does not display correctly on my panasonic 32 inch lcd tv
TV and computer monitors have slightly different aspect ratios. You need to the configure the PC display settings. Check also if there is a panasonic display driver for your TV.
Sep 07, 2014 | HP pavillion elite m9340f core 2 quad...
I a having a laptop-HP pavillion dv6000,RAM 1gb and OS-32bit with window 7 ultimate,a problem of colourisation.i mean the display colour has change like a spray a of colours(green,deep blue)on the normal...
Try plugging in an external monitor and see how the display shows on it. If the display is ok on the external then your LCD Screen is going bad. If it shows the same colors on the external monitor then your video graphics card has issues.
Apr 21, 2012 | HP Computers & Internet
What to do when I dont get the LCD display in hp pavillion tx1000
Hi
did you see start up screen if not then just clean your RAM & remove your battery & plug in then try if u face same problem then send me more details
Harry
Jul 15, 2009 | HP Pavilion tx1000z Notebook
HP Pavillion zd8000 with less than full screen view
IF YOU GO TO START, CONTROL PANEL,DISPLAY, SETTINGS YOU SHOULD BE ABLE TO SELECT YOUR MONITOR THERE,GOOD LUCK MATE.
Jun 14, 2009 | Acer X193W LCD Monitor
Screen black computer laptop not starting ,hp pavillion entertainment pc,power lights on but screen black screen black computer laptop not starting ,hp pavillion entertainment pc,power lights on but screen...
hi,
if nothing(even hp logo ) is not coming on the display then please try this.
1.remove the battery and then press the power button for 30 sec.Again refix it and check.
2.If windows sound is there then this mught be the issue with display.
3.If there is no windows sound might be the issue with RAM so please get it checked.
May 29, 2009 | Microsoft HP Pavilion DV6276US Notebook PC
My HP 9311 Tx does not give display on its LCD screen
after loading Operating system just press F5 and wait for 2-3 seconds. if display not appear try 1-2 times. it will come. plz replt if ur problem solved
Apr 10, 2009 | HP Pavilion dv9000z Notebook
HP Pavillion dv8320us PC notebook display problem
Kathleen, I apologize for the inconvenience. As your external monitor is also not showing the display , the issue is not with any driver, it is the fault of the graphics card, unfortunately it cannot be removed from your Notebook, It has to be repaired from HP qualified technicians. If your notebook is under the warranty you can avail the mail in service without any cost. Or arrange a paid mail in service if it is out of warranty. You can simply go to HP.com and check the phone numbers of your local area to get the FEDEX box to your house for the mail in process.
Please feel free to contact for any queries.
Thank you & good bye.
Dec 21, 2008 | HP Pavilion dv8320us (HP RDV8320US) PC...
Ram capacity on HP Pavillion dv2120us
nope....that 2 gig is true..and the reason it may be invisible is that it is not seated properly, or, it is mismatched..
Oct 16, 2008 | HP Pavilion dv2120us Notebook
Computers & Internet Logo
215 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
